Old 08-07-2020, 05:44 PM
pilot737 pilot737 is offline
Default Trunk paint 67 GTO
What is the correct paint for inside trunk area? 1967 GTO
It looks like a black/speckled-white type paint.
Can one find it locally at hardware or paint store?
Or is ordering from Ames the only way?
Old 08-08-2020, 01:09 PM
OG68 OG68 is offline
No it isn't.
https://www.thorntonmusclecars.com/p...ge/guru-colors
2007 Cadillac SRX
Old 08-08-2020, 03:32 PM
Jeff Hamlin's Avatar
Thumbs up
EASTWOODS Grey-White lays out real nice.
Buy more than it recommends, better to have to much then not enough.
I then use a Satin Clear to top coat.
https://www.eastwood.com/ew-trunk-pa...hoCsCIQAvD_BwE
Old 08-08-2020, 03:45 PM
Is there a reason not to use one of the two products sold by Ames?
AC Delco or Eastwood... half the cost but comes in one can.
I'm doing some 'touch-up', not the whole trunk.
But maybe the 'all-in-one-can' doesn't work very well?
And I found a DupliColor brand trunk paint locally at OReillys. (haven't purchased yet)
Old 08-08-2020, 04:04 PM
Default Trunk paint
Hi Jeff, I see you live near Va Beach. I'm in Charlottesville. Thanks for the tip...I know Eastwood is a quality product.
Why grey/white? I thought 67 GTO was supposed to have black/aqua?
Old 08-08-2020, 07:37 PM
Default My understanding of trunk painting...
'64 GTO was the un-spattered year.
'65 IIRC could be either Black/White or Black/Aqua.
'66 was Black & Aqua not sure if any were sent out with Black/White spatter.
'67 most I've come across were Black/White.
FWIW (Refinished one that had signs of the OE so I matched it)
'68 I'm not sure.
Old 08-08-2020, 09:11 PM
ZeGermanHam's Avatar
'68 I'm not sure.
Not to hijack this thread since I have a '66, but the original spatter paint in my trunk was a lighter gray with white specs. Is this what you consider "black/white"?
1998 BMW 328is (track rat)
Old 08-08-2020, 09:34 PM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
Default '67 Fremont GTO
Original finish...
Old 08-09-2020, 01:27 PM
brad900 brad900 is offline
I used The Parts Place splatter paint. Everywhere I read it's the only one that holds up. Smells really good when spraying, smells like a candy store.
Old 08-09-2020, 01:49 PM
mgreen0104 mgreen0104 is offline
Default 67 & 68 GTO trunk paint color
Hi,
I could be wrong but I think the 66 carried a black/white spatter or splatter paint. The 67& 68 GTO trunk paint code calls for a turquoise/black spatter paint. Slightly different from the 66 GTO. I purchase my paint from the local PPG paint supply store. SEM or 3M has the proper paint code and texture.it cost $8-12 dollars only needing two cans for proper coverage. 3 cans if your going for a heavy textured look also. The product works great! Hope this helps.
The Following User Says Thank You to mgreen0104 For This Useful Post:
Old 08-09-2020, 04:44 PM
Default trunk paint
[QUOTE=428ho4spd;6167997]Original finish...[/QUOTE
Thanks. Hard to tell from the picture. Is that black/grey or black/aqua?
I think mine is also the original paint but hard to tell if the splatter is grey or aqua. I suppose it doesn't matter that much; I'm planning to sand and touch-up a few small areas.
Name:	trunk paint 4.jpg
Old 08-11-2020, 03:03 AM
lust4speed's Avatar
Looked at my '67 original trunk paint today and what is left of it is black/aqua.
Mick Batson
Old 08-11-2020, 08:21 PM
RedDirtRoad RedDirtRoad is offline
Is this the monthly trunk paint thread?
Haha. We been over this before
