Old 01-07-2020, 10:43 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Originally Posted by opeliac View Post
Why did you pick those?
Not sure I want to go into a lot but detail but to be safe the Hi-port will have a more reliable valvetrain and has the best I/E ratio. I'm sure all three heads would have a ton of power potential.
Go fast, see Elvis!
Old 01-07-2020, 10:49 PM
opeliac opeliac is offline
I'm actually looking for a pair of heads for my turbo car...So if you cant go into detail, who would you recommend that would?
Old 01-07-2020, 10:55 PM
PAUL K's Avatar
If you're considering using one of these three heads for your build, the Hi-port will be your best choice for your build. I doubt any of these three examples have been set-up for a power adder application.
Go fast, see Elvis!
Old 01-07-2020, 11:00 PM
I agree... Hi-ports will be your best option... PP's are expensive to build and tigers are not that power adder friendly.....from my personal experience..
Old 01-07-2020, 11:01 PM
What makes the hi port the better choice? Do all three have comparable deck thickness? Material thickness in the valve train area?
The Following User Says Thank You to opeliac For This Useful Post:
Old 01-07-2020, 11:04 PM
455firebird1969's Avatar
Originally Posted by slowbird View Post
Just thought i'd add some tech to the board, maybe generate some discussion.
Valve sizes on the heads ranged from 2.28 to 2.365. HP heads have made 1050 horespower with 1 carb and a cam that is gental on valve springs, other heads have not been run yet.
..........HP / PP / Tiger
.200 125 142
.300 194 218 221
.400 266 292 287
.500 334 349 367
.600 387 402 421
.700 417 446 453
.800 425 470 466
.900 428 477 478
1.00 430 480 484
Nice collection you have there. I have a set of HP’s I had done by Dave Wilcox recently. We went for max power on E-85 and ability to run all season without maintenance, it’s for a bracket car. I thought it would make for a nice comparison.
.4- 291
.5- 344
.6- 385
.7- 409
.8- 414 .8- through the Northwind intake 398
.85- 414
.9- 408
We are planning on .800 lift SR 50MM cam, and about 480 CI, IAII-A Block. I went with the Northwind to run it under a flat hood on a 74 T/A with a shaker scoop. The plan is to bust some unsuspecting chebby butt at the local drag strip, or anywhere I take it.
Old 01-07-2020, 11:10 PM
.4- 291
.5- 344
.6- 385
.7- 409
.85- 414
.9- 408
I hope he wasn't going for max port..... I'm a fan of Dave as he has made big power for me for 20 years.... he took my 406 from 12.20's to 11.20's for $800 in 97.. then to 10's at 3150 lbs with a hyd. Roller..
If he went for max power, 414 isn't there.... ??
Then 6.40's with a shoe string budget...
Old 01-07-2020, 11:35 PM
slowbird's Avatar
slowbird slowbird is offline
The pro ports arent available anymore so those are eliminated, the Tiger heads are nice but cost more and in a turbo build i doubt they're worth the added expense. The HP heads are by far the cheaper option and paired with a turbo will make HUGE power.
Old 01-07-2020, 11:44 PM
Stan Weiss's Avatar
.4- 291
.5- 344
.6- 385
.7- 409
.85- 414
.9- 408
Would you happen to have the .2 and .3 flow numbers? Also what size intake valve?
Thanks,
Stan
Pontiac Pump Gas List
Old 01-08-2020, 12:17 AM
He gave me what I asked for, which was a compromise. Given the restraints of 14/1 and low maintenance so I can run a couple hundred passes a season without having to worry about reliability, we ended up targeting .800 lift. He said they sounded sweet on the bench. I’m confident they will deliver.
Old 01-08-2020, 12:46 AM
Dragncar Dragncar is offline
Are those High Ports std pushrod, no offset shafts and lifters ? If they are then 414 is about as high as I have seen on a std pushrod High Port.
Old 01-08-2020, 08:11 AM
steve25 steve25 is online now
I got to say that for a high heat Exh motor like a turbo set up I would want a Exh port lay out like a RAV head and such.
Old 01-08-2020, 08:42 AM
PAUL K's Avatar
X 2
Go fast, see Elvis!
Old 01-08-2020, 02:20 PM
grandville455's Avatar
Nice!! What's the Minimum CSA in the Head?
Darby
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
Old 01-08-2020, 03:04 PM
PAUL K's Avatar
About "yeah" big 🤣🤣🤣
Go fast, see Elvis!
Old 01-08-2020, 04:56 PM
slowbird's Avatar
All I'll say is min csa is at valves
Old 01-08-2020, 06:08 PM
PAUL K's Avatar
Told ya!
Go fast, see Elvis!
  #38
Old 01-08-2020, 06:11 PM
Stan Weiss's Avatar
Brian,
That is interesting. I have never worked on a head where the throat was not smaller than the valve.
Stan
  #39
Old 01-08-2020, 06:16 PM
slowbird's Avatar
Brian,
Stan
Sorry it is the throat, didn't think people would take the "at the valves" literally lol
  #40
Old 01-08-2020, 06:36 PM
slowbird's Avatar
.4- 291
.5- 344
.6- 385
.7- 409
.85- 414
.9- 408
What are your performance/horespower goals? How many runs do you make in a year (just wondering how many runs it needs to go before maintenance)?
