#121
255s on all 4 corners is fine, and allows for rotations. And yes, 275, pretty much just the contact patch. 8s all around is fine too, though it will limit you to a 255, anything bigger requires a wider wheel.
Eagle GT all season W rated tires are about $130, that's cheap for the tire you're getting. And have a 400 wear rating. I saw some NANKANG tires on Discount for $110, but I have no experience with them. (Still inexpensive for an 18). .
#122
On mine, I am going to measure my current ride height and then contact PTFB and see what they can provide that would maintain close to my current height, but obviously stiffer to avoid bottoming. All the research I did says that 255/50/17 on 17x9 wheels at all four corners is very easy on a 2nd gen bird. So a simple spring change must be the answer...several guys on here running the same tires but with aftermarket springs. Does anyone know the proper spot to measure ride height?
#123
![]() Quote:
You might get lucky though with just going to a higher rate spring, since an inch really isn't that much. But you would have to choose a higher rate spring that has no drop for the most part to be sure. I think it's a lot easier to just go to a tire that mimics the factory height and be done with it. Allows you to follow examples and setups others have already worked out and done homework on. Maybe someone who is running that size tire can chime in, or maybe find someone that is and ask. Just a thought, might want to check your core support/body bushings, see if they're mashed or need replacing. You can loose an inch easy when those are boogered. .
#124
Thats why I went with a 27" tire. That is a factory height tire, just wider.
#125
PTFB's GT front springs will work with a 255/50R17 on a 17 x 9 rim- more than one 2nd gen Firebird owner has run this combo on his car with success. I think a 255 is about as wide as you can go with this spring's ride height however- I know it won't work for me. A 275/40R18 is only 26.66" tall but much squarer in the shoulder than a 255/50R17 even though it's 27" tall, and will come in contact with the wheel wells. I am running stock WS6 rear leafs and I have good clearance with this spring, but I did cut the fender lips and rolled them back to make sure there's no contact there.
Ride height is measured at the front and back of the rocker panels- 8" is supposed to be the stock measurement, give or take 1/4". Of course for lowered cars this number goes out the window. And if you have old, worn body bushings and tired springs this number will no doubt not be accurate either. Geno |
#126
![]() Quote:
I can imagine that a wider tire than OE, at OE height, would have clearance issues, considering the shape of the inside of the well opening. And that's the basis for the Herb Adams mod (trimming the inner and rolling the lip). .
#127
http://i876.photobucket.com/albums/a...ps043548be.jpg
Here is the damage, or lack there of. Wish I could get the darn photos to display! |
#128
Have to resize them so they're not too big...(photos)
That doesn't look too bad from the pics, but can't tell if the outside shape of the fender/quarters got distorted or not. That's pretty close, you might be able to beat it up enough to where it doesn't grab. .
#129
Funny thing is I did measure my ground clearance at the specified locations and got 9" at all four points, factory with 27" tires is supposed to be 8". That is with old bushings and springs!
#130
![]() Quote:
Pretty obvious what your choices are though. Shorter tire I think is the better of the two, but that's my personal opinion. I know running 40s on 17s is proven and widely accepted. Think Year One listed 40s as recommended tires for the Rally wheels even (275s). On the 8" wide, they list a 245/45. .
#131
Got my set of 4 18x8's in this week. Went cheapo on the tires, 280 treadwear, but they were $76 each with a 30 day money back. 255/45/18
I'll take some before and after shots next weekend when I get them mounted up. Also, I took some measurements...inside the wheel behind the center cap is 2.625", the center cap is 2.69" wide, and the Rally II cap is 2.81" wide.
1970 GTO 455HO Convertible M40, Sierra Yellow, Saddle Int, Tan top. PDB, PS, PW, A/C, Rally Gauges, Hood Tach, Spoiler |
#132
For those of you guys wanting a big inch tire and white letters, I saw a new Challenger this weekend with I think 20s and it had Falken Tires with white letters, looked pretty cool
www.fquick.com/Captainofiron 68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4 97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil 14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires |
#133
I'll have to ask Discount about them. They carry Falken. I also wonder if they might have just been colored in with the Duplicolor tire system. A quick search turned that up on the internet.
http://www.duplicolor.com/products/hotTires/
#134
![]() Quote:
looked good though just did a quick google search, they are "Falken Azenis" ![]()
#135
Or - if you'd like redline's - Diamond Back makes them in 14 - 20" sizes.
#136
I only see 13"-17" in redline...am I missing the others?
http://www.dbtires.com/store/shopselecttire.cfm?size=
#137
20's - are on page 30 of the catalog
http://www.dbtires.com/2013_catalog/hi/30.htm 18's - are on page 28 of the catalog http://www.dbtires.com/2013_catalog/hi/28.htm |
#138
Thanks.
At $300 a pop, I'd never get the treadwear out of them before they'd be too old!
#139
You won't get the treadwear out of any tire before the tires will be too old...
![]() I spent $250.00 each (average) for my 15's on my '64, but I like 'em! I look at the cost per year of enjoyment - not the price per tire... |
#140
![]() Quote:
I was looking at tires yesterday, since it's going to be my son's car, all-season and safety are major concerns. I was looking at the General G-Max tires, 275/40s were like $165ea. That's still not bad, I've paid more for 17s before. I also agree with The Champ, have to look at total cost over the life of the tire. Now for higher-HP cars, that is a lot shorter of a time span, but you get what you pay for, even when it comes to fun. .
