Old 05-15-2020, 01:39 PM
necdb3's Avatar
necdb3 necdb3 is online now
Default 69 T/A rear leaf springs
For anyone looking for the correct rear Leaf springs for a 69 firebird, Matt (tellyshavilli on PY) has worked on having them made. They are the correct 3 leaf springs and the car sits right where is supposed to sit. It's even at the same height as an original 69 400 firebird convertible I have with the original springs. Very happy with the springs,
Thanks Matt!
Old 05-15-2020, 01:44 PM
necdb3's Avatar
Sorry, I don't know how to rotate the picture.
Old 05-16-2020, 08:00 PM
jstites jstites is offline
Heartbeat city sells them. I have a pair and they are spot on
Drive it !
69 Trans Am coupe
70 Trans Am
76 SE 455 hardtop
87 GTA
89 Turbo TA
02 CETA Convert
Old 05-16-2020, 08:07 PM
grivera's Avatar
grivera grivera is online now
How much are they?
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'69 LeMans Vert, 350, #47 heads: work in progress
Old 05-16-2020, 08:40 PM
necdb3's Avatar
Heartbeat has them for $420.00
Old 05-16-2020, 11:54 PM
Firebob's Avatar
Firebob Firebob is offline
Yeah but how much is the shipping to Cali on a set of leaf springs?
Robert
69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always )
http://youtu.be/eaWBd3M9MN4
Old 05-17-2020, 11:50 AM
Dadspackard's Avatar
Dadspackard Dadspackard is offline
How about Eaton Spring
http://www.eatondetroitspring.com/db...rtsinquiry.php
Old 05-17-2020, 01:37 PM
necdb3's Avatar
You would have to check but the car sits where it should. That's worth it to me. Seems almost all spring replacements sit to high. That was the reason I replaced them in my car, somewhere along the line someone changed them and they were 2" too high. Looked like 4wd height to me.
Old 05-17-2020, 01:39 PM
necdb3's Avatar
Originally Posted by Dadspackard View Post
Has anyone tried them with success?
Old 05-17-2020, 04:40 PM
A Schab A Schab is offline
Eaton doesn’t even acknowledge they exist. I talked to a guy there a few years ago that called himself Mr. Spring, it was a waste of my time. The guy was a rude idiot that thought very highly of himself.
Old 05-17-2020, 08:46 PM
Here you go
Old 05-17-2020, 09:16 PM
Another view with the car levelled out
Old 05-18-2020, 02:00 PM
Firebob's Avatar
That's a lot of wheel well showing above the tire in the front. New coil springs too? Nice looking car.
Robert
Old 05-18-2020, 05:13 PM
necdb3's Avatar
Yes, replacement springs were installed in the front also and I'll be correcting that as well.
Old 05-18-2020, 05:15 PM
necdb3's Avatar
Guys, I want to make sure that I only speak for the use of the springs that I got through Matt. I don't know that they are the same spring as the ones at Heartbeat. They could be, but I cannot verify that.
Old 05-18-2020, 09:08 PM
FASTASSBIRD FASTASSBIRD is offline
Pretty sure Matt’s are his and his alone. Not even sure he has many more left. Guess I better get a set before he sells out
Old 05-18-2020, 10:06 PM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
I believe that Matt and Heartbeat collaborated on the springs so they are identical to one another. I'm happy to have a set for my car.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
Old 05-18-2020, 10:34 PM
Heartbeat city is incorrect . The supplier I worked with is Bob at Camaro Specialties (716-652-7086 )he has them and that’s who you should contact for getting the best and most accurate set of 69 Firebird Trans Am rear leaf springs that are available . thank you
Old 05-20-2020, 12:27 AM
Bird_collector's Avatar
Bird_collector Bird_collector is offline
Matt,
Are these a 3-leaf spring as indicated in the original post or a 4-leaf? I was of the understanding that 69 T/A had 4-leafs originally.
Old 05-20-2020, 08:28 AM
Originally Posted by Bird_collector View Post
Matt,
They are 3 leaf and that’s exactly what 69 TAs have from factory
