Old 02-09-2024, 03:03 PM
78w72 78w72 is offline
I may have missed it, is this the digital 6al or the older analog one?
  #62
Old 02-09-2024, 03:15 PM
64speed's Avatar
64speed 64speed is offline
Digital
  #63
Old 02-09-2024, 03:40 PM
Crazy idea.
Put a recurved GM not aftermarket HEI in it and drive off into the sunset, with a spare module and a screwdriver in the glove box.
Even crazier idea.
GM points distributor with a modern coil along with a spare set of pre-gapped points and that same screwdriver in the glovebox.
Funny how reliable those factory ignition systems actually were, isn’t it.
  #64
Old 02-09-2024, 03:41 PM
64speed's Avatar
I need a rev limiter. That’s how I blew up the first one. It runs fine with the RTR that’s in it now but the 6AL is really only for the limiter
  #65
Old 02-09-2024, 03:43 PM
So you’re saying that a rev limitation device couldn’t be added to a factory ignition system.
A points distributor that uses the points to trigger an MSD box is a way to do it. This way you can jumper out the MSD box and just run on the points alone should the MSD box crap out.
I used to keep those MSD supplied jumper wires in my glovebox.
  #66
Old 02-09-2024, 04:02 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Aren't the stock points a rev limiter of a sort
Go fast, see Elvis!
  #67
Old 02-09-2024, 04:28 PM
I’m sure to a certain extent.
My 1974 455 would easily go to 6000 during a burnout if I wasn’t being careful, I usually shifted at 5200 and saw 5700 through the lights while bracket racing.
I ran a locked points distributor with an ancient MSD6A box, never used a rev limiter and managed to keep the stock cast rods and pistons inside the block for a decade of racing. Later went to a recurved points distributor with vacuum advance when I put it back on the street.
For your average 500 or so horsepower hot street Pontiac I’m sure factory points or HEI would handle 99% of anyone’s ignition needs.
  #68
Old 02-09-2024, 05:54 PM
HWYSTR455's Avatar
Keep trying to tell you, YOU didn't blow the first one up by over revving it.
  #69
Old 02-09-2024, 05:58 PM
64speed's Avatar
Ok well the Lunati lifters were not capable of handling 7500 RPM
  #70
Old 02-09-2024, 06:07 PM
HWYSTR455's Avatar
They should be able to handle blips to 7500, think they would float before then though.
  #71
HWYSTR455's Avatar
  #72
Old 02-09-2024, 07:30 PM
PAUL K's Avatar
Agree..... I used an MSD 5 ..... Still have it. Thinking about testing it on my 70 and see if I notice an improvement.
Go fast, see Elvis!
  #73
Old 02-09-2024, 08:32 PM
242177P's Avatar
242177P 242177P is offline
Or an automatic.
  #74
Old 02-09-2024, 08:44 PM
64speed's Avatar
Originally Posted by 242177P View Post
Or an automatic.
What fun is that 🤣
  #75
Old 02-09-2024, 10:02 PM
MSD makes a in cap HEI module with an adjustable rev limiter, works pretty good in my experience, but i dont really need a rev limiter so switched back to a good ol GM module.
  #76
Old 02-20-2024, 11:59 AM
64speed's Avatar
Well big shout out to MSD. Less than a week test and turn around. I called today to see if they received it and they have already tested it and are shipping me one back. Diode failed and took out a capacitor. They said 15-25 days just diagnosis time but they’ve only had it since Wednesday so kudos to them.
  #77
Old 02-20-2024, 12:31 PM
triathlonx13's Avatar
Oh WOW! well, glad this has been resolved - good luck.
  #78
Old 02-20-2024, 12:56 PM
They are pretty good that way...they replaced mine post warranty no questions asked... 👍
Old 03-01-2024, 11:00 AM
64speed's Avatar
Just an update to this. The MSD 6AL AND the distributor were bad. I sent the box in for evaluation and the replaced a diode and capacitor. Sent it back and I rechecked all the wire, it was good so I hooked the box up and fired it up. Ran about 15 minutes and died. I got the old screwdriver out and tapped the distributor and box and it fired up again and ran a couple of minutes then that was it. I then noticed that if I tapped on the distributor with the key on the MSD box light flashed. I sent a video of that to Grivera and even he thought it was weird as hell. Ordered a pro billet non ready to run distributor and got it yesterday. Stabbed it in and took off. Runs better than it ever has.
The Following 2 Users Say Thank You to 64speed For This Useful Post:
