KYB's with OEM replacement Delco springs and 1-1/4" Addco sway bars. I am a fan of the compliant pring/shock, stiff sway bar school of thought. Complaint ride and good handling that becomes tighter when cornered hard.
Triple Black 1971 GTO |
HO Racing Front and Rear bars. Also have the Tom Lee Power Steering Box. 1964 A-Body vehicle. Most likely there are other parts out there that might be slightly better but the parts I have (above) have done the job for many years. Tom V.
The Following User Says Thank You to Tom Vaught For This Useful Post: | ||
The usual problem with jacking-up the back end of an A-body for tire clearance is that it makes the suspension subject to wheel-hop on acceleration. Quote:
The low-budget version would be to scavenge a front bar from a Treasure Yard Trans-Am from the '70s or early '80s, and a rear bar from any mid-'60s, early '70s A-body or B-body. The newer body style A- and B-bodies used different rear suspension, those bars don't work for the earlier chassis. Quote:
I saw a thread in the last couple of weeks where someone had a stock style bar on a vehicle with a 9" axle, clearance was slight, but it did work. EDIT: This thread: https://forums.maxperformanceinc.com...d.php?t=864524 Last edited by Schurkey; 02-27-2023 at 04:42 PM. |
The Following 3 Users Say Thank You to Schurkey For This Useful Post: | ||
FWIW After talking with another GTO guy, he recommended Spohn Performance to me as well as UMI. Both are in PA and Spohn manufactures their stuff in the USA.
I used their 926A sway bars with their 221 rear lower control arms. Installed well with no problems and made a real difference in the handling of my A body (GTO). They were helpful to me with some advice when needed. I like Shurkey's advice on the wrecking yards but here in the upstate there is so much growth we've lost all of our yards that had older cars (pre-2000) to vast housing tracts. That's why I went with Spohn as "treasure yards" have disappeared within reasonablr distance. https://www.spohn.net/shop/1964-1967-GM-A-Body/
"No replacement for displacement!" GTOAA--https://www.gtoaa.org/ |
The Following User Says Thank You to 1968GTO421 For This Useful Post: | ||
68GTO, Thanks, I was looking at UMI. The Spohn is a bigger front bar for the same price! Seems like a win to me.
The axle housing needs new bushings. Should I use poly or rubber for a good handling street car? My current boxed lowers have poly bushings. My uppers are adjustable spherical, forget the brand. If I was going with the KYB shocks in the rear, should I use KYB or Koni adjustable in the front? The front has a drag spring that stores energy and comp engineering 3-way drag shocks. It really wants to hike up on a hard launch.
There's no point in putting different (street) shocks on drag springs.
The Following User Says Thank You to Schurkey For This Useful Post: | ||
Here's a pic of the front suspension at ride height and a pic of how the car sits. Does this tell anything about the type of spring or how its set up? I can change the springs later when I do the engine swap. Dont shoot the messenger, I didnt set this car up.
What can I do to make this more street friendly?
I could explain all this to the girl at the parts store, but she'd probably call the asylum. White '67 LeMans 407/TH350/Ford 3.89... RIP Red '67 LeMans. 407/TH400/Ford 3.25 Last edited by chiphead; 03-01-2023 at 08:51 AM. |
first thing to get the car to handle better on the street if to get rid of those drag shocks, they dont control the ride on the street very well compared to OEM or lowering type springs, get a stock replacement if you like that ride height or buy a more performance type lowered stiffer spring, then pick the shocks you like & can afford. for a street cruiser normal OEM shocks like KYB or other brands mentioned will be fine on a good OEM spring. if you want better handling performance get a lowered stiffer spring and some konis or billsteins... but get rid of the drag springs and shocks if the car will only be street driven. |
Beyond that, previous posts have discussed heaps of additional parts that would be an improvement over stock. Are we sure the front suspension is not just plain worn-out? Limp rag-joints are epidemic. The OEM steering boxes were a mess when they were new--slow ratio, weak torsion bar. Really tragic, because the engineering of the box is marvelous, but the parts selection was a complete disaster. Parts exist to correct that...but GM didn't use them at that time. Loose wheel bearings, ball joints, tie rod ends, idler arm, etc.? |
You're right. All of that could be suspect. But Rome wasn't built in a day. I just need something to get me by until I pull it all apart and fix it the right way. Shocks and sway bars are easy to do. A full front end tear down is a bigger deal. I'm already swapping in that Ford 9-in that's a big enough project by itself.
I got a Bel air been blown apart for years and I need to get it done. If I've learned anything it's only blow one car apart at a time
The Following User Says Thank You to chiphead For This Useful Post: | ||
Heavier sway bars, make sure the bushings are all in good shape, ball joints, and steering linkage linkage tight. A set of quality gas conventional shocks, springs that are not sagged, or dropped. The steering box needs to be tight as far as backlash. Hopefully the car has power steering, as the manual box is really slow lock to lock. Putting a better/quicker box in helps, but isn't necessary.
Top that off with an alignment that puts at least one degree of positive caster, (more if you can get more with stock parts) sometimes you can get 3 degrees with stock parts. 1/2 a degree of negative camber, 1/8th inch of toe in. If you have the cars front end set like this, and the rear axle bushings are tight and not worn out, you should have a vast improvement. The car should not be hiked up in the rear, because it will then be susceptible to wheel hop as the geometry is off when it's raised excessively. I assume you have radial tires, bias ply isn't going to get the job done. From my own experience, this should get you in the ballpark for a decent driving street car, if you want to spend more time, and money you can surely improve it even more. This will make most any A body much closer to a better handling street car without breaking the bank, and investing many hours in labor. |
The Following User Says Thank You to Sirrotica For This Useful Post: | ||
Here's a few pics of the disc brakes. Can y'all confirm what caliper and brake hose this is? I need new brake hoses.
Donor vehicle is harder to figure. Likely a '69-72 A-body if the steering knuckle height isn't altered with a "tall-spindle" conversion. That's where I'd start, anyway. S10 disc conversions are (were?) also popular, if your rotors are 10" instead of 11". Cheap and available, not especially effective. |
H-Os F &R sway bar sizes were 1-3/8 front and 1-3/8 rear. We had these custom made by Hellwig. Closest available now are from Hellwig with 1-5/16 front { 55703} and 1" rear {5800}
The shocks I used to sell for my suspension pkgs were KYB Gas Adjusts or Koni s. Ride quality is good. Use with good sticky tires and you will be amazed.
GOOD IDEAS ARE OFTEN FOUND ABANDONED IN THE DUST OF PROCRASTINATION |
The Following User Says Thank You to KEN CROCIE For This Useful Post: | ||
A new-to-you car has many 'unknown' parts, who knows what the string of previous owners did.
50+ year old spring are just that, 50+ year old spring. Not only has the tech come light years, but springs that old are done. (and simply, old-tech) Herb's comments on 'soft-spring/big bars' approach was based off the original, NEW, OE trans am springs, and preferably, the WS6 springs. Once those springs are 50+ years old, it's all moot anyway. Keep in mind, when the trans ams were new, the 'designed' spring rates took the control arm bushings into account. They changed the spring rate, by loading the bushing in-travel. The moment you go to new OE type bushings, you lose that overall config, because all the replacement bushings are 'generic'. The trans am bushings were unique to the car. That's why when people went to a free-moving type bushing, which allows for more free articulation (desired), many noticed the change in characteristics, and started 'chasing' to get it back. You have to change the spring rate. Best approach is to do it all at once, in a 'package', but that's not always in someone's budget. You can choose a desired end-design and go piece by piece, but not only does it cost more in the long run, but you have to tolerate the characteristics that the 'unbalance' creates until it's all done. Sway bars are used to tune the characteristics of the car's 'attitude' driver's driving style. Understeer/oversteer is basically the 2 factors. Again, you need to wait until everything else above the bars is complete. So honestly, at the moment, it kinda doesn't matter what shocks you use. Shocks basically last about 24k miles, less if you're a 'spirited' driver. I've used a lot of Bilstein and Konis. Konis are a hair better, but they are both still just 'mid-grade' shocks at best. 4-links in general, eat right-rear shocks. In the LeMans, I would get about 10-12k miles out of them, at most. The more I tightened up the rear suspension, and allowed for more free articulation, the longer they started lasting. .
