Tim Corcoran |
Tim Corcoran |
Looks like it's getting fuel. I would try a cylinder leakdown test and a running compression test to verify the exhaust lobe of the cam on that cylinder. I ran into that one time on an SBC....dead hole, but good compression, fuel, spark, no vacuum leak, etc. Turned out to be a flat lobe on the cam, for the exhaust valve on that cylinder.
Jeff |
Mystery Solved
Schurkey was spot on in post number 14. I suspected a vacuum leak from the very beginning but for the life of me couldn't figure out where it could be. I even pulled the carb off and made sure the gasket was covering all the right places. I believe I did all the correct trouble shooting steps but just couldn't figure it out until I pulled the intake manifold. When I was elongating the pushrod holes so I could use 1.65 rockers I got kind of carried away and broke through in a couple places. My machinist gave me some two part putty epoxy and he said it would be fine. Maybe I sanded it too thin but obviously it didn't hold. Now I need to fix these holes with something that will stay put.
Tim Corcoran |
The Following User Says Thank You to Tim Corcoran For This Useful Post: | ||
Yep that picture explains it all. That baby is sucking in some oil ( Big vacuum leak )
If you can, put a sleeve down that hole, only because the Apoxy is a hit or miss. It’ll come out again when you lease expect it
Not sure how I could do that the hole is not round after I was grinding in there. It's a shame I have a lot of money in those heads, porting, valves, springs, milling.
Tim Corcoran |
In that case I would grind that all off and get a real good Apox That’s not saying that you didn’t use a good going to begin with. Hey you may have good luck. Hey I go for it
Tim do it right but to do that you need to pull the head(s), that’s the hardest part.
Next drill the hole with a new 1/2” Drill bit. Get some 1/2” OD brass tubing from a hobby shop or order it from Grainger or micro mark. Cut it to length full coat both the hole and tubing with JB weld and install it. Let it harden for a full day and then cartridge roll sand away what you don’t need. Sorry for your issue, but atleast you did not harm anything in a new motor. Here in this photo of a max ported D port 16 head you can see how I did it.
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 09-10-2023 at 06:23 PM. |
Glad you found the problem. As said, without all the info on your engine, it's hard to determine the cause. (nothing about head work being done)
Here’s another photo of that same head and on the left port you can just see the tube peaking out and how far back and flat you can get to roll back to.
If you choose to drill & sleeve you will have to drill slowly when you get to the blow out holes because the might really want to walk on you.
Thanks for the great info on how to fix this. Fortunately, only one head will need to come off the other head is OK. Can this be drilled by hand or will it need to be done in a mill? I have a drill press but getting the head at the proper angle would be almost impossible.
Tim Corcoran |
Hand drilling would be tough, have to go slow and easy. But it could be done.
You have a lot invested in your heads.
Pay a machinist to drill the hole and install the brass sleeve, you’ll be glad you did.
Didn't we go through all of this a few months ago? Different guy, same problem?
https://forums.maxperformanceinc.com...d.php?t=866228 |
This right here. Its cheap in the long run.
A drill press would be the best way to do it, but you would need to cut a lenght of wood to a 14 degree angle to sit the head on.
I have always done it with a big hand held electric drill that I have which has a side bar handle . Maybe you could brorow one or get you hands on one from a tool rental shop.
#38
Here's another tip for you Tim.
Use a Qtip wetted with some light oil to coat the whole inside of the tube so that any stray epoxy you get inside it will be far easier to sand out it you should need to.
#39
Is the PCV routed to that runner on the intake?
Lay the spark plug on the side of engine or other ground and crank it over, see if it sparks. The plug could just be bad. .
#40
He found the issue gang!
