Fitment was good in all areas. I had to order new pushrods so we haven't made any smoke yet. I will report once I make some passes on it.
Dave Polichena |
Here they are. The DLC coating, what is it ? Looks like a steel bushing with a coating. How does it hold up ? 1090$ here.
https://vincentperformance.com/shop/bam-b-2030-16-bb1/ They make a std bronze bushed lifter. 940 $ https://vincentperformance.com/shop/bam-b-2030-16-bb4/ And a needle bearing lifter. 695$ https://vincentperformance.com/shop/bam-b-2030-16/ USA made. I did not see a .903 lifter on this website. |
Isky red zone, Crower enduremax, and BAM all are good choices. Like dealing with Brad. He will do specials on request. Just got some .903 +.005" with .180" intake offset for SBM.
Monty Frerichs B&M Machine Box Elder SD |
It looks like DLC stands for"'diamond like coating". Some sort of carbon coating. A lot of the name manufacturers are making lifters using it now.
Well, If Richard can run 7000 plus miles Street and Track and not have any issues with lifters, then I would say your probably pretty safe with Morel. No?
Just my experience from running these lifters. Crower # 66494X903E-16 The Crower lifter were using are HIPPO oiling They also incorporate a .010 groove on the side for oiling from the oil band to the oil supply hole for the pushrod. It's just for additional oiling all through the lift range. The hole for the bearing or bushed wheel is feed from inside the oil band. They are cross drilled and one side is plugged. This definitely has to be check if cross drilled on new lifters. The side facing the lifter bore is plugged during manufacturing. Thank you Mike for pointing this out. From what I understand these lifters are edge oil oiling and is based on clearances in the lifter bores or in my case the installed bushing. We don't run any Restrictors in block or pushrods. So far so good.
I'm sure someone has mentioned Bam.
BAM has 2 bushing options, Bronze and Solid Steel DLC. Brad mentioned that there are multiple dragweek guys running the Solid Steel.
2023 Best ET Slip 60’ 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
.040 restrictors might be a good way to go since its not a street engine. |
x2! I was told a minimum of .100 right from Morel when running a bushed lifter
I can always drill them out to .100. Or just pull them out.
It's almost like i knew what i was talking about lol
The Following User Says Thank You to slowbird For This Useful Post: | ||
I'm having a duh moment. What is the .100 your referring too? Thanks
I fat fingered a reply that ended up on the shaft rocker topic. I'm trying a .062 hole size on my 525 with .903 bushing type crower lifters. Will see how it goes.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
The whole size in my lifter bushing to feed the lifters
The Following User Says Thank You to grandville455 For This Useful Post: | ||
I was told .030 was too small for std non pin oiled Comp rollers. 10+ years later still good. When priming the engine I was amazed how much oil shot out of the .030 hole. Took over 10 minutes of priming and slowly turning the engine over to get oil everywhere I wanted. I figure I need to restrict oil to the top end at least some and the HP heads have good drain back. |
This is the best price I have found so far on the BAM lifters with DLC coating.
1000$ Going with them from this guy. |
#38
Dragncar
Instead of buying new lifters why not have Crower rebuild your current lifters ? And they can add the Hi Pressure Pin Oiling option. https://www.crower.com/rebuilt-your-roller-lifters .
The Following User Says Thank You to Steve C. For This Useful Post: | ||
#39
I run a bit more oil pressure than some do.
#40
I'm trying a .062 hole size on my 525 with .903 bushing type crower lifters. Will see how it goes. I think I'm around .080 feed hole in the bushing. I primed the engine with the lifters removed and there is lots of oil comes through those holes in the bushings. May I ask what oil pressure your running? Thanks
68 Firebird. IA2 block, 505 cu in, E-head, Solid roller 3650 weight. Reid TH400 4:11 gear. 29" slick. Best so far 10.12@133 mph. 1.43 60 ft. 76 Trans am, TKX .81 o/d, 3.73 Moser rearend, 468 with KRE D-ports, Doug headers, 3" Exh. Last edited by chuckies76ta; 03-05-2022 at 10:28 AM. |
