#41
I liked it better when the shaft didn’t move but I guess it is what it is. All this has given me a headache just reading it. The gear is on and that’s about all that matters to me at this point LOL
#42
#43
Hehehe...it's a super rare Delorean Phase Adjuster
#44
Aside from matching the original configuration when installing gear, is there any other way to determine what on side the dimple should be on?
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
#45
Thanks for this post! I now get it. Excess clearance is needed to manage the variation in the STACK: oil pump, oil pump shaft, distributor shaft.
My original thought about thermal expansion was only about differential between distributor housing and distributor shaft. I now think expansion of the pump and oil shaft is another source of clearance loss. Net: your advice to check clearance when INSTALLED is the key. Thanks again! |
#46
As others have stated, for whatever reason the dimple on every points distributor I have taken apart (all Pontiacs) it lines up with the rotor contact. I have no idea if that is the case with every one.
#47
![]() Quote:
Clay
All the federales say,they could've had him any day They only let him slip away, out of kindness...I suppose Poncho & Lefty |
#48
![]() Quote:
Kenth |
#49
So, what about post #37, paragraph #7? Who's right?
#50
See post 48.
#51
That's not a phasing tool, that's a timing adjustment tool for use on a car without a vacuum advance. Here is an adjustable rotor for phasing adjustment: https://www.jegs.com/i/MSD/121/84211...IaAgmXEALw_wcB
They don't make this piece because it's a figment of the imagination. |
#52
I feel your pain. This is a hard point to drive home.
#53
![]() Quote:
I have a bridge for sale too. |
#54
Oh I knew you were trying to be funny, but that's what people do when they don't understand the subject matter and are too embarrassed to ask someone to explain it to them.
#55
In a "Pontiac", it would have to be a reverse rotation engine for the cam to pull down on the distributor gear.
I've tuned and worked on a bunch of twin engine boats that had one engine that ran CW and the other ran CCW. Most of them were chevy or mopar powered. I've personally never seen a reverse rotation Pontiac. Clay
#56
![]() Quote:
http://pontiacformula.free.fr/en/allumage.php "Pontiac’s 287 block featured five 2.5-inch-diameter main journals that support a forged-steel crankshaft. The left-hand cylinder bank was offset rearward. This allowed the distributor to be mounted on the right side of the block, exposing its driven gear to upward thrust, eliminating the need for a machined thrust surface within the block". https://www.pontiacdiy.com/pontiac-v...ory-1955-1981/ |
#57
![]() Quote:
Does appear that Mickey Thompson may have built at least a couple for one of his early land speed record cars. Four blown 389's, two running regular rotation and two reverse. Still ain't seen one myself Clay
#58
![]() Quote:
You're getting off to a wonderful start. I look forward to your insightful contributions to our store of knowledge. |
#59
Dang. Guess dyslexia kicked in again!
#60
I agree, had the same thought when I read the post.
