Old 01-30-2004, 09:48 PM
Jason455 Jason455 is offline
I bought a bunch of pontiac stuff from a guy. I got and older pump with M-54D on it and another (looks newer) M-54D-S. I am just starting to reassemble my 428. Not sure which to use.
Old 01-30-2004, 10:02 PM
WARPed's Avatar
WARPed WARPed is offline
The ā€œsā€ means it comes with a pick screen, other wise they are the same pump.
with out questions there can be no answers
1969 Grand Prix
9.947@133.53(1.358)
6.246@107.91(1.342)
WARPed Tepee Forums
alex@pontiacgroup.com
1994 Formula
535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200
Pontiac Powered 4th Gen Project Progress
Old 01-30-2004, 10:46 PM
Are these the high pressure or high volume?
Old 01-30-2004, 10:52 PM
Goatman Goatman is offline
On Vacation
There are no HV Pontiac pumps. Just standard (60lb) and RAIV/SD (80lb).
PY's FIRST AND ONLY real live celebrity........
Old 01-30-2004, 10:53 PM
Brian Baker's Avatar
In addition to what Goatman said, if you want the high pressure pump, you need the "F" pump.
Old 01-31-2004, 10:55 AM
WDCreech's Avatar
WDCreech WDCreech is offline
And if you want a high volume pump with adjustable pressure, you can get a Titan, or if you can wait, I understand that BOP will be producing one.
Bill
Bill
64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs.
8.2550@164.17-1/4, 5.2901@131.97-1/8, 1.1981-60-ft. 8/10/08
Old 02-01-2004, 04:51 AM
Kenth's Avatar
Kenth Kenth is online now
I guess the standard oilpump with 5/8" pickup tube is not considered as a HV pump.
The oilpumps with 3/4" pickup tube are HV compared to the standard oilpump.
M54DS(60psi) and M54F 80psi)uses the 3/4" pickup tube.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 10-09-2023, 06:42 PM
Verdoro 68's Avatar
Same pump. I think the S just means it came with a screen.
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - 3.55 posi (build thread | walk around)
Old 10-10-2023, 10:57 AM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
you can also buy that pump from Summit with the screen already on and welded on !
63 Catalina coupe 455 budget drag car 11's 1/4 , 7.4 1/8th
66 Star Chief Executive 57k mile
69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2007 Hummer H3 3.7 liter turd
2019 Chevy Spark petrol car 38 mpg
