Hey everybody,
What are Reasonably priced fiz can options for 67 through 70 Pontiac metallic blue engine paint? Thanks, Craig |
Pontiac began using the silver blue metallic starting in 1966. I used Dupli-Color DE1616 on my car.
![]() 1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
The Following User Says Thank You to ZeGermanHam For This Useful Post: | ||
The Duplicolor DE1616 I've used in the past have all been too silver with too little blue. I have heard they changed the formulation for this and the DE1610 '59-'65 engine color.
I have had zero problems with Ames and Inline Tube versions of both colors. Problem is, they're double the cost of Duplicolor.
BONESTOCK GOATS '64 GTO Tripower Hardtop (Wife's Car) '64 GTO Tripower Post Coupe (My Car) '99 Bonneville SE Sedan |
Here's a '66 I restored that has, what I believe, to be the correct color.
That Duplicolor silver/blue conducts electricity really well.
Ask me how I know... |
Could be the picture but the DE 1616 color in post #2 is less silver-ish than the the factory color in post #4.
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
Ebay !!
I have always used Bill Hirsch. I brush instead of spray, one quart will do an engine. does not look as 'blue' as yours but could be lighting. I like it regardless.
birds, goats and a few outliers |
I get it right off the shelf at Napa and it matches, looks, perfect to me and everyone else that sees it.
Inline Tube has a special blend they had made up. They sell it to Butler and Ames and others it seems to be the most correct according to Butler Performance. I just used it on this engine. I have been unable to find the Dupli color paint in this color anywhere.
Tim Corcoran |
yepper DE1616
good choice! metallic blue is the only color that should be on a pontiac engine. Last edited by JUDGE3; 12-20-2023 at 10:54 AM. |
![]() Quote:
You bring up a good point. I bought a case of 6 Dupli-Color DE1616 cans from Amazon in May of last year for $42.35. Looking for them now, I can't find anything, anywhere. Not available on Amazon, eBay, or at O'Reilly... Wonder what's going on.
![]() 1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild Last edited by ZeGermanHam; 12-05-2022 at 11:55 AM. |
![]() Quote:
Yeah Will, that was then this is now and no one seems to have it. I think Dupli Color stopped making it but at least you can get the stuff that Inline Tube has.
Tim Corcoran |
As was mentioned, according to Butler, the Inline Tube color is what they think is best, and the Duplicolor is their second choice.
I went with the Bill Hirsch initially and I did not like it at all. The Duplicolor DE1616 looks much, much better to me. I got it from Summit a few weeks ago but it's not available now. Hirsch: ![]() DE1616: ![]()
Do you have a local Napa? Ours carries that Pontiac duplicolor on the shelf.
Just called my local Napa - 3 cans of 1616 on the shelf but none available for order. Interesting thing is the system defaults to the 1610 sky blue
Been using it on all my OHC builds for years and it lays out really nicely and holds up well.
Even when I spray parts separately and sometimes from different lots it always matches up really well. I still have some PK 227 and it always looked too green to me. ![]()
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. ![]() |
The Following User Says Thank You to Jeff Hamlin For This Useful Post: | ||
Thanks Guys,
I ordered the DE1616 from NAPA - I hope they can get it. I will let you know. Take care, Craig |
I have one can of Valspar Plasti-Coat in the silver blue high temp. Can says OER and cap color is blue I wanted for my 72. One spray and I knew what the cap color looked like wasn't what came out. I took the second can back to the parts house and got a different brand that was what I needed. So, this can I would sell cheap.
