Old 08-06-2019, 10:13 AM
grivera's Avatar
grivera grivera is offline
Default Car stalled and won't start - looking for suggestions re: troubleshooting
I went for a long drive on Sunday in 90 degree weather. About an hour in, I filled up with a full tank of 93 octane. Engine temps during driving fluctuated between 185-195 degrees. After fueling up, I stopped at a light and the car stalled out. It would then crank and “buck” but wouldn’t start. With help, I pushed it to a side road and attempted numerous times to start it. Even considered it might be flooded so tried the pedal to the floor method and no dice. On a couple of occasions I didn’t even get a click at the starter/no crank, but the dome light would light when door open. The battery remained strong otherwise and cranked at regular speed. All wire connections visible on top of engine look normal. There was no electrical smoke, pop, etc. I ended up towing it home and it sits waiting on me to fix it.
It has an electric in-tank Walbro 255 lph pump with ˝” supply and return. I could hear the pump running and smelled gas at carb. I haven’t yet checked for spark. Dizzy is Dave’s Small Body HEI and coil is Summit brand e-core. Engine harness was replaced in 2011 with an M&H set up and HEI 12V wire - only about 2k miles on harness and 300-400 miles on this engine. About 9 months ago I swapped out the ignition switch on steering column. I have a 4 gauge cable from battery to a lug in trunk which powers fuel pump relay. That wire runs through firewall and along door sill guard, under rear seat into trunk.
I hope to get to it this weekend. I plan on checking for spark first then 12 volts at coil. Will also look at the starter wiring.
Any thoughts or ideas?
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
Old 08-06-2019, 10:33 AM
tstevea's Avatar
tstevea tstevea is offline
Ignition module if no spark
Old 08-06-2019, 11:38 AM
P@blo's Avatar
P@blo P@blo is offline
Could be pick-up coil or even a bad rotor so I'd pull the cap and have a look first.
Old 08-06-2019, 12:15 PM
If the accelerator pump makes fuel shot then I would say the pick up coil went open and a test with a timing light to see if it flashes will comfrim spark or not .
Old 08-06-2019, 12:42 PM
grivera's Avatar
I'm looking forward to digging in. Any comments on why on a couple of occasions it didn't turn over at all, or "click" the starter?
Will Rivera
Old 08-06-2019, 01:58 PM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
Check to see if the carbon button in the cap snapped off, I’ve had that happen
Old 08-06-2019, 02:29 PM
Cranking issues need to be broken down into either does it happen only when the motor is hot or has been sitting hot for 10 minutes and is now heat soaked, or the no Crank condition is random.
If it takes place when hot only then it could be the starter solenoid, Battery connections , or the switch in your case that's on the top of the base of the steering column.
When the motor does not Crank and you have your headlights on then if you do not see them dim then that atleast confirms that your Battery is good and something electrical connection is not closing to Crank the motor.
At that point your taking about a bad ignition switch on the lower base of the column, or the starter solenoid.
If your not running headers then many times when the motor does not Crank you can slip a screw driver down into the end of the starter and place a short across the Battery terminal and the Crank terminal and regardless if the solenoid is bad or not the motor will Crank.
Old 08-06-2019, 02:34 PM
STEELCITYFIREBIRD's Avatar
Check battery voltage on battery terminals, not cable terminals ~ 12.6 is full charge.
Proceed to clean and tighten terminals. Hopefully you don’t have any $2 bolt on battery terminals. Or one of those green knob quick disconnects. If you do make sure all are making good contact and not getting hot when cranking.
Check for spark at the plug, further diagnose if no spark.
Check for fuel discharge from carb, further diagnose info fuel available.
I’m going to guess at connection/s at starter need attention.
Define “buck?”
Did it ever sputter or fire when you tried to start?
Old 08-06-2019, 02:40 PM
phil400's Avatar
phil400 phil400 is offline
Did the engine slowly die or just quit on ya with no warning?
78 T/A 4SPEED, Original paint, match #’s, mine since ‘99.
77 t/a sold
85 Monte Carlo SS sold
83 Mustang GT sold
Old 08-06-2019, 02:59 PM
grivera's Avatar
I don't recall the small cap having a carbon button - maybe I don't know what that is?
I failed to mention I let the car cool to 150 on gauge before calling the tow truck - it cranked but no attempt to start - like no spark sound
Originally Posted by STEELCITYFIREBIRD View Post
Define “buck?”
The buck was similar to when an engine has too much timing. It didn't even sputter .
died without warning.
Will Rivera
Old 08-06-2019, 03:01 PM
indymanjoe's Avatar
my neutral safety switch acted up occasionally with a no crank situation. Doesn't explain the rest of your dilemma though.
Old 08-06-2019, 03:44 PM
rohrt rohrt is offline
It sounds like you might have got a bad tank of Gas. Friend of mine had the same thing happen. He filled up and didn't make it a mile and the car died. Ended up being to much water in the gas.
Old 08-06-2019, 05:35 PM
grivera's Avatar
Seems unlikely as it was Costco gas - but everything is suspect
Will Rivera
Old 08-06-2019, 05:42 PM
Schurkey Schurkey is offline
Originally Posted by grivera View Post
I stopped at a light and the car stalled out. It would then crank and “buck” but wouldn’t start... ...attempted numerous times to start it... ...On a couple of occasions I didn’t even get a click at the starter/no crank, but the dome light would light when door open.
WHAT starter motor? How old/how many miles?
Until you check for spark, all we can do is make wild guesses.
Old 08-06-2019, 05:55 PM
grivera's Avatar
The starter is a mini IMI- About 2k miles on it.
Will Rivera
Old 08-06-2019, 06:11 PM
phil400's Avatar
I'd look at spark. Anytime I've ever had a car just die on me has always been spark related.
77 t/a sold
83 Mustang GT sold
Old 08-06-2019, 06:21 PM
george kujanski's Avatar
Assuming the car dying and simultaneous cranking and starter motor related issues are due to the same fault, it seems like an electrical problem getting power to the cranking system and ignition system.
1. poor connection at the fusible link which provides power to the ignition switch and related.
2. Ignition switch related issues
3. Wiring issues at the starter if that's where the battery connection and the battery feed to the harness are joined.
If the ignition dying and the starting issues are separate faults, check each system for wiring issues (for the starter) and check for spark from the ignition system. if no spark, check for power going to the ignition system and then drill down as necessary. Connect battery directly to the proper terminal on the dist and try for spark. This will eliminate all intermediate wiring for ignition power.
george
Old 08-06-2019, 06:27 PM
phil400's Avatar
Just wanted to add,I've had a pick coil go bad on me. Quick.and easy test, connect test light ground to Positive batt terminal, put probe in tach of dizzy, no blinking light means bad pick up coil or maybe coil,blinking light but no spark is coil.
77 t/a sold
83 Mustang GT sold
Old 08-06-2019, 09:47 PM
grivera's Avatar
george
Where is the fusible link for the ignition switch located?
This sounds easy to do - will give it a shot, hopefully tomorrow
Will Rivera
Old 08-07-2019, 02:08 AM
I'm thinking along the same lines as George...What would trouble me is that some times you're not getting the starter to turn. That would have nothing to do with ignition or fuel. You either have two separate problems or one thing that is common to ignition and starter voltage.
So, the starter problem was just a couple of times...or fairly regular?
Checking for spark should be 1st thing on the list.
