Old 10-11-2016, 11:15 AM
JC455 JC455 is offline
Originally Posted by rjpaige3 View Post
The center caps, I tell you, I managed to impress myself with how they came out. Okay, no mods to the lucite, the secret is in turning the caps themselves. I had a machinist lathe out the recessed logo center and open a hole just the right size for the emblems to seat in. Then I got some 2" ABS cleanout caps from the plumbing aisle at the hardware store. Cut off the wrench square, file/sand the top mostly flush. Place the emblem in the metal cap, press in the plastic cap top-first in behind it, and done! The press fit is tight enough that you can hand seat the caps in the wheel bore without having to worry about contacting the lucite, just soap up the rubber o-ring a little. Also, ignore the setscrews, I was going to drill and tap two holes in each cap to anchor the plastic, but it feels unnecessary.
VERY creative!! I like that!
John
IG: @crawdaddycustoms
YouTube: https://www.youtube.com/channel/UCK9...Nc_lk1Q/videos
  #222
Old 10-12-2016, 12:00 AM
rjpaige3 rjpaige3 is offline
Thanks, and one little update. It turns out the plastic takes a set and gets less snug than initially though, so I ended up needing the setscrews after all. Now they are rock solid.
  #223
Old 02-17-2017, 04:15 PM
Zyman's Avatar
Zyman Zyman is offline
Originally Posted by 1966Lemans View Post
No 17" or 18" tires available with white letters.
Go to tirestickers.com and design your own.
"Pride Precedes The Fall"
1968 Firebird Undergoing Transformation
1970 Formula 400 - Keylime Green, Stroked to 462 Cubes - Gone But Forever Remembered
2016 Mustang GT - GT with the Performance Pack, beats my former 12 Boss around the track.
  #224
Old 03-04-2017, 06:56 PM
Zyman's Avatar
Default Finally Made the Purchase
Went with 18"x9"; 275/40/18
  #225
Old 12-10-2017, 07:08 PM
jeff1969gto jeff1969gto is offline
I did a little homework, it's not verified, but what I came up with so far is the C5/C6 brake setup has a caliper offset of .790 - .812, so not sure these will clear. I have ATS AFX spindles, and the Touring Classics brake setup, which may be a hybrid setup, that too is not clear, Touring Classics is out of business, so templates are not available.
I guess I'm stuck having to measure, unless I can find someone with one of the templates. Maybe I will post over at pro-tour, see if someone over there can come up with something.
Can you let me know in a PM please I have a 1969 pontiac GTO with the ATS spindle and a wildwood brake kit
  #226
Old 12-10-2017, 07:26 PM
HWYSTR455's Avatar
Look at post # 109, I used the template for the hybrid C5/C6 brakes, and yes, they fit. I posted measurements from the template, so you can compare to the Wilwood template and figure out if they fit.
  #227
Old 12-11-2017, 06:48 PM
NeighborsComplaint's Avatar
I bought these to just stick on the existing Bandit center caps. Fit exactly inside the embossed ring.
https://www.ebay.com/itm/4-Pontiac-H...JXRbrh&vxp=mtr
  #228
Old 12-11-2017, 06:52 PM
Originally Posted by Zyman View Post
I include this link for illustrative purposes and not to advertise, endorse or comment in any way on the seller. But it looks like attaching PMD center caps should be achievable.
I tried the bolt on caps. Nothing to center the cap on the hub, retaining stud hit the spindle dust cap. Did not try the "drive in" caps.
  #229
Old 12-11-2017, 08:34 PM
Zyman's Avatar
Darn photo bucket. Try this.
Name:	IMG_0732 smaller.jpg
  #230
Old 12-28-2017, 02:36 PM
Bob's GTO Bob's GTO is offline
I had to make my own mounts, but I think the caps fit great.
  #231
Old 12-28-2017, 02:55 PM
Overkillphil's Avatar
Zyman, looks great! Same rim/tire size all around?
  #232
Old 12-28-2017, 03:01 PM
18 X 8 in front, 18 X 9 in back
  #233
Old 12-28-2017, 03:37 PM
Zyman's Avatar
Yes. 18x9 rims, 275/40/18 all corners. I plan to replace the fronts with 255/40/18 for clearance at full lock issues.
  #234
Old 01-27-2018, 02:11 AM
72blackbird 72blackbird is offline
Zyman,
Looks pretty good. I'm annoyed with Photobucket myself- here's a recent pic of my Bird with the Bandits. Not alot of rubbing- most of it is due to a tired suspension (that's getting addressed in 2018).
Geno
  #235
Old 01-27-2018, 08:59 AM
DevoBuzz's Avatar
DevoBuzz DevoBuzz is offline
Anyone get a chance to weigh these wheels yet? The Year One wheels weigh a ton.
1972 LeMans
461 stroker 10.3:1
Edelbrock D ports Scorpion 1.5 rockers
Comp Cams "Stump Puller" roller
Holley Ultra Street Avenger 770
Ram Air III exhaust manifolds
2.5" pipes Dynomax VT w/crossover
Edelbrock Performer RPM
TH350 2.78:1 10 bolt
  #236
Old 01-27-2018, 12:32 PM
1966Lemans's Avatar
1966Lemans 1966Lemans is offline
Originally Posted by 72blackbird View Post
Zyman,
Geno
That is freakin' sweet looking!
'67 Piper Cherokee
'66 Lemans
  #237
Old 01-27-2018, 12:59 PM
skullbucket's Avatar
skullbucket skullbucket is offline
It says in the ad they come in 15s but I haven't found 15s anywhere that sell them????
1972 Grand Prix
  #238
Old 01-27-2018, 08:10 PM
FrankieT/A's Avatar
That's what I'm looking for...
  #239
Old 01-28-2018, 01:16 AM
Thank you sir!
  #240
Old 01-31-2018, 03:47 PM
The Cast rims only come in 17/18" sizes, the Forged versions are available in 15-20" sizes.
John
