Old 01-20-2022, 12:09 AM
ZeGermanHam's Avatar
Originally Posted by 64speed View Post
I’m driving it
Cool! That will be fun.
1998 BMW 328is (track rat)
  #662
Old 01-20-2022, 09:50 PM
64speed's Avatar
64speed 64speed is offline
If this is an ill fit I’d hate to see perfect!
ID:	582317   Click image for larger version
ID:	582318   Click image for larger version
  #663
Old 01-21-2022, 11:31 PM
64speed's Avatar
Well glass man called. All the regulators and everything are in and all he has to do is wire it up and adjust all the glass. Hoping it will be ready next week instead of the month I was quoted. He said everything was in better shape than he anticipated so it didn’t take as long.
The Following User Says Thank You to 64speed For This Useful Post:
  #664
Old 01-22-2022, 12:51 PM
Bluesugar Bluesugar is offline
Very well done!
  #665
Old 01-24-2022, 06:15 AM
64speed's Avatar
Well I know this seems ass backwards but there is method to my madness. Car will be leaving glass shop this week and going to stereo shop. It is VASTLY cheaper to have the speakers and amp installed with no interior installed then coming back and revisiting that later in the game. I am dropping the front seat off to be recovered so I have something to put my ass in and then I will plumb the fuel system and check for leaks. Once I have a leak free fuel system then I will wire up the sniper and hit the key and see what happens.
  #666
Old 01-28-2022, 02:41 PM
64speed's Avatar
I can’t upload the video but I have working power windows.
  #667
Old 01-28-2022, 04:47 PM
geeteeohguy's Avatar
You're almost there. But, when you do go to fire it up for the first time, have a fire extinguisher handy just in case.
Jeff
  #668
Old 01-28-2022, 07:01 PM
64speed's Avatar
Didnt think of that. Thanks!!!!!
  #669
Old 01-28-2022, 11:50 PM
Yep, always have an extinguisher at the ready for a first start, and maybe also a blanket and/or rag to put out carb/throttle-body fires. Also be sure to check for leaks along the full length of the entire fuel system from stem to stern. I plan to keep an Element Extinguisher in my car at all times. They're more costly than standard bottle type extinguishers, but they are much smaller and won't wreck everything in the car if you actually need to use it like the bottles can.
https://www.summitracing.com/parts/efe-el40100
  #670
Old 01-29-2022, 08:03 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Better make sure it's Halon!!! You do NOT want to discharge a conventional, powder chemical, fire extinguisher on your car!
  #671
Old 01-29-2022, 11:57 AM
That's why I recommended the Element Extinguisher "sticks". Similar to a halon bottle, the sticks use gas to starve the fire of oxygen and not powder chemicals that will damage everything they touch. And they require no servicing, have no expiration date, and can easily be stored in a center console, etc. due to their small size.
https://elementfire.com/
  #672
Old 01-29-2022, 08:49 PM
64speed's Avatar
Here are the windows
https://youtu.be/ZCBE6R-5qDg
  #673
Old 01-30-2022, 09:44 AM
grivera's Avatar
grivera grivera is offline
very nice!!
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
  #674
Old 01-30-2022, 10:32 AM
64speed's Avatar
I ordered the element fire extinguisher cause summit said they only had 7 left
  #675
Old 01-30-2022, 10:38 AM
64speed's Avatar
So #1 lesson I have learned, take your dream car, look at prices, budget for it, then multiply by 3, tear that estimate up, and add double to it ��
  #676
Old 01-30-2022, 04:46 PM
Can confirm. I planned about $40k for my restoration, and after adding up literally every receipt I have so far, I'm over double that amount and have not even built an engine. It also depends on your starting point, though, and I knowingly started with a rusty car that I wanted to save for sentimental reasons.
It's always much, much less expensive to buy an already restored car.
  #677
Old 01-31-2022, 04:40 PM
Or, do what I did, and buy used 15 year old cars that nobody else wants because they're gas hogs. My '65 GTO with factory tripower and a 4 speed cost me a whopping $1200 in 1982, and my '67 GTO convertible set me back $1800 a year later. Back then, these were old, gas-hog, used cars. I loved the power and the practicality of a lot of room for friends and luggage. The years went by, both cars got engine paint refreshes, but were never out of service or not driven. I've got a total of about $8,000 invested in the pair. The drawback is you have to be an old guy like me to have been at that time and place in the first place!! You were just being born, IIRC!
Jeff
  #678
Old 01-31-2022, 04:55 PM
gtospieg gtospieg is offline
geeteeohguy...I was around then but in NY you weren't getting a GTO for that kind of coin and if you did it would've been real rusty. In '81 I bought a 66 OHC Tempest post for $200(still have the engine in the barn), a 67 Tempest for $100(restoring that now), and a 67 Lemans for $100(still have some of those parts).
  #679
Old 01-31-2022, 10:15 PM
64speed's Avatar
What size heater hose from the nipple on the timing cover to the back of the head fitting do I need. I don’t have the AC/heater hooked up yet and I wanna start it
  #680
Old 01-31-2022, 11:01 PM
I believe it's 5/8 and the other one is 3/4
