66 421 tri power, can,t get the idle down screw all the way out, spring in last hole
Cannot get idle down on the goat, idle screw backed out all the way, return spring in last hole, what's the solution
First thing I would try would be to disconnect the front-to-rear linkage rod; then check to see if both front and rear carbs are sealing.
Jon
"Good carburetion is fuelish hot air". ![]() "The most expensive carburetor is the wrong one given to you by your neighbor". If you truly believe that "one size fits all" try walking a mile in your spouse's shoes! Owner of The Carburetor Shop, LLC (of Missouri). Current caretaker of the remains of Stromberg Caburetor, and custodian of the existing Carter and Kingston carburetor drawings. |
![]() Quote:
If it's new, have you changed anything on the carburetors or links? |
Vacuum leaking , throttleplate / gasket area cho
ke fast idle cam hanging Last edited by chrisp; 05-20-2023 at 07:45 AM. Reason: add |
