Old 10-03-2023, 06:20 PM
gtorich gtorich is offline
Originally Posted by 64speed View Post
I guess it is upsetting. So much money and the last thing I was is spots in the driveway
I hear ya brother, im in the same boat, 3 rebuilds over the years and the rear main still leaks..................not gonna hi-jack this thread, but start a new one next week..............see if yours is anything like mine.
Rich
The Following User Says Thank You to gtorich For This Useful Post:
Old 10-03-2023, 07:39 PM
Gach's Avatar
Gach Gach is offline
Oh my God !! Unbelievable.
Old 10-03-2023, 08:02 PM
64speed's Avatar
64speed 64speed is online now
It’s not that bad LOL. It’s just annoying. Car runs great.
Old 10-03-2023, 08:18 PM
Gach's Avatar
I am relieved to hear that. LOL
Old 10-03-2023, 09:19 PM
68WarDog's Avatar
68WarDog 68WarDog is offline
Still think it would be a good idea to reach out to members of the Palmetto Pontiac club. There are some very knowledgeable guys in that club,
Old 10-04-2023, 08:12 AM
Don 79 TA Don 79 TA is offline
depending how bad your issue is, but perhaps something else to possibly try
what kind of oil and weight do you use?
There's many articles out there about ester oils and how they help with seal issues. i think perhaps the key on that might be seal related vs say gasket, but i dont know, i've seen articles and it would say seals.
maybe using to thin oil? to fine? maybe try a group V base stock?
i use motul and haven't had issues
but as i've mentioned in the past, that engine dye stuff really helped me
one trick we did with a few customer cars, i should say the shop guys would do, is when troubleshooting an issue as finding a fine oil leak with a dye, is change oil, add dye, but on this change use the thinnest oil you can get your hands on, as thin oil, especially syn oils, if theres a place to leak, you'll leak and probably have better luck finding it. i used 0-8w when i did my troubleshooting, and of course changed once i saw the issue was resolved. didn't want dye flying around any longer than it needed. I know, probably just some stupid thinking on my part, but hey it worked for me.
i know in the later 70s/early 80s guys used to use thicker oils to help reduce leaks, again oil was so different back then, also for other tricks too, but you can compound other problems i suppose.
just a little more thinking outside the box to possibly help
The Following User Says Thank You to Don 79 TA For This Useful Post:
Old 10-25-2023, 05:25 PM
64speed's Avatar
This is still baffling me. I am dripping still BUT it looks like it’s coming from the front of the engine based on the driveway stain. It is nowhere near the back it’s more towards the middle. Front of the pan and timing cover and fuel pump are bone dry. I am lost
Old 10-25-2023, 05:36 PM
steve25 steve25 is offline
Around that middle area of the pan where you think it’s leaking remove two or three pan bolts .
If the threads are wet then that’s where a poor gasket seal is letting oil get the bolt and when all is hot weep out.
Old 10-25-2023, 07:42 PM
64speed, dont know if it will help, i pm"ed you about my similiar issues............i marked everything out with tape to see where the leak might be comming from..............one time its in the front, then the middle, then the back.............my front of the pan and tc and fuel pump are always dry also..............but im still dripping somewhere.....................i think steve 25 has a good plan..............im gonna try that myself.
Old 10-25-2023, 11:06 PM
jhein's Avatar
jhein jhein is offline
Sounds like you really need a smoke machine.
Old 10-26-2023, 02:24 AM
chuckies76ta's Avatar
Check the bottom of the power steering pump and the power steering box itself. You need a lift to get under it.
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 4:11 gear. 29" slick.
Best so far 9.95@134 mph. 1.43 60 ft.
The Following User Says Thank You to chuckies76ta For This Useful Post:
Old 10-26-2023, 02:01 PM
64speed's Avatar
It’s not far enough back to be rear main
Old 10-26-2023, 03:00 PM
Verdoro 68's Avatar
Only one way to find out where it's coming from - grit your teeth, get under there and take a peek.
Dye might be a good way to trace the leak, just be aware that it sticks around in your engine for a while. I pulled and disassembled my engine twice and have done three or four oil changes since I put the dye in. The new oil still has a slight glow to it under UV.
Ken
'95 Comp T/A #6 M6 - bone stock (pics)
Old 10-29-2023, 07:43 AM
64speed's Avatar
After thorough examination I think a lot of mine is the drivers side valve cover. It has Felpro cork gaskets. Anyone recommend something else?
Old 10-29-2023, 09:51 AM
78w72 78w72 is offline
I have felpro cork gaskets in use for 15+ years that are bone dry, are you using steel covers or aluminum? If steel make sure the gasket surfaces are flat around bolt holes & maybe try the load spreaders, if aluminum spreaders shouldnt be needed since they are more rigid than steel.
Some get by with dry cork gaskets but I always use a thin layer of ultra black/grey permatex sealer, just a thin bead smoothed out with your finger to glue to the cover then a very thin layer to the head, will seal it up for a very long time & if careful when removing it lets you take them off and reuse a few times, just a light clean up of any lose area & a fresh coat on the head surface each time. Doing them dry with a light layer of grease can work too but the ultra black seems to give them a skin to allow more uses, almost like a rubber coated gasket.
They make a steel core rubber gasket too that gets mostly good reviews too.
Old 10-29-2023, 02:06 PM
geeteeohguy's Avatar
I've been using Felpro cork gaskets for over 40 years. The ones on my '65 are 42 years old and just starting to weep a small amount. I use no sealant at all on VC gaskets, just a couple dabs of grease to keep them in place on the valve cover when installing. And then I don't overtighten the valve covers.
Jeff
Old 10-29-2023, 03:53 PM
J.C.you's Avatar
J.C.you J.C.you is offline
Probably valve cover leak
1966 GTO dragcar
1966 GTO Ragtop
1969 Tempest ET clone street/strip
1969 GTO Judge RA lll, auto
1969 GTO limelight Conv. 4speed go and show (sold)
1970 GP SSJ
1972 GTO 455 HO, 4 speed, (build)
  #38
Old 10-29-2023, 03:57 PM
Verdoro 68's Avatar
I use the 1/4” thick cork FelPro gaskets since they’re more forgiving. I dab a little weatherstrip adhesive on the valve cover side to keep them in place, nothing on the head side. The key is not over tightening.
Ken
  #39
Old 10-29-2023, 04:48 PM
64speed's Avatar
They are aluminum valve covers not chrome so I don’t think the flange is bent.
  #40
Old 10-29-2023, 04:57 PM
Verdoro 68's Avatar
Ken
