#1741
![]() Quote:
#1742
The car looks and sounds great! Glad to see you got it back together. What length/brand mufflers are you running now?
'71 GTO, 406 CID, 60916, 1.65 HS, '69 #46 Heads 230CFM, 800CFM Q-jet, TH400, 12 Bolt 3.55 '72 Lemans, Lucerne Blue, WU2, T41, L78, M22, G80 |
#1743
I think my local muffler shop carries Dynomax. I’m gonna get them if they have them .
#1744
Yeah, you will need the longer case mufflers to quiet it down. For as little as the shops charge, it's not worth it to lay on your back and saw pipes off.
Triple Black 1971 GTO |
The Following User Says Thank You to NeighborsComplaint For This Useful Post: | ||
#1745
I think it’s got 14 inch case on it now, I may be wrong, it’s the 3 inch venom 300
#1746
![]() Quote:
As yes, the objective is to use as large a muffler case as possible to keep it on the quieter side. If the shop carries the mufllers, they can determine which is the largest that can be fitted. IMO, as quiet as possible without a performance hit is the best goal. You don't want to draw attention when you hammer it is my motto. .
The Following User Says Thank You to HWYSTR455 For This Useful Post: | ||
#1747
Get the 20” long 17749 Dynomax Super Turbos.
I have used them on a couple of my ‘64s and they’re quiet enough during normal driving but have a nice muscular sound when you hammer it. Bonus they flow better than the short 17734 mufflers.
The Following 2 Users Say Thank You to b-man For This Useful Post: | ||
#1748
Agree car is too loud but is gorgeous and done in excellent taste. Hope it stays reliable and issue free!!
Jeff |
The Following 2 Users Say Thank You to geeteeohguy For This Useful Post: | ||
#1749
![]() Quote:
Definitely use as large a case muffler as possible. On another note, no pun intended, but tips that point to the ground also help quiet it down some. Maybe go to the side splitters, and angle them down some. That would help. You have a full 3" system? You could go to 2.5 tail pipes, that would help too, and very little to no performance hit. .
The Following 2 Users Say Thank You to HWYSTR455 For This Useful Post: | ||
#1750
![]() Quote:
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
#1751
Drove it a lot last night and it jerks at low speed. Where should I start?
#1752
Maybe start by to dialing in the combination, working out the bugs and enjoy the car for a while. I didn't read the part about why the mufflers need replacing but if this was my project I'd hold off on that for a while.
Most likely the low speed bucking is carburetor related. |
#1753
I’m trying to enjoy it but it’s too damn loud LOL
#1754
Check your fuel pressure.
#1755
The 20" 17749's fit a '64 A body just fine.
My '64 GTO with the 20" Super Turbo's - and they are quiet enough so I can hear my stereo with the convertible top down. You already have the 3" pipes, so slipping in the 20" case 3" 17769's should be an easy fix to your problem. |
The Following 3 Users Say Thank You to The Champ For This Useful Post: | ||
#1756
20in case and 2 1/2 tail pipes.Tom
The Following User Says Thank You to tom s For This Useful Post: | ||
#1757
Just think now you’ll be able to listen to Johnny Cash, wink
The Following User Says Thank You to Gach For This Useful Post: | ||
#1758
Life ain’t easy for a boy named Sue
The Following User Says Thank You to 64speed For This Useful Post: | ||
#1759
I can remember in Junior high, 63-63, dresses all in black, like Johnny Cash. LOL
In 1952 I was 6 years old, Hank played Live at the calabrese club, here in Westerly RI. I was 6 years old, I went to see him with my uncles and my grandfather. I will never forget it. I remember it like it was yesterday. At my uncle funeral 40 years later the played all of Hank Williams songs, I sat there in tears. |
The Following 2 Users Say Thank You to Gach For This Useful Post: | ||
#1760
![]() Quote:
the camshaft jerking you around. Ya just got to get use to driveing it Don't lug it down so much cause you've got a rowdy cam there it sounds like to me. This is a stick car right? GT |
