Old 12-06-2023, 03:16 PM
dv657172 dv657172 is offline
Oil level seems fine and no smell of gas.
I mentioned earlier that car would only run for about 15 seconds off the float bowl with old carb and same with rebuilt carb which Greg Reid thought seemed in line.
If I assume the bowl holds 1/2 cup of fuel (?) than every 30 seconds the car consumes 1 cup of fuel or 1 gallon every 8 minutes or 1.25 gallons in 10 minutes. Bad math/logic?
Old 12-06-2023, 04:18 PM
Gary H's Avatar
Gary H Gary H is offline
Originally Posted by dv657172 View Post
k fine. Blew air through fuel line to tank and heard air right away at the tank. Hooked fuel line back up and it ran fine for 15 minutes or so with no issue until I shut it off. Still not comOld cars sure keep things interesting. As stated earlier, car ran off external fuel tanpletely sure if issue was carb (probably), fuel pump, fuel tank pickup blockage or some combination.
I will say I was surprised at how much fuel the car used sitting at an idle for about 15 miuntes when I was running off the external tank, about 1.25 gallons
If the pump has a return line from the pump to the tank that was still hooked up during the 15 minutes of run time, then most of the fuel went back to the tank through the return.
The Following User Says Thank You to Gary H For This Useful Post:
Old 12-06-2023, 04:37 PM
I am using a stock (Carter) fuel pump. The manual refers to it as a vapor return line, is that what you are referring to Gary H.?
Sorry for whats probably a dumb question...
It would probably make more sense than my math, lol
Old 12-13-2023, 01:31 PM
HWYSTR455's Avatar
With the pump off you can look thru the hole at the eccentric and make sure it's there, and attached properly.
Check for dry rotted lines between the tank and the pump. Make sure all the clamps are tight too.
I've seen them not suck fuel and not leak either. If they're old, replace them. The old stuff isn't made for today's fuel and will eventually fail.
Something stuck in the fuel line itself may allow air to pass back to tank, but plug again from the tank forward. It's possible. Like a bunch of rust flakes at the bottom. Or globs of thickened crap.
If you've never had the tank out, it wouldn't be a bad idea to pull it and inspect it. Yank the sock off while you're at it. Pop the sending unit and look in there, shake it around, see if there's crap in there. Bet there is.
If there's a question over the vapor line, plug it.
It's possible to get multiple DOA/out of box failures on the pumps, Paul Spotts just went thru this. Think it took him several before he got one that worked. The Carters were the ones failing, and he was going to try an airtex I believe. Pretty sure he picked up a NAPA one.
Old 12-13-2023, 03:19 PM
JB Eng Wis JB Eng Wis is offline
Try this.... blow air (low Psi)from fuel pump inlet hose back to the tank....(remove fill cap)
see if fuel / air is leaking from a cracked or pin hole in the steel line......If you find a leak,,,, your sucking air into the line.
Hope this helps.
Old 12-14-2023, 08:20 AM
HWYSTR455's Avatar
Spotts commented that he ended up with a Delphi pump, and it holds a steady 7psi at idle.
