Old 12-22-2023, 09:22 PM
Tim Corcoran's Avatar
Default Motor Mounts
Besides going to a solid motor mount or strapping down the motor is there a motor mount made that won't separate with 400 plus HP?
Tim Corcoran
Old 12-22-2023, 11:04 PM
64speed's Avatar
64speed 64speed is offline
AMES has a new lifetime warranty set that are really nice
Old 12-23-2023, 10:22 AM
78w72 78w72 is offline
If you are using the older "rubber block" mounts they sell whats called a mity mount for ~$100+, its basically a stock mount with a bolt through the center... or do what I did and make your own for the price of a grade 8 bolt an an hours worth of time drilling and tapping the mount. Has help up with 500+hp & lots of low 11sec runs... I did install a limiter chain just in case the mount breaks but after about 7 years with lots of street use its doing fine. I have a 2nd gen Fbody but they sell the mounts for other cars too, think there was a write up on making a stronger Abody mount too.
Old 12-23-2023, 11:02 AM
64speed's Avatar
The new AMES one is not a mighty mount. Call them and ask about them, they sell basic, mighty mount, and then the lifetime warranty ones
Old 12-23-2023, 11:51 AM
grivera's Avatar
grivera grivera is online now
https://butlerperformance.com/i-2445...ngine%2Bmounts
https://polybushings.com/pages/2255-6.html
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
The Following User Says Thank You to grivera For This Useful Post:
Old 12-23-2023, 01:27 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
I`m using those now at 600`ish hp. Holding up so far. Used to run solids but figured i`d take some "stress" off the block.
The Following 2 Users Say Thank You to PunchT37 For This Useful Post:
Old 12-23-2023, 02:29 PM
jhein's Avatar
jhein jhein is offline
I'm using these from Butler at around 500 hp and so far so good. They are really stiff. Functions almost more like a solid mount I think but doesn't feel rough or harsh driving it.
https://butlerperformance.com/i-3164...tegory:1393551
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
Old 12-23-2023, 05:14 PM
ta man ta man is offline
I've used stock replacements..no issues and I have a few passes on them.
Old 12-23-2023, 05:18 PM
Picture from track
Old 12-23-2023, 06:10 PM
The new ones listed in the Ames catalog are called 'Torq Lok' mounts. The description states it's the highest HP mount on the market aside from solid mounts.
I would have gotten a set if I had noticed they were available when I purchased my mity mounts.
Old 12-23-2023, 06:13 PM
All the poly ones get eaten up by heat and crumble if you run headers.
Old 12-23-2023, 06:34 PM
Thanks for the replies, I am aware of the Butler poly mounts but they are heat sensitive and with my RA/HO manifolds don't think they would work. I may try the Ames life time warranty mounts. Wanted to see what was available as new stuff comes out from time to time.
Tim Corcoran
Old 12-23-2023, 11:39 PM
64speed's Avatar
I was told no polyurethane with headers also.
Old 12-24-2023, 12:17 AM
grivera's Avatar
I’ve had the poly mounts on my 69 bird with long branch manifolds for several years and no issues.
Will Rivera
Old 12-24-2023, 01:41 AM
locomotivebreath's Avatar
locomotivebreath locomotivebreath is offline
I have the butlers on my GTO with RA manifolds - 500 miles and no issues .
When I wore a younger man's clothes
Old 12-24-2023, 10:35 AM
jhein's Avatar
Butler has a warning about using them with headers.
"If using headers, ceramic coated headers are highly recommended AND/OR a heat shield or header wrap to keep heat away from the Poly mounts as excessive heat may cause the poly to melt or deteriorate."
I have about 1700 miles with RA manifolds and no problems.
Old 12-24-2023, 11:41 AM
PunchT37's Avatar
Yeah, I saw that warning too.
Mine have been on the car for a few years now with 1 7/8 headers. One of the tubes is 1/8 inch, at best, from the metal mount frame on the pass side.
I have at least a few thousand miles on this thing. It`s not a daily driver but I do use it as much as I can. And it gets used in the hot ambient temps we usually have down here.
I look at em at oil changes since my a$$ tightened up after seeing the warning. So far, I see nothing. No bulging, cracking, etc.
The Following User Says Thank You to PunchT37 For This Useful Post:
Old 12-24-2023, 11:48 AM
jhein's Avatar
The design of the Butler mount gives more clearance than more traditional style mounts. With RA manifolds it's pretty good. Obviously with headers it's a different story. Also with bigger/bulkier style poly mounts may even be an issue with manifolds.
Old 12-24-2023, 11:51 AM
PunchT37's Avatar
Never saw a mount like that. Where did you get that?
Old 12-24-2023, 11:55 AM
jhein's Avatar
Butler sells them. No idea who makes them.
