Old 02-18-2020, 11:41 AM
grd777 grd777 is offline
here u go
Name:	IMG_2750 (002).jpg
  #42
Old 02-18-2020, 12:39 PM
78w72 78w72 is offline
Originally Posted by grd777 View Post
here u go
very difficult to see any detail of the ports on the base plate & the pics are sideways... can you get a pic showing the ports on the front of the base plate like whats in the link i posted of a 1980 turbo carb?
or can you look at the pics on the link & confirm you have the correct ports for the pevr? need to verify that since there is no # stamped on the carb.
http://www.v8online.co.za/TransAm-301-Turbo/
  #43
Old 02-18-2020, 05:38 PM
yes i have all the ports like the pic but they are all pluged
  #44
Old 02-18-2020, 05:57 PM
ok good. if you are sure they are all there & in the right locations, then hopefully its the correct carb. now all you need is to find a PEVR valve.
then you can confirm the vac lines are right & maybe do a basic vac test & confirm the choke has 12v power & operates correctly. after that you can check the turbo & see what psi its making.
  #45
Old 02-18-2020, 06:22 PM
going to order one from joe at tta but i think that the carb was not rebuilt correctly
  #46
Old 02-18-2020, 07:01 PM
send him the carb to verify internal parts are correct & do a rebuild. ive read these reman'd carbs can use incorrect parts like jets & secondary rods etc.
  #47
Old 02-18-2020, 07:21 PM
will do
