Old 08-06-2019, 09:58 PM
64CatalinaVentura's Avatar
64CatalinaVentura 64CatalinaVentura is offline
Seeing this there was a really cool experience.
Frank (Catalina) Tupka
1964 Pontiac Catalina Ventura Sports Coupe
Connecticut Pontiac Association
  #42
Old 08-07-2019, 08:32 PM
goatwgn goatwgn is offline
There is now a IA II short deck block. I am curious if anyone has tried to build a 303 using that as a foundation???
  #43
Old 08-07-2019, 09:23 PM
tom s tom s is online now
Actually their block is a 9.5,not sure if they ever got one down too 9.2.If you look at the factory pontiac short deck block they dont use a oil filter adapter,the filter screws to the side of the block.Also not sure if they can do a small main block like the 303.EVERYTHING is possible just numbers in a check book.Then the issue with custom intakes comes next.I really dont see someone doing a 303 anyway even boosted.A short deck 400-428 would make a killer turbo combo IMO.Tom
  #44
Old 08-07-2019, 11:13 PM
77 TRASHCAN's Avatar
I bought a set of 303 heads,a intake and carb at Norwalk.I have a std deck 303 block being built as a 428 right now,hope to have it on the dyno the end of the month.I have a ready to build 301 turbo block here that I might put the 303 heads on it with a factory X ram 2-4 intake.Thats in the future maybe.Tom
Glad you found someone to do dyno testing, Joe, was the "Man"!!!
Shut it off
Shut it off
