Old 02-09-2019, 03:13 PM
performerrpm's Avatar
performerrpm performerrpm is offline
Send a message via AIM to performerrpm
Default trans cooler line fittings in radiator 66
i have a radiator i use to run with a th400 and then swapped to a 4 speed. its a desert cooler 4 row. im now trynna reuse it in a auto car but i guess i took out the fittings that reduce it down to the size i need for the fitting on the lines to screw into the radiator.
anyone know what i need to order or have the fittings?.
i had some fittings in a 64 lemans radiator but they was too small
Old 02-10-2019, 12:50 PM
Ccass's Avatar
Ccass Ccass is offline
Administrator
I got mine at NAPA.
Old 02-10-2019, 02:22 PM
do u happin to know what the right name would be?...i can only imagine walking into the part stores around here trynna explain this...lol
Old 02-10-2019, 02:48 PM
Ccass's Avatar
Administrator
I called them radiator to transmission line adapter fittings. They had every imaginable combination.
Old 02-10-2019, 03:09 PM
cool deal....guess ill be headin to napa
Old 02-11-2019, 03:30 PM
HWYSTR455's Avatar
Dorman Transmission Line Connectors 800-755
https://www.summitracing.com/parts/r...-755/overview/
Old 02-11-2019, 10:16 PM
thanks....it actually ended up taking a 5/8 18 to 1/2 20 inverted flare fitting....ransacked 4 parts stores to find just 1 the right size....was fixing to cut the ends n buy a regular trans cooler
