Old 07-25-2018, 11:04 PM
GTOGEORGE's Avatar
Originally Posted by Scott Roberts View Post
You're right...sikgoat is heavy
.. not sure it has the manners to drive 1200 miles though...it might..
I doubt he he drive it on a 1,200 mi trip.....but what do I know.
GTO George
  #142
Old 07-25-2018, 11:07 PM
Originally Posted by GTOGEORGE View Post
...So how much hp does it take to run 7.80’s in a 3,200 car?
GTO George
1332 horses
[internet.com LLC ]
  #143
Old 07-25-2018, 11:13 PM
GTOGEORGE's Avatar
1332 horses
[internet.com LLC ]
Thanks, if that’s it then maybe 1,800 hp can be had with around 20 lbs of boost in a procharger now that I’ve pondred about it....maybe!
  #144
Old 07-25-2018, 11:18 PM
JSPONT's Avatar
JSPONT JSPONT is offline
You are right and I am wrong except I have never bashed pro chargers or turbos (for making hp)!
LMAO George! I did not expect that response!!
  #145
Old 07-25-2018, 11:24 PM
JSPONT's Avatar
I think we have a Pontiac that is quicker with a pro charger!
GTO George
Yes but like stated before it drives drag week, all the car shows in the area. Steel bumpers, original glass, original steel body and hood! It is a 56 Chevy.
Your car would make a ton more power with a turbo or procharger because you could run more boost. Your motor is ready for it, not sure you want to spend money considering you said you are at the end of drag racing.
  #146
GTOGEORGE's Avatar
I’m just sick of arguing with people, it’s not worth it.
GTO George
  #147
Old 07-25-2018, 11:27 PM
JSPONT's Avatar
Originally Posted by Mark G View Post
Wow 3650 ..7.37 gotta love turbos ..lol that is a bad bitch..
Yes it is. If he could leave on power he could go faster. The power management is what holds back car from going faster.
  #148
Old 07-26-2018, 12:34 AM
Dragncar Dragncar is offline
George would make 1600HP with a very basic single turbo.
  #149
Old 07-26-2018, 12:37 AM
GTOGEORGE's Avatar
Not with 11 lbs of boost! Apples to apples!
GTO George
  #150
Old 07-26-2018, 12:52 AM
GTOGEORGE's Avatar
............but with a bigger blower or maybe a Don Hampton two lobe 8-71 I could make anywhere from 1,600 - ?, its all in the boost or how much i want to spin the blower BUT what do I know!
GTO George
  #151
Old 07-26-2018, 01:21 AM
Scott Roberts Scott Roberts is offline
GTO George
How old is your cam George? You could probably gain substantial hp from a cam change.. minimize overlap on a boosted combo and you will waste less boost... no idea what you have but the same engine with the same boost can gain power...
A lot is lost on the overlap... high pressure will always go to the low pressure side.. just a thought...
  #152
Old 07-26-2018, 06:23 AM
GTOGEORGE's Avatar
I’m ok, car can only take so much power and I’m perfectly happy going 170.
GTO George
  #153
Old 07-26-2018, 09:48 AM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
GTO George
I get that, for sure. If you wanted to go quicker and faster, I suspect a change to a high helix blower would do it, provided everything else is set up for it. My car routinely runs sevens with just one-to-one on the blower. The 10-71 high helix runs 536 ci per revolution, IIRC. I'll bet a used high helix would be the simplest way to go (and of course I always lobby for a Birdcatcher---simplicity in tuning with hat and port injectors).
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
  #154
Old 07-26-2018, 10:25 AM
GTOGEORGE's Avatar
Jim
Anything larger then what i have would require a rise for the blower so it would hit the distributor. Anyways like I said I'm kinda at my Race Cars limit when it come to power, if only I knew back in 1993 what i'd be doing now i'd bought something else.
GTO George
