#61
I have received mine but I haven't had a chance to hook it up yet. Hopefully I'll be able to do so on Monday and I'll test mine out.
It might be a worthwhile experiment to see if you try a different reistance source (a light bulb hooked directly to battery or similar) to see if that would make your alt work, given that it tested okay. Not to dispute the BBB guy but I think most modern cars will have a PCM somewhere between the alt and the dash lights. I know that there are two types of CS144s and some don't have an "L" terminal, but an "I" (I think) and thus requires a slight change in the way it is wired, but will still work. I dropped my alt off at my storage place for my car, so I can't verify the terminals present at the moment. In any event, I'll give it a try on Monday and post back here. Last edited by myckee; 07-01-2010 at 06:39 PM. |
#63
I just had this happen to my CS144 the day before yesterday! I was running my 66 up through the gears and heard a loud bang (sounded like a backfire through the exhaust) at the top of 3rd (less than 6k RPM). I thought it went lean (I've been messing with the end carbs.). I couldn't replicate what I thought was the lean condition while recording with the LM-1. When I got home, I noticed that the plastic part of the alternator fan was GONE, leaving the metal disk. Fortunately, I can't find any damage under the hood anywhere, but the thing definitely came apart. I am hesitant to put another plastic one on there, but I don't want to burn up the alternator either! I have the metal one off my old alternator on there for now. Are there any all metal fans that are as efficient as the plastic ones? |
#64
Is there any reason that I could not go higher than 140A? The new stuff and a lot of performance alternators are coming in around 200-250A.
My Tempest is almost all electric. I have the 100A alt and a yellow top deep cycle Optima and at idle with the stereo, fan, blinkers and lights on, it is a BIG drain on the bat. Thoughts?
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!! 1990 Chevy Suburban R2500 Daily Driver 1986 Volvo DL245 Wagon.. Project car!!! The Burb Files |
#65
Like I mentioned above, v-belts won't hold anything over 140a, and even slip at that. You glaze the belt quick, starts slipping, and the charge falls off. Serp is the way to go, and if you do, you can toss a 350a on there!
As for idle, not sure if I mentioned it in this thread, but you need an alt that has a high rating at idle, not peak, like something for an ambulance or police car. Most companies don't provide an output graph to RPM (alt spindle), which is the problem. It will most likely be a custom, and you will pay. Your 140a probably only puts out like 30a at idle, which is the problem. Shoot for a '96 caprice police model, see if that helps. You can do the math, using roughly 70% peak load for your rating on the alt. For example, if you have a peak load of 100a, you need a min of a 70a alt, and you can;t be in peak load more than 30% of the time. Roughly. I'm getting by with a 105a, and I have fans that draw 30a+ when they kick on. That, with the stereo, fuel pump, and at idle, with your foot on the brake, AC on, it dips. But it does catch up. .
#66
They will put the v belt on, but you said that it will glaze. Is that due to the drag on the belt? Why? I just have not seen it. Plus as stated, the belt is almost180* around the thing. Yeah, my crappy 140A that died was most likely fried cause of low output at idle. My Summit 100A is bulletproof!!!
#67
It's because of load. Once youu put a load on it, and the regulator kicks in, it goes full output, and loads the pulley. Not sure it having the belt 180 around the pulley would help, kind of doubt it, think it will still slip. I tried everything, different kinds of belts, those stupid green ones (don't do that, by the way), different and NEW pulleys, everything, they slipped. Dropped back to a 105 and problem gone. Went with a marine battery, largest that would fit in the tray. Only time I have a problem is sitting at idle at night with the AC on and have the fans kick on, but I can toss it in neutral and give it some gas if I have to.
140a alts are overdriven (regulated) 105s, and they don't take too kindly to that. Same with the 200s. The 130Ds and 144Ds are better alts all around, fyi. .
