Old 04-06-2014, 12:44 PM
gtofreek's Avatar
gtofreek gtofreek is offline
Well, I found a good deal on a Victor intake that was like new, and a mega brace, lifter bore brace, at Pontiac Heaven yesterday. More parts and pieces to add to my car parts collection.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
  #42
Old 04-06-2014, 11:49 PM
gtofreek's Avatar
Hey Greg, I tried to sign up for a photo bucket account and it told me I already had one! So I signed in and there it was. I forgot all about having one.
I sanded the paint, primer, and rust off the dash today. Next week I will clean it and POR15 it, then epoxy primer it while the POR15 is still slightly tacky. Then I can fill the pits and get it ready for paint.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #43
Old 04-06-2014, 11:53 PM
gtofreek's Avatar
Some more.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #44
Old 04-07-2014, 12:26 AM
GOAT WHORE's Avatar
GOAT WHORE GOAT WHORE is offline
Nice work Paul, dash and photos. That dash looks way better already.
1969 GTO 4spd. Antique Gold/black, gold int.
1969 GTO RAIII 4spd. Verdoro Green/black, black int.
1969 GTO 4spd. Crystal Turquoise, black int.
1970 GTO 4spd VOE Pepper Green, green int.
1967 LeMans 428 Auto. Blue, black int.
  #45
Old 04-08-2014, 12:47 AM
gtofreek's Avatar
Well, my centerlink arrived today. Looks like a nice piece.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #46
Old 04-08-2014, 01:00 AM
gtofreek's Avatar
Was digging through stuff and found a brand new, still partially shrink wrapped, Hurst shifter handle. Forgot I had it.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #47
Old 04-08-2014, 01:01 AM
gtofreek's Avatar
Ran across the tach and gauges I cleaned up back in the 90's and wrapped in plastic bags to keep clean.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #48
gtofreek's Avatar
Ran across the heater control I restored back in the 90's also. I tried to match the gauge color by mixing metallic green and Pontiac silver/blue metallic engine paint. Not quite a match, but looks good anyway. Control works super smooth and easy now.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #49
Old 04-08-2014, 01:05 AM
gtofreek's Avatar
Here is one side headlight bezel. Other side will be on next post. Both had badly pitted anodizing on them which I bead blasted off. One was in so, so condition. One of these was crunched from when the front fender got hit. It was crumpled some on one end and was oval shaped instead of round. I pulled it back into shape by hand, then straightened the crumpled spots the best I could. Then I gently peened all the dents out from the inside with a small hammer and punch. Once I got the dents hammered out, I lightly hammered the high spots down on the outside. Then, I filed the outside until all left over high spots were leveled, then I wet sanded it down to 1500 grit and polished it with a buffing wheel and polishing compound. See if you can tell me which one was crumpled because I've been looking at them for 15 minutes and I can't tell which is which. After I peened all the dents out, I re-glass beaded it to hide the work, Now I can't tell.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #50
Old 04-08-2014, 01:06 AM
gtofreek's Avatar
Here's the other side.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #51
Old 04-08-2014, 01:14 AM
GOAT WHORE's Avatar
Some nice pieces for sure. That tachometer is golden! Price is around $450 to get one restored to factory style. The newer cheaper methods don't have the pointer dropping to zero with key off.
  #52
Old 04-08-2014, 08:55 AM
HWYSTR455's Avatar
And you're going resto-mod, right? I say if you can swing it convert to H4 headlamps, and run the headlight relays on the core support (M.A.D. version). Think I paid $24 each off egay for the AutoPal ones that came with hi/lo bulbs (they are glass, make sure before you buy). Also wired it so the hi & lo are on when hi is selected, much brighter.
With those Packard 56 terminals, you can make your own engine and forward light harness, fyi. If yours is the kind that uses Twin-lock connectors, lemme know, got those I can send. It's probably going to be less expensive & easier to make your own if you want upgrades and custom stuff. HEI, larger gauge power wire to the compartment, adding a Ford sol, using ATO fuse holders, relays, etc.
Quickie reference with resources too:
http://www.rowand.net/Shop/Tech/Auto...Connectors.htm
I use Waytek a lot.
Shame I dumped all my Muncie stuff....
  #53
Old 04-13-2014, 07:13 PM
gtofreek's Avatar
I got my dash POR15'nd today. First I washed it with Marine Clean[POR15 product], then I wiped it with a wet rag, then dried it. Marine Clean removes any dirt or oily residues that might interfere with adhesion. Then I used a brush to lay down some Metal Ready[another POR15 product]. This product etches the metal and leaves behind a zinc phosphate coating that creates a good base for POR15 to adhere to. Then I wiped it down with a wet rag and dried it with a heat gun to remove any moisture.
Here's a couple of pisc of zinc phosphate coating left behind.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #54
Old 04-13-2014, 07:14 PM
gtofreek's Avatar
Badly pitted, never to rust again!
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #55
Old 04-13-2014, 07:16 PM
gtofreek's Avatar
POR15 going on. I did it with a brush.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #56
Old 04-13-2014, 07:17 PM
gtofreek's Avatar
All done! I only used 7 teaspoons to do all this.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #57
Old 04-13-2014, 07:18 PM
gtofreek's Avatar
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #58
Old 04-13-2014, 07:19 PM
gtofreek's Avatar
I coated my window stops with Plasti-Dip. After I bead blasted them of course. Gave them 2 coats.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #59
Old 04-13-2014, 07:21 PM
gtofreek's Avatar
Did these stops also.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #60
Old 04-14-2014, 12:24 AM
GOAT WHORE's Avatar
Nice work this weekend Paul. Especially like the plasti-dip.
Also loving the full size photos!
