Old 03-10-2021, 02:37 PM
dataway's Avatar
dataway dataway is online now
Maybe the 68 seats are easier
I've got ACI foams, going to try just some jute and thin padding beneath, then foam, then covers. Will try to follow a combination of Rambows how-tos and the Legendary installation videos.
Local shop wants $850 to do the job with all the materials supplied by me, not a chance I'm going that route.
Recovered the rear using the original covers with all new padding, turned out ok.
  #62
Old 03-10-2021, 05:13 PM
vertigto's Avatar
vertigto vertigto is offline
$850 for just the buckets? If it's for all 3, that's not too bad. I was quoted $900 for the front buckets and rear bench.
  #63
Old 03-10-2021, 07:53 PM
dataway's Avatar
Yep, $850. Told them I would supply every thing down to the hog rings and stripped and painted frames. Just the two fronts.
  #64
Old 03-10-2021, 07:56 PM
roger1's Avatar
roger1 roger1 is offline
That does sound pretty expensive. I don't ask my interior guy for quotes because he's always given me very reasonable pricing.
Also, where I live helps. Labor in general is less expensive here than a lot of places.
'69 GTO Convertible - Acquired October 2020. An all original project car. Restomod is underway PROJECT THREAD
'83 Chevy Choo Choo SS El Camino - LT1 350/4L60e, Owned for 30 Years, completed 2nd restomod in 2018 PHOTO
2019 BMW 440ix - Twin turbo I6, 8spd auto. PHOTO
'55 Chevy Bel Air Sport Coupe - Ram Jet 350 / T56 Magnum 6spd, Restomod Completed Sept. 2012, Sold Sept. 2021 PHOTO
  #65
Old 01-08-2024, 02:20 PM
HWYSTR455's Avatar
Reviving thread...
I'm coming back around to fixing my buckets, and am seeing how others have been doing, or made any progress with their' projects.
I am going to cut the 'extra' wires in the seat pan, and see where that gets me.
Maybe the upright pans have extra springs too?
On the foams, I'm thinking only the insert areas need to be trimmed, the side bolsters appear to be correct. By trimming the insert area foams, I'm thinking I can pull the listing wire closer to the pan, taking up any slack that is leftover from trimming the foams.
Any ideas are greatly welcome!
  #66
Old 01-09-2024, 11:43 AM
Cammer-6 Cammer-6 is offline
A trick I use:
turn covers inside out and put in a pillow case.
Low heat in the dryer to soften.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
The Following 2 Users Say Thank You to Cammer-6 For This Useful Post:
  #67
Old 01-09-2024, 07:09 PM
HWYSTR455's Avatar
That's sounds like a great idea! Mabe even toss some tennis balls i there too?
  #68
Old 01-12-2024, 02:23 AM
KGTO's Avatar
KGTO KGTO is offline
Guess I'll mention my issue. Legendary front buckets with ACI buns on a 70 GTO (sandalwood) had a shop do them turned out good, but the horizontal stitch ran at angle on each. Not noticable installed.
Rear bench different story. Same issue with stich, but the covers were too big. Problem fixed but I reached out to them, Paul directed me to Ron. Sent pictures but no word back yet.
ID:	626434   Click image for larger version
ID:	626435   Click image for larger version
ID:	626436   Click image for larger version
ID:	626437   Click image for larger version
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot
1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @159 3500+lbs 10.5W's SOLD!
1964 421 GP-Sold
6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold
  #69
Old 03-09-2024, 10:43 PM
Nyairguard's Avatar
Nyairguard Nyairguard is offline
Default legendary
used legendary in the past they were top notch, if I had issues id call and complain, used acme covers horrible fit but ok at best for a driver just installed a set of pui door panels fit like all heck even had issues with weatherstrips not sure whats going on with the fitment with USA parts but unfortunately our craftsmen all retired and were left with assembly workers that just don't care.. gotta make 10 of these and I get to go home my 2 cents
2nd gen bird
