I haven't had any issues with Powerbond dampers on the ones I've used. Other low cost dampers that given good service has been Pioneer with the snap ring and the Summit brand.
ATI Superdampers are what I recommend when asked. I know they are more expensive but what is the extra $200 to protect other high dollar parts?
Monty Frerichs B&M Machine Box Elder SD |
Does the ATI clear the oil pan lip and how’s the fit on the crank snout? Thanks
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile |
I use BHJ and they have worked well.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
The place to buy a 4 bolt Pontiac SFI US made balancer that will clear the lip and work on all Pontiacs even with A/C is Nightmare Performance. They sell the BHJ balancer that he had a custom run made that will work on any Pontiac. He paid a lot of money for the buy in but he has them in stock. I paid about 450$ for mine and if you go straight to BHJ they are close to 600$. You need to have a 'exact" measurement of your snout down to .000 so he can match up with ones he has already measured so you get the correct press fit. He is the guy, call him up. They are not "one size fits all". |
With a new balancer, mark the hub and ring, so you can keep an eye on them and catch any obvious slippage.
1968 Firebird 400 RAII M21, 3.31 12 bolt, Mayfair Maize. 1977 Trans Am W72 400, TH350, 3.23 T Top Everyone you will ever meet knows something you don't. Bill Nye. |
The only time I ever exploded a torsional damper, the engine spun a bunch of rod bearings not long afterwards. The engine was assembled by morons, lasted about a year and a half.
Did the faulty damper cause crank problems? or Did crank problems overload the damper causing it's failure? Since that time, I've always been squeamish about shoving a new damper onto a crank when the old damper failed. Seems like a good time to check the bearings and maybe the flywheel/clutch/flexplate... |
To your original question I looked at two balancers I have the key way is about 80° they both stop at 50° and then has 90° so it’s just a close estimate.
Thanks.....
Anyone else care to post balancer brands that are good... or bad? Sounds like some more education on the subject would be good, if it’s ok w/ Mike?
Interesting thread here.
My experiences, If TC (cam & crank) is at Zero with No Adv-Ret, offsets, the (installed on snout) damper should then display the “Zero” groove-line mark at the TC-Cover’s pointer-finger line / edge. I’ve seen where the cover finger was wrong and or the damper was wrong also, at OEM instal of all parts. It was a matter of figuring and get the proper pieces to make it sync-align, else would so cause confusion. It all should align rather simply as designed!! (in a perfect I dream of Genie show world). Work around I also seen is the inner mechanics of TC setting once you Do have this TC set, then THAT is the bottom line!! You will need to make the damper its “new Zero” TDC mark. Which is cosmetically Wrong yet the engine doesn’t care! Just make your new Zero line mark, on the damper, like a Butler damper tape placement on it etc. And finish the task or go gather the correct TC cover or/and damper combo pieces.. And Yes these old damper have old rubber inserts Do have a limited life span, I had one on my Honda accord spin slightly on me causing a lot of havoc & days of troubleshooting my electrical system. (poor battery charging issues-next morning No starting) Hope this helps. ------------------------- Don’t fall for the banana in the tailpipe!! |
I also now make a paint mark on the crank pulley, inline with the timing mark. Then, when checking timing, I can see if there has been slippage.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
Best to avoid the (sharp) chisel, as the sharp indentation makes a perfect stress-riser potentially leading to a crack. I've put marks in dampers using a center-punch; but then I set a small ball-bearing on the punchmark and whack it with a hammer to create a rounded impression with surface compaction, to avoid cracking. |
The statement was for OEM straight up cam crank align, as in whole task-job in this matter, to Clarify logic and clocking degree mechanics, that reflects including the OEM proper damper to Pointer alignment . Offset in cam is irrelevant to damper and goes “almost” without saying, unless a Soul on the thread needs things Spelled out a little deeper--obviously. After 45 years as an engine builder-mechanic and the winningest engine Still in my region bet Ive learned this within 3 months of understanding in the 70’s. Like I said if dampener is OFF then “Butler “TAPE” remark it . READ the whole statement . thx |
slipped balancer
I had one that had slipped about 5/8-inch. Verified that with a piston stop and rotating by hand in both directions. New balancer checked 'perfect' using same technique.
Lord....that’s a range of responses
New balancer is installed, all back to normal again. I ended up with a Romac balancer due to the powerbond not being in stock. As others have noted with the Romac, I had to bend the lip of the oil pan slightly to clearance the balancer hub. Other than that, no issues. Thanks for the feedback
#38
I'm running the ATI one. From what I understand when you get in the upper H/P levels, its good to move to a more reliable balancer. I had to remove a small portion of the timing tab. I had not issues with oil pan lip and I just took my pulley and drilled 3 new holes as the balancer uses 3- 3/8" bolts versus 4-5/16" bolts. I run the powerbond on 2 engines with 600 hp and 600 T with no issues so far. Charles |
#39
piston stop on number 1 ?
It is easier to fool a man than it is to convince he has been fooled |
