Old 10-27-2021, 03:32 PM
ZeGermanHam's Avatar
Default Wanted: Engine Pulleys
Hi all. I am in search of the following engine pulleys:
- 2-groove crank pulley for 1968-70 with AC & PS, part# 9790842 YB
- 1-groove crank AC pulley (goes behind main crank pulley) for 1968-70 with AC, part# 9790843 YC
- Water pump pulley for 1970 with AC and PS, part# 9799128 XT
- Power steering pulley for 1967-70 with AC, part# 9786901 XH
- 4 bolt washer to hold the crank pulley
Thank you!
1998 BMW 328is (track rat)
Old 10-27-2021, 06:32 PM
rockys1970 rockys1970 is offline
Default 1970 Pontiac Pulleys Wanted
I have two of the items listed.
1. 9790843YC single groove A/C crank pulley
2. 4-Bolt Support Washer
PM me if interested.
Thanks,
rockys1970
Old 10-27-2021, 06:57 PM
Thanks,
rockys1970
PM'd, thanks.
Old 10-27-2021, 11:09 PM
70ra455's Avatar
70ra455 70ra455 is offline
I have the p.s. pulley but it's attached to the pump and bracket. If interested text me at 908.208.7778
1970 GTO Convertible 455 Ram Air M-21, Atoll/Blue/Black, Hood Tach, 3:31 12-Bolt Posi, A/C, Console
1966 Grand Prix 421 Tripower 4spd, Marina Turquoise/Turquoise, a/c, console, posi, reverb. pa, pb, ps, remote mirror, mats
2010 Dodge Challenger R/T Classic, 6spd Hemi, Detonator Yellow, black stripe, black leather
Old 10-28-2021, 12:26 PM
BLACK70GTO's Avatar
BLACK70GTO BLACK70GTO is offline
Default pulleys
I have them all except for the power steering pulley.
Contact me if you want them.
Thanks David
Old 10-31-2021, 03:00 PM
Thanks David
PM'd. Thanks.
Old 11-01-2021, 06:52 PM
tri.lllgto tri.lllgto is offline
Default pulley
I have an 842
Old 11-01-2021, 08:20 PM
Thanks. I have located the crank pulleys and washer. Now just looking for the following items:
Old 11-03-2021, 07:26 PM
23337 YT's Avatar
23337 YT 23337 YT is offline
If you are still looking for the 9786901 XH power steering pulley, PM me.
Old 11-05-2021, 10:28 PM
Still on the hunt for a 9799128 XT water pump pulley.
Old 11-06-2021, 08:02 AM
Half-Inch Stud's Avatar
i probably have the XT water pump pulley, in Nice cond. On travel will check in Sun PM
Old 11-06-2021, 08:09 PM
Thanks, appreciate it!
Old 11-10-2021, 01:37 PM
Just following up to see if you've had the chance to take a look for that water pump pulley. I'm still on the hunt for one. Thanks.
Old 12-09-2021, 12:39 PM
Christmas has come early! I'm very happy to report that I can finally close this thread out. It took much longer than expected to find a 9799128 XT water pump pulley. It was the last piece of the puzzle I needed. Many people kindly reached out here and on Facebook thinking they had one, but it in all instances except one, they either couldn't find it or had the 481040 XT pulley instead (same diameter, but different offset). I can't imagine what life would have been like trying to restore a car before the internet.
Old 12-09-2021, 04:02 PM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
What would #9799130XJ two grove pully be used on??
Old 12-09-2021, 04:26 PM
Not sure what the 9799130 XJ pulley is for.
Old 12-10-2021, 01:03 AM
63Longtop's Avatar
63Longtop 63Longtop is offline
130 is a 1970 AC, it will work to replace the 128
Old 12-10-2021, 01:54 AM
Based on what little info I could find online, they appear to not be the same dimensionally, though. The 9799128 XT is 6.5" diameter and 2.75" deep, whereas the 9799130 XJ is 7.125" diameter and 3.00" deep.
Old 12-11-2021, 12:15 PM
63Longtop's Avatar
Depths are the same, I have both for reference.
Old 12-13-2021, 12:22 AM
Is the diameter where they differ then?
