Old 04-27-2024, 02:32 PM
TA63 TA63 is offline
Default 77 grand prix electric fans
So I'm working on a 77 grand prix. Built her a pretty stout 400 making about 375 hp. The fan shroud extension is busted up pretty bad as you can see by the Pic. Is this extension or a complete fan shroud available anywhere? I've also considered electric fans. The radiateo measures 28 x 18. Any recommendations? It's a non AC car
Old 04-27-2024, 08:57 PM
gtokid1968's Avatar
gtokid1968 gtokid1968 is offline
I think you could use sheet metal rivet it on and paint it black.
Or cut up another shroud and rivit it together.
My buddy has a 77 GP with a 461 alumheads with stock cluch fan and shroud and it runs 180 all the time.
Old 04-29-2024, 01:28 AM
This is the route I'm tentatively planning on taking. Was hoping this car shared shrouds with an older car and it was reproduced in some form though. Electric will be a last ditch choice.
Old 04-29-2024, 03:12 AM
Tim Corcoran's Avatar
I don't see a reason to go to the trouble and expense of installing electric fan(s) on your car. The factory shrouds and clutch fan should do an excellent job of cooling a 400 cubic inch motor. If your having cooling issues it's a symptom of another issue and installing electric fans would be a band-aid for another problem.
Tim Corcoran
The Following User Says Thank You to Tim Corcoran For This Useful Post:
Old 05-01-2024, 11:53 PM
Yeah I don't want to go electric, just an option I was considering if I was unable to find a replacement or repair my existing shroud to insure proper cooling. I actually almost have it done, and i used a piece of fascia tin. I'll post a Pic tomorrow.
