Old 04-12-2024, 02:37 PM
JBanna's Avatar
JBanna JBanna is offline
Default High Torque Starters
It's time I replace my OEM starter with a high torque mini for my 455 with headers - any specific recommendations? Thanks!
78 White T/A, Carmine interior, Fisher T-tops, WS-6 package, 3.08 gears, a/c, rear discs. Original 403 with 300,000 miles replaced by new Pontiac 455 (roller everything, 6x-4 heads, Performer manifold, Hooker Headers, Hughes converter, Cliff's Q-jet) - I only get 12 mpg!
Old 04-12-2024, 02:51 PM
ZeGermanHam's Avatar
My brother and I have both been very happy with the Powermaster 9510XS in our GTOs. Works great, highly reputable U.S. company, and all kinds of room with headers, etc.
https://www.summitracing.com/parts/pwm-9510
1998 BMW 328is (track rat)
The Following User Says Thank You to ZeGermanHam For This Useful Post:
Old 04-12-2024, 03:42 PM
65 Lamnas's Avatar
https://www.robbmcperformance.com/pr...c_starter.html
Old 04-12-2024, 04:12 PM
78w72 78w72 is offline
I use a summit mini starter on a 10.75:1 stroker with big 2" super comp headers, its been in use for 10+ years and starts the engine great in hot or cold temps, street or track. Im pretty sure its just a reboxed powermaster for a better price.
The Following 2 Users Say Thank You to 78w72 For This Useful Post:
Old 04-12-2024, 04:42 PM
tom s tom s is offline
IMI!Tom
Old 04-12-2024, 05:52 PM
R 70 Judge's Avatar
Another vote of the Powermaster XS 9510. 1970 TA with Highports and 2" Hooker headers and it fits great!
James
1970 Trans Am
Spotts Built 484" IA2, Highports, EFI Northwind
Terminator X sequential EFI fabrication and suspension by
Old 04-12-2024, 06:14 PM
jhein's Avatar
jhein jhein is offline
PM 9510 here also. Works great. No headers. It has 360 deg, "infinite" clocking which I would think should help a lot with headers. RobbMc also has infinite clocking.
The Following User Says Thank You to jhein For This Useful Post:
Old 04-12-2024, 10:14 PM
65madgoat's Avatar
IMI!Tom
Another vote for IMI
The Following User Says Thank You to 65madgoat For This Useful Post:
Old 04-12-2024, 10:38 PM
hojs69's Avatar
hojs69 hojs69 is offline
Location: Pacific NW by way of Detroit, Tampa, San Diego
IMI x 3
79 Trans Am WS6
71 Formula
72 Formula
71 Firebird
69 Firebird
The Following User Says Thank You to hojs69 For This Useful Post:
Old 04-12-2024, 11:16 PM
GtoFM's Avatar
GtoFM GtoFM is offline
I bought the MSD mini when it went on clearance. It works great but only 2 clocking positions! The solenoid is to close, for my comfort, to the RA exhaust manifold. Research any of the above keeping 360* clocking in mind.
The Following User Says Thank You to GtoFM For This Useful Post:
Old 04-12-2024, 11:56 PM
JBanna's Avatar
All that's great advice - I did check O'Reilly's close to my house and they have the Powermaster brand in stock, and really talked it up, especially for reliability and clocking positions; I'll look at the details and decide which way to go after I repair the burnt wires under my dash - that nightmare is in the electrical forum!
Old 04-13-2024, 02:04 AM
64speed's Avatar
64speed 64speed is offline
RobbMC has the nose cone option. It is the only mini starter I know of with one
Old 04-13-2024, 02:27 AM
lust4speed's Avatar
IMI
Tops in customer service also.
Mick Batson
1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon.
The Following User Says Thank You to lust4speed For This Useful Post:
Old 04-13-2024, 04:43 AM
indymanjoe's Avatar
10? years with this one on my 469 and no issues at all.
https://www.summitracing.com/search/...g&fr=part-type
The Following 3 Users Say Thank You to indymanjoe For This Useful Post:
Old 04-13-2024, 06:42 AM
etennett etennett is offline
Curios why you need to replace your original starter? I had my rebuilt along with the starter solenoid
eric
Old 04-13-2024, 06:57 AM
triathlonx13's Avatar
Powermaster
Old 04-13-2024, 09:35 AM
roy381 roy381 is offline
67 GTO 461 with Dougs headers Powermaster 9510
Old 04-13-2024, 09:53 AM
That is correct, and I always recommend the nose support.
While I've had a couple issues with Robb's starter, things like the ball bearing falling out and causing the gear to slide on the shaft, I've always thought there has to be a better retention method for that gear, but Robb has always been great to deal with, with fast turnaround, honest and up front. No reason I wouldn't buy more starters from him. They also clock in any position. Dad has been running one on his 571 for the last decade or so, does a great job spinning that engine over.
My vote is for RobbMC with the nose cone support.
Just a quick story on those other china starters without a nose support. They retain the gear with a snap ring. Eventually that snap ring fails and the gear shoots off like a bullet. Good luck finding it. Happened to dad and luckily he was parked on the grass, which slowed down the gear when it flew off and he was able to find it, slide it back on and start the car one more time to get home. There are a lot of reasons why you should have a nose support and some of them are obvious, but one thing I never counted on was without the nose support there is nothing to keep the gear from falling completely off and never finding it, or becoming a projectile for anyone standing nearby.
Fast forward to the RobbMC starter with nose support. Gear came loose but the nose support wouldn't let the gear shoot out from under the car. Bottom line is the car would still start no matter what, just that sometimes the gear would get hung up on the flexplate and you would have to shut it off and start it again until that gear finally bounced back into it's resting position. Moral of the story is it won't leave you stranded if the gear comes loose. Turned out to be a simple fix and Robb turned it around in a couple days. Knock on wood dad hasn't had that issue for a few years now but it's just one of those funny stories not often posted around here.
https://youtu.be/XqEydRRRwqE
Old 04-13-2024, 10:48 AM
I've had good luck over the years with my Tilton on my 78 for 30 years! Replaced it once then put a new solenoid on that one for a back up.. I did reclock it myself drilled and topped the mounting block hole. The MSD(that was on December sale!) looks similar and already has the ability to reclock but it hits the lip on the oil pan.
RobbMc is on the IA car. First one had an issue with s spring clip on the gear shaft they fixed . New ones have a different design. Old one back up now.
Old 04-14-2024, 07:44 AM
Elarson's Avatar
Elarson Elarson is offline
I have the RobbMc with nose support on the road race engine. The infinite clocking was a problem solver for clearing the Canton T-pan (that sticks out a couple inches). It's got enough power to start the engine with 36 deg locked timing and an ordinary 12 volt battery.
Eric
The Following User Says Thank You to Elarson For This Useful Post:
