Old 09-21-2023, 04:19 PM
Speargun's Avatar
Speargun Speargun is offline
Default IA Block Distributor Hold Down?
I'm finally getting around to installing my IA block so today I primed it (after draining the oil and removing the oil pan to retrieve the dropped intermediate shaft) and installed the distributor.
When I put the distributor hold down clamp on, it doesn't work. (See pic below) I tried a couple of different hold downs with the same result.
So what is the go to hold down for IA blocks?
No!
Do not try!
Do! Or do not.
There is no try. - Yoda
1967 Firebird Restoration 2005 - 1/25/2017
Old 09-21-2023, 04:47 PM
Schurkey Schurkey is offline
I'd be asking why the block isn't properly machined.
Block looks rough-cast where the back-end of the hold down rests, and the dimensions aren't correct.
Old 09-21-2023, 04:57 PM
steve25 steve25 is offline
Has that dizzy and hold down ever been run before?
it looks like the arc in the hold down is either too small or that the OD of the dizzy down at the hold down lip is too big.
Also there needs to be a washer under the head of that bolt.
Old 09-21-2023, 06:05 PM
Speargun's Avatar
The hold down came off of the 400 I just pulled out of the car.
The dizzy is new. It came with the Edelbrock pro flo 4
Washer will get added when I find a clamp that fits.
No!
Do not try!
Do! Or do not.
Old 09-21-2023, 06:17 PM
grandam1979 grandam1979 is online now
That’s a aftermarket hold down Pontiac hold downs are not flat and don’t have a slot just a bolt hole.
Old 09-21-2023, 06:41 PM
Verdoro 68's Avatar
Example of a factory distributor hold down with the step down. Looks like it would solve your problem.
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around)
'95 Comp T/A #6 M6 - bone stock (pics)
The Following 3 Users Say Thank You to Verdoro 68 For This Useful Post:
Old 09-21-2023, 07:00 PM
Speargun's Avatar
Looks like I need to find my factory style hold down. The one in the pic came off of my 400 & worked just fine on it, but the IA block must be different. (correct?)
No!
Do not try!
Do! Or do not.
Old 09-21-2023, 07:07 PM
jhein's Avatar
jhein jhein is offline
I have an OE style clamp like the one picture above on my IAII block and it works perfectly.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
Old 09-21-2023, 07:08 PM
jhein's Avatar
I believe that the pedestal it sits on is taller on the IAII.
Old 09-21-2023, 08:11 PM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
Looks like the wrong hold
Down as everyone has said get a factory style no issues
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 09-21-2023, 10:32 PM
Speargun's Avatar
I found a factory clamp and that solved the problem.
I do think that the IA block IS a little taller than factory though.
Thanks1
No!
Do not try!
Do! Or do not.
The Following 2 Users Say Thank You to Speargun For This Useful Post:
Old 09-22-2023, 06:46 AM
That looked like a Chevy clamp maybe just made it on the 400 block Glad you figured it out
1964 540 gto
Old 09-22-2023, 10:04 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I had one repop factory style hold down bracket that was soft. It slowly flexed and loosened over time again and again. Found a factory one and no issues.
Skip Fix
Old 09-22-2023, 02:58 PM
mgarblik mgarblik is offline
I have had 1 or 2 of the early IA blocks that had some minor issues in that hold down area. First, try a factory hold down that has the legs bent down like in the pics. If that does not give you enough clamp to hold the dist. tight, try this. I had an IA block that needed an ARP stainless stud installed. Before I installed the stud I had to bend it 20 degrees or so to get the clamp to fit the distributor right and clamp it tight. PLEASE, if you go the stud route, bend it FIRST, then install it. If you strike it to bend it while in the block, you might break the block back there. Then you have a real problem.
