Old 03-07-2020, 12:01 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
I've got 2.5" pipes with an X and Ultra Flows and it drones like crazy at 2k rpms. Outside of the drone zone they sound great.
Chris D
Old 03-07-2020, 06:54 PM
nmoreilly nmoreilly is offline
PYPES X system in both cars - 66, 69 GTO - with the Race Pros which I like a lot. There is a bit done but definitely not fatigueing
Old 03-07-2020, 08:21 PM
BLANK1's Avatar
BLANK1 BLANK1 is offline
Jones Max Flow mufflers or the new Flowmaster FlowFX mufflers.
Old 03-07-2020, 09:31 PM
DOC DOC is offline
Not sure where you are located but I have a 3" Pypes w/ X pipe, Dynomax ultraflows from headers to tailpipes in good condition I just took off a 78 T/A because I wanted to go back to a cross flow muffler. If your interested. PM me. Located in Jacksonville Fl
Old 03-08-2020, 09:03 AM
allenga allenga is offline
Originally Posted by JLMounce View Post
I'm a little confused. Your picture shows an X pipe, but you state you had an h pipe installed. Is the picture you posted not of your car and just a stock image of a like system?
There is a general rule of thumb on muffler type that fits different cross-overs. If you go with an H, you typically want a chambered muffler like a Flowmaster. If you go with an X pipe, you generally want a packed muffler like what pypes sells, or a magnaflow etc.
Putting a chambered muffler behind an x pipe is a recipe for massive drone.
Spinttech doesn't really say on their site if their mufflers are a straight through packed design or if it is a chambered design, or a hybrid of the two.
Regardless, if the car is rattling itself, that is also some of the resonance you're getting. How you deal with that is by adding a constrain layer to the body panels (usually floor boards) that are resonating. This is your typical dynamat product. 70% coverage on large flat panels will reduce harmonic resonance by quite a bit.
Follow with a mass loaded vinyl on top of areas around the mufflers and you'll knock down a good bit of the sound that the muffler is putting off itself.
Thank you. Sorry, I meant I have X pipe. Floor boards are covered with dynamite like product and another layer of heat insulation.
Old 03-08-2020, 09:05 AM
Originally Posted by coonhunter70 View Post
Dynomax or Goerlich xcellerator
These Xcelerators are interesting but no one promotes them but RamAir Restorations.
Old 03-08-2020, 09:07 AM
Thank you. There is a hands width between floorboard and muffler.
Old 03-08-2020, 09:10 AM
I would love this sound. https://www.youtube.com/watch?v=BoQdGQpwZk0
Old 03-08-2020, 02:40 PM
wovenweb's Avatar
wovenweb wovenweb is offline
Be careful!!!!! Oh, dynomat, lol.
1971 Pontiac Trans Am Cameo White
1968 Firebird 400 convertible, Verdoro Green w/black top
1970 Buick Skylark Custom convertible(driver) Fire Red
Old 03-08-2020, 03:51 PM
Chris-Austria Chris-Austria is offline
I use the FlowFX on my 66 GTO (462cui) and there is very little drone, nothing I would complain. I use an H-Pipe and 2.5" piping.
Just a nice deep sound
Old 03-09-2020, 08:34 AM
Larry Navarro's Avatar
Jones Max flow mufflers are similar to the dynomax or goerlich designs, oval case, offset or straight through, perforated tube surrounded with noise suppression packing. I use the ones available on ebay. About $40 each. Sound great with no drone.
The Following User Says Thank You to Larry Navarro For This Useful Post:
Old 03-09-2020, 01:22 PM
Lee's Avatar
Lee Lee is offline
Tom Hand recommended these to me over 15 years ago. I've used two sets, one on a low-11 Pontiac and the other set on a mid-10 stroker Ford Windsor. Great performance, surprisingly quiet (for the large case versions, at least).
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
My webpage http://lnlpd.com/home
Old 03-09-2020, 01:28 PM
Navy Horn 16 Navy Horn 16 is offline
This thread makes me appreciate my military related hearing loss.
I run 3 inch electric cutouts, and they dumb right behind the driver's door. I made a 3 hour road trip yesterday with them open, and it didn't bother me a lick. I really like the stupid face I get from Prius drivers when I drop a gear and pass em at WOT. It's only when the sound bounces off their car that I really notice it.
77 Trans Am, 469 w/ported E-Heads via Kauffman, matched HSD intake, Butler Performance forged rotating assembly, Comp custom hyd roller, Q-jet, Art Carr 200 4R, 3.42s, 3 inch exhaust w/Doug's cutouts, D.U.I. Ignition. 7.40 in the 8th, 11.61@116.07 in the quarter...still tuning.
Old 03-09-2020, 01:33 PM
Do they sound like this? . https://www.youtube.com/watch?v=BoQdGQpwZk0
Old 03-09-2020, 03:46 PM
Lee's Avatar
Lee Lee is offline
Yep, pretty much sound the same on my cars. Here is an in-car video, from the track. https://youtu.be/tHpXgrPAKmE?t=16
Old 03-09-2020, 04:51 PM
Dick Boneske's Avatar
I installed a 2 1/2" Pypes X pipe system on my '64 GTO in 2010. I used the Pypes mufflers, the quietest of three they offer. It's a 4 speed, 428, with '67 HO cast iron exhaust manifolds, 3.23 gears, so I'm running about 3000 rpm at 70 mph.
There is no drone whatsoever. The sound is a little "raspier" than stock OEM mufflers, but quiet inside the car while on the highway.
Name:	Engine & Detail GTO 016.jpg
ID:	534176   Click image for larger version
Name:	Engine & Detail GTO 014.jpg
ID:	534177   Click image for larger version
BONESTOCK GOATS
'99 Bonneville SE Sedan
The Following User Says Thank You to Dick Boneske For This Useful Post:
Old 03-10-2020, 08:24 AM
I use the XLerators a lot, as well as the Dynomax Super Turbos. The Goerlich's have a more raspy sound and do wake up when you stomp on it. The Super Turbos are more quiet than the XLerators. Either in a short case get louder, obviously. Both last about the same time.
Another example of the XLerators:
https://www.youtube.com/watch?v=R2Od_KQq1ms
It does boil down to personal preference at some point, but with H or X pipe, either I have never had any drone with over the axle tailpipes.
  #38
Old 03-10-2020, 09:37 AM
63gpman's Avatar
63gpman 63gpman is offline
Maybe I missed it, but I assume you have tail pipes and not just dumps at the mufflers?
Brad Hansen
65 Cat Ventura, 66 Cat Vert, 63 GP
  #39
Old 03-10-2020, 09:48 AM
Yes, tail pipes and X pipe.
  #40
Old 03-11-2020, 01:04 PM
moontower69's Avatar
moontower69 moontower69 is offline
Default Dynomax super turbo 17749
The Dynomax Ultra flow will still drone.
Get the #17749 DM super turbo (offset/offset) with 2.5 pipes and it will rumble like stock muscle from 70s and still roar a bit when you mash it down.
Its the only way to go if you value your ears, sanity and want to be comfortable on long trips talking to people in your car or on phone.
1974 Lemans Sportecoupe GT (daily driver)
"Well the girls out there knock me out, you know
Cruisin' around in my GTO"
Rock 'n' Roll High School
Ramones
The Following 2 Users Say Thank You to moontower69 For This Useful Post:
