Old 12-27-2023, 12:18 AM
boardog boardog is offline
Default Assembly plant question
My gto was sold new at Lou meliska pontiac in Parma Ohio but was assembled in Canada. Did all gto's sold in Ohio get built in Canada?
ID:	625619   Click image for larger version
Old 12-27-2023, 12:24 AM
Rest of the phs
Old 12-27-2023, 07:33 AM
johnta1 johnta1 is online now
No.
The Pontiac distributed orders to differing plants to keep the load balance equal. (so one plant wouldn't get overloaded with work)
Old 12-27-2023, 09:23 AM
mrennie's Avatar
mrennie mrennie is offline
Would be nice if that Canada specific door label was reproduced. Thanks for sharing!
Michael
1970 Oshawa built 1 option Judge. 24 year restoration/upgrade project finally finished!
1979 Trans Am - low-buck drag car project for when I retire
Old 12-27-2023, 10:41 AM
Boardog do you also have the Canada report for your car? (like PHS but sometimes has more data)
Old 12-27-2023, 02:28 PM
comanchefirebird comanchefirebird is offline
Here is the link to the website for obtaining Canadian documentation
https://www.vintagevehicleservices.com/
The Following User Says Thank You to comanchefirebird For This Useful Post:
Old 12-27-2023, 07:40 PM
i have requested the form to fill out in order to get the Canadian documentation.
Old 12-30-2023, 10:10 AM
scott70's Avatar
scott70 scott70 is offline
Built in Oshawa. My gto was also....made in Canada for the US market. Mine was sent to maine and is also a 455 ho 4 speed car....a short description in my sig.
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
Old 12-30-2023, 10:51 AM
Keith Seymore's Avatar
My Chevelle was built in Oshawa for US consumption (point of sale = Flint, Michigan).
Dad ordered the car for my mom to drive.
K
'63 LeMans Convertible
'63 Grand Prix
Old 12-30-2023, 10:53 AM
No.
This is correct.
Final assembly location was allocated roughly by geometry, but then tempered based on work load balance - or - if you had some unique option content that only one of the plants was building.
For example, if you ordered dual rear wheels then your order would have to be deflected to Janesville.
K
'63 Grand Prix
Old 12-30-2023, 10:54 AM
Pontiac Michigan is closer to Ohio than Canada is (and a higher volume producer, too).
I bet most of the GTOs in Ohio came from the home plant.
K
'63 Grand Prix
Old 12-30-2023, 01:24 PM
Rest of the phs
The interior dome light with spotlights is an option I rarely see on 70-72 GTO invoices.
Upgraded axle ratio on the 70 455HO cars is also not seen often.
Really cool car you have in TripleBlack.
Not implying that those had anything to do with the Canada build.
The Oshawa cars have unique cowl tags and coding too.
Your cowl tag should show codes D55 for console bracket , M21 for trans hole in floor , and likely a code for the vinyl top trim , and possibly another code for the dome/reading light bracket.
Anything that required a modification to a general basic body shell got coded.
Can you post a picture of your cowl tag ?
If its not too much trouble
Old 12-30-2023, 05:40 PM
scott70's Avatar
I did get a reproduction door tag from a member here,,,don't know if he's around anymore. I did some research about Canada cars built for the US and was told those particular cars did say made in Canada like the OP door pic. He did offer a Canada version so that's the one I chose.
Old 12-30-2023, 05:44 PM
Default Trim tag
Here is the trim tag
The Following User Says Thank You to boardog For This Useful Post:
Old 12-30-2023, 08:46 PM
Thanks boardog .
C08 is for the provisions of the vinyl top moldings.
Been a while since I have taken out one of those reading dome lamps from a car.
Sort of thinking now they had an adapter plate that screwed into the normal mount of a regular dome light.
My 70 GTO 455 RA has that option.
Used to find them in later 70's TA's mostly.
Old 12-31-2023, 12:21 AM
Jack Peters's Avatar
My 71 T-37 was built in Fremont. Ordered through a dealer in Kodiak, AK, sent to Portland, OR then shipped to Renton, WA and delivered to a parking lot at tha Sea-Tac airport where I picked it up, put the plates on it and drove it about 100 miles to my parents house.
JLP
Old 01-02-2024, 01:23 PM
Gordon Church Gordon Church is offline
try inline tube....... INL15411
The Following User Says Thank You to Gordon Church For This Useful Post:
Old 01-02-2024, 01:58 PM
mrennie's Avatar
You are awesome, thanks for the info!!
Michael
Old 01-02-2024, 06:03 PM
Reading lamp equipped dome light became a Pontiac option for the 70 model year but had surfaced earlier on other divisions. No need for an adaptor plate, the two screws that hold it to the roof have identical locations.
Btw, 70 and 73 were the only years that had Canadian production of the GTO and it was only for two door hardtops (not convertibles) and if I'm not mistaken no RA IV's. I've noticed a few distinctive things on Oshawa built GTO's like the lack of sealer on the lower door seams and a red goop used to hold the trunk mat.
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
Old 01-02-2024, 06:18 PM
trishieldchief's Avatar
North ,do you know how many 1973 GTO's were built in Oshawa?
Rich Johns
www.purestockauto.com
1970 GSX Stage 1 Auto 3.64 # 603 of 678 12.44@109.73 mph 2011 Buick GS Nats Pure Stock, 12.71@110.64 mph PSMCDR 2011
1970 GS Stage 1 Convertible Auto 3:64 12.71@109.15 mph PSMCDR 2009
1970 GS 455 M21 4 Speed 3.42
1987 GN Astro Roof
