Old 05-07-2021, 10:16 PM
Stuart's Avatar
Stuart Stuart is offline
Default Supercharged Mickey Thompson 4 cylinder engine
I saw this was posted in the Craigslist discussion in the Lobby. I figured I'd put it here as well, since it's a slant 4 engine:
https://losangeles.craigslist.org/sg...318419087.html
1960's Pontiac Tempest 4 Cyl race Motor - $5,000 (El Monte)
Pontiac Tempest Vintage Race Motor build by Mickey Thompson
471 Blower 183 CU IN
MT Rods Pistons
ID:	566105   Click image for larger version
ID:	566106   Click image for larger version
ID:	566107   Click image for larger version
ID:	566108   Click image for larger version
Old 05-07-2021, 10:45 PM
tom s tom s is offline
If it is a M/T engine it was built by Fritz Voight who was his mechanic.Tom
Old 05-07-2021, 11:26 PM
No M/T valve cover.
Might be irrelevant, but makes you wonder.
Old 05-07-2021, 11:55 PM
PontiacJim1959 PontiacJim1959 is offline
It may only have MT rods/pistons and the blower adapter. It does not look anything like the MT engine used in his 1961 dragster, so assume a build for a customer.
MT produced his own valley pan, finned valve cover, breathers, 4-71 blower adapter, 3-piece timing cover, and idler adjusting plate - all for the Tempest 4-cyl and each part had a "Thompson" logo. He also offered a street 3-71 blower kit for the Tempest.
Not saying this engine was not built by MT, or his services, but I would expect to see more "Thompson" products?
Name:	04 pontiac.jpg
Old 05-08-2021, 01:10 AM
mechanickeith's Avatar
mechanickeith mechanickeith is offline
The only thing I see thats MT is the water fill pipes on each end of the heads. Have never seen an intake like that. Even the timing cover is a stock Pontiac cover thats been cut down to remove all of the coolant passages.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 05-18-2021, 08:57 AM
Stuart's Avatar
There's a discussion over on the HAMB board about this engine, started by the guy who bought it. He said the seller told him it was last run in 1963 in a lakester at Bonneville named the Baby Whale, owned by Ron Benham. With Burke LeSage driving, it set a speed record of 213.747 mph on August 24, 1963. There are some additional engine pictures posted over there. https://www.jalopyjournal.com/forum/...lower.1229803/
Old 05-18-2021, 07:36 PM
Jeff Hamlin's Avatar
Oswalds FB page;
https://www.facebook.com/groups/4166...0000008851937/
Old 06-05-2021, 06:18 PM
jusjay's Avatar
jusjay jusjay is offline
Definitely not fritz no blow off plate. Mickey would never run a motor without the safety of having a blow off plate.
Old 06-05-2021, 07:12 PM
padgett's Avatar
padgett padgett is offline
And here I thought the Pontiac 4 cyl was a 194. (half a 389).
Web Site
Old 06-06-2021, 03:50 AM
Drag Star Le Mans's Avatar
It was 194ci but M/T stroked them up and down in cubic inches for different classes. I have many doubts about this engine. A Mickey Thompson engine would be dripping with M/T parts or specifically Thompson labeled parts from this era. This engine has a low performance 538177 heads. The short block has been modified to clear the aluminum rods which would be typical for a stroker M/T 4 banger? Sorry I sound like I'm busting b@lls but don't think the whole package is what it's is presented to be?
DragStarLeMans
Old 06-06-2021, 11:05 AM
Bill Hanlon's Avatar
No first hand knowledge here, but I remember reading in Hot Rod back in the early sixties Mickey was running not only against 1/4 mile records (NHRA), but
international records (FIA) that included standing kilometer (about .6 miles). FIA classes were based on liter engine sizes. 183 cubic inches is 3 liters, a likely class break. It was probably destroked.
http://wildaboutcarsonline.com/membe...ecords_1-4.pdf
Old 06-12-2021, 10:41 AM
Doug Doug is offline
Smile The "other" supercharger motor
Another Thompson project
Name:	tempest Scan 1.jpg
ID:	568080   Click image for larger version
Name:	tempest Scan 2.jpg
ID:	568081   Click image for larger version
Name:	tempest Scan3.jpg
ID:	568082   Click image for larger version
Name:	tempest Scan 4.jpg
Old 06-12-2021, 10:59 AM
Stuart's Avatar
Neat car, i hadn't seen that magazine article before.
Old 06-12-2021, 11:50 AM
Thumbs up
The article is an August-1961 CAR LIFE magazine item reprinted in this book that may have been published in mid-1980's
ID:	568087   Click image for larger version
Old 06-16-2021, 10:49 PM
TransaxleTempest62 TransaxleTempest62 is offline
Doug,
Is there anyway you can enlarge the specs on page 4? I remember reading that article years ago. I get a kick out of the speedometer error part.
Thanks!
Old 06-16-2021, 11:01 PM
RAIV55 RAIV55 is offline
Looks like just a bunch of pieces semi-bolted together.
Wonder what the purpose of the two speed Ford-o-matic? They weren't anything special although lighter than most cast iron trannys of the day.
Monty Frerichs
B&M Machine
Box Elder SD
Old 06-17-2021, 10:12 AM
misterp266's Avatar
Originally Posted by TransaxleTempest62 View Post
Doug,
Thanks!
Not really too clear.......
" Darksiders Rule "
Old 06-17-2021, 12:54 PM
A little better.
Old 06-17-2021, 10:35 PM
Thanks guys, some interesting data for sure. Some numbers are still hard to read but I was able to see a lot more of it.
