Old 11-29-2020, 10:57 PM
oethel's Avatar
oethel oethel is offline
Default Test n tune
Went to the track a couple weeks ago and my Catalina ran 6.59 at 108.95 foot braking.Original block and heads 400 stroked to 461 ,75mm turbo,small hyd roller,UCC convertor,Jake's stage 3 th400 kit,9in rearend with a 3.50 gear.Best of all,I can jump in it and drive anywhere.
I don't know how the hell to get these pics upright.
ID:	555048   Click image for larger version
Old 11-29-2020, 11:32 PM
4dblnkldude's Avatar
Nice!!! So what is that in the 1/4? 10.50?
Old 11-29-2020, 11:53 PM
oethel's Avatar
Thats pretty close.I think I have the potential to run a high nine.That will be my goal next year
Old 11-30-2020, 07:07 AM
With that 60' time, if it would launch good, it would be a LOT faster.
Good run and good looking 'land yacht'
ID:	555071   Click image for larger version
Old 11-30-2020, 08:19 AM
Scott Stoneburg's Avatar
Thats running very good on the top end. I think that 6.59@108 will get you in the 10.30s in the 1/4.probably in the 135 mph range.
Old 11-30-2020, 09:05 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Wow now that's a sleeper!
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
461, 850 Holley, T2, KRE 310s, Comp HR288 w 165s, RA manifolds, 11.60@114, 1.58/60
The spare: 467, 850 Holley, T2, Edelbrock Dport 310cfm w RA manifolds, HFT 245/251D .561/.594L, 11.59@ 114, 1.57/ 60'
Old 11-30-2020, 09:16 AM
firechickenman's Avatar
firechickenman firechickenman is online now
Very nice! You will definitely be hurting some feelings with that car if you haven't already!
Greg Weigart
IAIIA 520/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radial Pro/3300lbs/1.35 60'/6.21@110.47/9.77@137.08
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69
2022 - 10.13 @ 133.07
Old 11-30-2020, 09:52 AM
mysticmissle's Avatar
awesome job, is that blow thru or efi?
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 11-30-2020, 10:28 AM
leeklm's Avatar
leeklm leeklm is offline
Yes, definitely a sleeper! Have you run the car across a scale?
Sent from my SM-G965U using Tapatalk
Old 11-30-2020, 12:52 PM
oethel's Avatar
CSU 750 carb and weights 4240
Old 11-30-2020, 07:19 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Have you tried a bigger carb?
Hauling.
Old 11-30-2020, 08:31 PM
oethel's Avatar
I've got enough carb to split the block right down the middle already.
The Following User Says Thank You to oethel For This Useful Post:
Old 11-30-2020, 08:34 PM
jimmy daniel's Avatar
jimmy daniel jimmy daniel is offline
😂😂😂 That car is bad ass!!
1965 TriPower GTO, 1967 GTO, 1969 GTO, 1969 Judge, 1972 GTO, 1977 Smokey and the Bandit, 1989 TA ProStreet, 1968 Firebird NHRA 10.90 racecar, 1963 Tempest S/Gas
Old 11-30-2020, 09:19 PM
D STAGE 2 455's Avatar
D STAGE 2 455 D STAGE 2 455 is offline
That's hauling the mail, How big are the rear wheels ? The car looks tubbed on that picture.
Definitely my kind of car!!!
Old 11-30-2020, 09:59 PM
firechicken's Avatar
firechicken firechicken is offline
How much boost?
Intercooler?
Engine bay pic?
Cool car!
Old 12-01-2020, 12:23 AM
oethel's Avatar
No tubs and a 12in wide 750 series Sander wheel with 275/60 radial pro rubber at 18psi.I put hi-tack on the beads to help keep from slipping. no beadlock and one of my tires moved on the rim about a inch.see the white mark?I believe that 6.59 run was 13-14lbs boost.I'm using a treadstone #1245 innercooler.
That first pic of the engine is a mirror image.still try too figure this damn picture problem i got.
Name:	20200301_162216 (1) (1).jpg
ID:	555134   Click image for larger version
ID:	555135   Click image for larger version
ID:	555136   Click image for larger version
Old 12-01-2020, 08:34 PM
flamedabone flamedabone is offline
All that car needs now is a flawless coat of shiny black paint.
Nice work, -Abone.
Daily Driver Model A Ford. 389 Pontiac w/6-71. 10.80 @129.5
1933, 1934, 1936 and 1940 Fords, also Pontiac powered.
Old 12-01-2020, 09:27 PM
blueghoast's Avatar
What heads you running steel or alluminum?
GT
Old 12-01-2020, 09:49 PM
charlie66's Avatar
How did the wastegate work for you?
Great times so far!
My Half AN Injun.....
Old 12-01-2020, 10:28 PM
oethel's Avatar
Paint don't make it any faster,but your right,it needs a nice paint job....the 7K3 heads are original to this car and have stainless valves,10 degree locks,lash caps and Teflon seals.Butler street ported these heads in 98.I had Butler freshen them up and spec springs for the Butler hyd roller turbo cam.my built on this engine is in the boost section a couple years back......Charlie the turbosmart
Hypergate45 has worked flawless.I must have did something right....thanks
