Old 09-16-2020, 02:48 PM
rohrt rohrt is offline
Default Factory sway bar sizes front and back
Does anyone have a list of factory sway bar sizes over the years?
I would like to put a rear swaybar on my tempest and the front one is really small.
I found a WS6 sway bar and another that just a little smaller not sure what from for possibly the front but don't want to ruin the nice ride quality by over doing it. At the same time I don't like feeling like I will tip over going around corners.
Old 09-16-2020, 04:37 PM
Bill Hanlon's Avatar
Sway bars should have little to no effect on ride quality while driving in a straight line.
The Following User Says Thank You to Bill Hanlon For This Useful Post:
Old 09-16-2020, 04:59 PM
OG68 OG68 is offline
Generally you want the rear bar to be smaller than the front.
1 to 1 1/8" front, 7/8" rear would be fine for a cruiser Tempest.
If you want to step it up a bit using factory style parts, a 1 1/4 front and 1" rear would work also. This may require some strengthening of the front bar mounting holes
2007 Cadillac SRX
Old 09-16-2020, 06:26 PM
The Champ's Avatar
I went from the factory front bar on my '64 to a WS6 bar and the only thing that changed was the handling - not the ride. Prior to that I had added an NOS rear bar.
Old 09-17-2020, 05:06 AM
Geoff Geoff is offline
Be aware that there is a downside going too big on a/roll bars. Bigger AR roll bars will make the ride harsher under some conditions
If the wheels hit a depression [ or raised section ] in the road such that both wheels on that axle deflect the same amount, there is no change in ride quality. If ONE wheel hits a bump or pothole, then the AR rate gets added to the spring rate to increase ride harshness on that side.
I removed the 1.25" front AR bar on my 66 & went back to the factory 15/16" bar because the comfortable ride was more important to me than hurling around corners at great speed.
Old 09-17-2020, 08:45 AM
Aluminum Chief's Avatar
Aluminum Chief Aluminum Chief is offline
Default Sway
I agree I just purchased a 67 GTO with a huge aftermarket front sway bar and after removing it the car went from riding like a truck to riding like a Cadillac. I will be installing a factory 15/16 sway bar in the near future.
KC
Old 09-17-2020, 09:38 PM
marxjunk marxjunk is offline
KC
what brand? if they come up for sale let me know...
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 09-18-2020, 05:02 PM
This is basically many roads in Iowa. And the reason for the question. As I said I like the plush ride but don't like how it corners. I certainly don't want to put the biggest bar I have on it. I was thinking a more conservative approach.
Old 09-18-2020, 06:07 PM
Default Bar
I don`t know what brand it is but I think it was purchased from Ames.
I might be selling it with the links.
Also removed the rear sway bar.
KC
Old 09-21-2020, 11:58 AM
I finally measured mine last night. Look like the front is 15/16 as well. So no difference between the GTO and tempest..
What was the factory size of the rear?
Old 09-21-2020, 12:25 PM
ZeGermanHam's Avatar
Be aware that there is a downside going too big on a/roll bars. Bigger AR roll bars will make the ride harsher under some conditions.
This. Sway bar diameter absolutely has a direct impact on ride quality, since the sway bar is a heavy gauge spring which physically connects one side of the car to the other. Stiffer the bar, the more upset the suspension will become if you hit a bump on one side but not the other.
1998 BMW 328is (track rat)
Old 09-22-2020, 09:21 AM
I have also found that if you change out to stiffer springs you really don't need to go crazy on a sway bar
Old 09-22-2020, 11:10 AM
Yep, absolutely. A byproduct of installing stiffer springs is less reliance on the sway bar to control body roll. That said, I'd never recommend installing stiffer springs if your only goal is to reduce body roll, because you'll impact ride quality at all times with stiffer springs, versus only some of the time with thicker sway bars. But you're absolutely right - if you happen to be installing stiffer springs for other reasons, you won't need to go crazy with sway bars.
Many race cars don't even have sway bars, because they sometimes handle body roll entirely with the springs. Obviously you can't get away with that on a street car, since the springs would have to be so stiff that you'd rattle your fillings out.
