#341
Played around with the steels in direct and forward drums for my TH400 to get the clearances set at .040. Disassembled my Q-jet to get the castings, linkages and other steel parts plated.
The Following 2 Users Say Thank You to 65 Lamnas For This Useful Post: | ||
#342
I know you've seen a lot of these cars, and have a pretty impressive stable yourself, so I greatly appreciate the complement!
Ken '68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '95 Comp T/A #6 M6 - bone stock (pics) |
The Following User Says Thank You to Verdoro 68 For This Useful Post: | ||
#343
Had a very intermittent coolant leak (like, would occur literally months apart) that dripped behind the passenger tire under the fender only after I would turn the car off. Had the same leak last year that spurred a heater core R&R along with all heater hoses and clamps.
Same leak happened again a couple weeks ago, and my heart sunk wondering if my new heater core failed. Would've been super pissed, since the inlet line is double restricted to prevent water slugging, and I splurged and got the higher quality copper/brass unit. Thankfully, I was able to trace the leak to the inlet heater hose connection. When I did the R&R, I used one of the repro Wittek tower clamps - don't use these, at least for the 5/8" heater hose connection. The radius of the tower end of the clamp is too bulky compared to the actual strap, and so the strap ovals out the house and doesn't seal well. It even slightly caved in the copper tube where the tower part sat (luckily the fitting bead was still round). In hindsight, the same leak from last year might've just been the heater hose the whole time, since it was the original hose, and not the heater core. And so I tried out, as recommended on this forum, a Gates PowerGrip heatshrink clamp (specifically the 32925# one), and admittedly smeared a thin glaze of Waterpump and Thermostat Housing RTV on the fitting to aid in the seal as well as provide lubrication to put the new hose on. Was able to position the PowerGrip clamp perfectly per the instructions, used my heat gun, and it resulted in a great seal which after two tests of running the system up to temp under pressure and then shutting the car down, didn't leak a drop and is bone dry. So far I'm a believer in these PowerGrip clamps. Could've probably gotten a proper seal using an old-fashioned worm gear clamp like what the factory used (which I recently found out is how W72 cars actually came from the factory: the engine side of the heater hoses used the Wittek clamps, while the heater core connections actually used worm gear clamps) as well, but I wanted to try out these PowerGrip clamps since they are variable tension in response to thermal expansion/contraction, and I don't plan on removing this hose any time soon since it's a bear to get to in that I have to remove the inner fender liner. So to nutshell, don't use Wittek tower clamps for the 5/8" heater hose connection, at the very least not flimsy repro ones, and the PowerGrip clamps really are amazing!
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop ![]() |
#344
The Wittek tower clamps are pretty finicky. I do a little prep to them before I install and I'm super careful when I clamp them down usually using vice grips to keep them straight. Even then I always have extra because some just don't hold. Hadn't heard of the PowerGrip clamps. They look pretty easy!
#345
I put Holley Retro bright headlights in my 73 Formula and 69 GTO. They are spendy at $200 each but well worth it in you night drive your old Pontiac. Before and after of the Formula.
DragStarLeMans |
The Following 3 Users Say Thank You to Drag Star Le Mans For This Useful Post: | ||
#346
Are you using factory wiring or do you have relays?
#347
Removed LH exhaust manifold to access mini starter. Connected battery cables and tested rotation. Plan to compare compression pressure of each cylinder. If good, will replace worn cam and HFT lifters and move on. If bad, will consider rebuild of numbers matching spare '64 engine.
#348
Simple plug and play.
DragStarLeMans |
The Following User Says Thank You to Drag Star Le Mans For This Useful Post: | ||
#349
Cleaned up the G8 with a clay bar. Didn't find any new chips or scratches so that made me feel pretty good.
1969 Firebird 350 convertible, t-5, Carousel Red 2008 Solstice GXP 5speed manual, Sly 2008 Grand Prix, Ink Slate, Winter daily driver 2009 G8, Switchblade Silver, summer daily driver |
#350
Picked up the new motor for the Formula 😀
74 Formula Below motor destroyed last fall 469, 6X-4's, 72 Intake, Ramair Manifolds. 3 inch exhaust with x-pipe Custom Roller Cam, 1.52 Roller Rockers Quadrajet done by Cliff 3:42 gears 12.061 @ 110.74 12.092 @ 112.43 12.128 @ 111.71 New motor 461 stroker Edelbrock 87 cc dport heads Performer RPM Same Ram Air manifolds, and quadrajet Results will be posted after the track |
#351
![]() 71' GTO -original 400/4-speed/3.23 posi 13.95 @ 102.1 on street tires @ 4055lbs. ‘63 LeMans- ‘69 400 w/ original transaxle. 2.69 gears. |
#352
Let's see. First, I took my boat to a local shop to have some small holes in the aluminum hull welded, then I moved the GTO from my shop up to my garage so I could put my 50 Streamliner in the shop to put the intake/ exhaust manifolds and cooling system back in it.
The pollen is terrible right now, so I won't be taking the Goat out for a couple weeks to a month, if then. I had to move the boat to get to the 50.
#353
400 block 30 over with a Stroker kit to make it a 461
E-heads 87 D port Rpm intake Roller cam
The Following 3 Users Say Thank You to form74 For This Useful Post: | ||
#354
Ah, the 11’s are calling!
The Following User Says Thank You to 67drake For This Useful Post: | ||
#355
![]() Quote:
#356
Picked up my glide.
The Following User Says Thank You to triathlonx13 For This Useful Post: | ||
#357
Pulled a oil sample from the new engine.Will start taking it off the run stand tomorrow.Tom
The Following User Says Thank You to tom s For This Useful Post: | ||
#358
Still on the TH400. Got the case saver installed but f**ked up the intermediate pressure plate, and had to get another one. Painted the pump red for an additional 10HP. Looks like there was a rear thrust issue
The Following User Says Thank You to 65 Lamnas For This Useful Post: | ||
#359
a friend of mine made me some custom inserts for my Rally 2s (for my 58 wagon project)
I may add some clear epoxy resin to coat them with for a smooth glossy finish |
#360
Scored a decent set of Cal Custom VCs that will polish up nicely....IMO the best-looking retro valve covers.
The same guy has a couple of OEM aluminum intakes (one NOS)and a couple sets of 7F6 heads for sale...He's advertising on FB under Pontiac Pickers Classified group, if anyone is interested...his name is Marty and in St. Louis area |
