Hello,
Does anyone have an understanding of the 2-letter codes on the emission decals? Looking at the various reproduction decals, I see several different codes: 1970 RAM Air IV - PE 1970 Standard 4 bbl engine - PB 1971 455 HO - PN 1970 Firebird 400-4bbl - PC Etc.... Does anyone happen to know if a code was ever assigned to the RAV ?
Hoping to finish a project while I'm still able to push the clutch in.... ![]() 1963 Tempest Convertible (195-1bbl, 3-speed transaxle. 428 RAIV, 5-speed, IRS planned) Pictures |
Because the RA V was a crate engine and not factory installed, there is no emissions decal.
So long, farewell. |
The Following User Says Thank You to Held for Ransom For This Useful Post: | ||
I understand that, but there is quite a bit of documentation that was created when they were gearing up for production. I'm wondering if that 2-digit code was created prior for some other purpose and might exist?
PC .....GTO RAIII
![]() Quote:
So if RA V was offered, say, in both stick and automatic, there would be at least two part numbers and therefore two codes at a minimum (had they been created). K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
Source on that?
My 1970 TheJudge RAIII has the PB decal according to the build sheet. |
This is in my 1970 Firebird Assembly Manual (applies to A-body also)
Feb 1970 dated on sheet ![]()
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." – Socrates Last edited by johnta1; 09-30-2023 at 06:04 PM. |
1970 GTO assembly manual got the same info, still:
Kenth, looking at a bunch of buildsheets, it looks like they probably added a code which moved the letters down?
Looks like after the beginning of the year or even around when my assembly book was dated (Feb 1970) it shows PC for 400 4 bbl. I have some with RA IV which took a different code also, having PE after Jan 1970 and PD before then. I'm not sure if I have any Craftsman Service News on this change, but then I never looked for it. ![]()
Early 1970 Pontiac had...
PA 8 cyl 2 bbl PB 8 cyl 4 bbl PC 455 PD RA IV Later 1970 Pontiac had... PA 350 2 bbl PB 400 2 bbl PC 400 4 bbl PD 455 4 bbl PE 400 RA IV & SD Now, if SD meant RA V, then PE was the decal.
The Following 3 Users Say Thank You to Held for Ransom For This Useful Post: | ||
Thank you all for the responses - I wasn't getting notifications and had no idea there was this much discussion. This is what I needed.
