Old 09-29-2023, 11:15 AM
tekuhn tekuhn is offline
Default Emissions Decal Codes - Ram Air V ?
Hello,
Does anyone have an understanding of the 2-letter codes on the emission decals? Looking at the various reproduction decals, I see several different codes:
1970 RAM Air IV - PE
1970 Standard 4 bbl engine - PB
1971 455 HO - PN
1970 Firebird 400-4bbl - PC
Etc....
Does anyone happen to know if a code was ever assigned to the RAV ?
Hoping to finish a project while I'm still able to push the clutch in....
1963 Tempest Convertible (195-1bbl, 3-speed transaxle. 428 RAIV, 5-speed, IRS planned) Pictures
Old 09-29-2023, 11:25 AM
Held for Ransom's Avatar
Because the RA V was a crate engine and not factory installed, there is no emissions decal.
So long, farewell.
Old 09-29-2023, 11:29 AM
I understand that, but there is quite a bit of documentation that was created when they were gearing up for production. I'm wondering if that 2-digit code was created prior for some other purpose and might exist?
Old 09-29-2023, 07:54 PM
Gordon Church Gordon Church is offline
PC .....GTO RAIII
Old 09-30-2023, 08:22 AM
Keith Seymore's Avatar
Originally Posted by tekuhn View Post
Hello,
1971 455 HO - PN
Etc....
An explanation I wrote for a Chevy truck website:
Further detail: let's say you order a 350 cu in engine. There is one base part for a 350, but it proliferates on Auto vs manual trans, a/c vs no a/c and California emissions vs Federal.
So there would be eight part numbers within that one engine family (there would probably be this many variations for v6, for 305 cu in, for 454 cu in and diesel as well):
12345678 350 cu in manual no a/c Fed
12345679 350 cu in manual w a/c Fed
12345680 350 cu in auto no a/c Fed
12345681 350 cu in auto a/c Fed
12345682 350 cu in manual no a/c Calif
12345683 350 cu in manual a/c Calif
12345684 350 cu in auto no a/c Calif
12345685 350 cu in auto a/c Calif
An assembly plant broadcast code would be assigned to each part number:
TAA 12345678 350 cu in manual no a/c Fed
TAB 12345679 350 cu in manual w a/c Fed
TAC 12345680 350 cu in auto no a/c Fed
TAD 12345681 350 cu in auto a/c Fed
TAE 12345682 350 cu in manual no a/c Calif
TAF 12345683 350 cu in manual a/c Calif
TAG 12345684 350 cu in auto no a/c Calif
TAH 12345685 350 cu in auto a/c Calif
So the operator goes over to a bay that is full of racks and racks of engines (probably more than you've ever seen in one place in your entire life). You can tell him which one to choose, via the build manifest, and he can remember that he needs an "AF", instead of trying to remember 123455683, or manual/AC/California emissions, since he will do this nearly 500 times in one day.
In summary - there is a broadcast code that corresponds with each individual part number. And there is massive proliferation based on a number of factors.
So if RA V was offered, say, in both stick and automatic, there would be at least two part numbers and therefore two codes at a minimum (had they been created).
K
'63 LeMans Convertible
'63 Grand Prix
Old 09-30-2023, 04:13 PM
Kenth's Avatar
Kenth Kenth is online now
Originally Posted by Gordon Church View Post
PC .....GTO RAIII
Source on that?
My 1970 TheJudge RAIII has the PB decal according to the build sheet.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 09-30-2023, 05:56 PM
This is in my 1970 Firebird Assembly Manual (applies to A-body also)
Feb 1970 dated on sheet
Old 10-01-2023, 02:37 PM
Kenth's Avatar
1970 GTO assembly manual got the same info, still:
Name:	Judge build sheet.jpg
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 10-01-2023, 03:17 PM
Kenth, looking at a bunch of buildsheets, it looks like they probably added a code which moved the letters down?
Looks like after the beginning of the year or even around when my assembly book was dated (Feb 1970) it shows PC for 400 4 bbl. I have some with RA IV which took a different code also, having PE after Jan 1970 and PD before then.
I'm not sure if I have any Craftsman Service News on this change, but then I never looked for it.
Old 10-01-2023, 07:55 PM
Early 1970 Pontiac had...
PA 8 cyl 2 bbl
PB 8 cyl 4 bbl
PC 455
PD RA IV
Later 1970 Pontiac had...
PA 350 2 bbl
PB 400 2 bbl
PC 400 4 bbl
PD 455 4 bbl
PE 400 RA IV & SD
Now, if SD meant RA V, then PE was the decal.
So long, farewell.
The Following 3 Users Say Thank You to Held for Ransom For This Useful Post:
Old 10-07-2023, 01:34 PM
Thank you all for the responses - I wasn't getting notifications and had no idea there was this much discussion. This is what I needed.
