#41
How many RPM is the alternator turning at when the engine is turning 6000 rpm? I guarantee it is faster; unless you have a 1 inch diameter crank pulley. Some Pontiacs have 8" crank pulleys. Please share your knowledge of pulley diameters and ratios GM used while testing, RPMs, heat tests etc. As well please post the tests which show it to be of a superior design as opposed to a cost saving one? I'm waiting with bated breath. lol |
#42
Derek B. Current best: 11.97@110 1.65-60' !!! '74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets. 1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram. |
#43
It depends if you are using a dash light or not. If you are using a light, which the alt senses as resistance, and thus turns itself 'on', you would use D1-W1201. If you have no warning light hooked up, then you would use D1-W1204. It has resisters in the wires which the alt senses instead of the dash light and excites itself.
Interestingly, back to the plastic fan topic, I was perusing Rock Auto's catalogue today and all of the truck applications (that I checked) come with the steel fans, regardless of model number whether it is a cs130 or cs144 etc. This cursory research shows only the cars and mini vans had the plastic fans, and the alts used in heavier duty applications used steel, "50+ year old relic" fans. |
#44
I ask because i dont think i have ever seen a car WITHOUT an idiot light for the alt. Not sure if im missing something i guess.
Yes i have an ''alt.'' light so i guess that answers my question.
#45
hydrogen embrittlement.
Well originally my car had a volt light in the standard gauge cluster, but when I swapped it out for the T/A gauges, there was no light that I recall; just the volt gauge. I have since changed over to all Auto Meter guages and have no light, although it would be a good idea to have to bring attention to the gauge should the fan belt break or something. So in my case I guess I would have to use the resister type.
#47
I learned about chrome causing embrittlement in airframe and powerplant school. Chroming aircraft parts, especially a propeller, is a big no-no. Here's a good read on the subject: http://www.moldmakingtechnology.com/...es/040208.html |
#48
I keep hearing belt slippage. With higher amp alternators. I am curious to how it would sound. Is that in just race cars? I haven't had any issues with my 140A, but I keep hearing slippage.
My belt have almost 180* of coverage on the pulley.
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!! 1990 Chevy Suburban R2500 Daily Driver 1986 Volvo DL245 Wagon.. Project car!!! The Burb Files |
#49
Can't always HEAR belts slipping. There is some simple math involved, load vs. belt contact area, though it doesn't tell the whole story. I've had a perfectly good alt not charge to par because a belt was slipping, and you couldn't hear anything. IMO, always change the belt when replacing the alt, regardless if it looks good or not.
V-belts have a limit, the contact area/load thing, and in my experience, 140a is that limit (load). Even at 140a, the belt slips, and it has to be replaced often. One good way to monitor is with a volt gauge, and when you see that the 'normal' steady-state volts seem to be slightly lower than usual, it's usually the belt slipping. The best solution is to go to serpintine, then you can run any amp alt you want. Chrome alts also retain heat, and cook diodes/regulators, etc, early. Powermaster used to offer a coated (black) alt that was supposed to dissipate heat better, not sure if they still do, or if it offered any gain. To one-wire or not, now that one takes a little homework.... .
#50
No to one wire. Also keep in mind the CS-144 (possibly the 130 too?) had temperature compensation built into the alt from the factory. It lowers the charge when its hot out and ups it when its cooler for the batteries health.
I think the 130 has it as i notice with my 93 chevy that it will run at 14v when first started and for a good 20 mins then drops down to say 13v when everything is warm. Usually slippage will happen when first started as the alt goes to full charge for a fraction of a second. I think 100A is the limit for v-belts, after that its dicey. All depends if you ever use the full 140 charge or not.
#51
I have the 140A on a v-belt now. I will have to change the belt!! Keep the one I have on there now as a back-up. I am not sure as I am using all 140 but definitely more than 100A.
Thanks!!
#52
Well, I just scored a rebuilt 100A CS130 for $19.79 on ebay. I wish I had found it before I ordered my 140A CS144 from Rock Auto the day before yesterday! Oh well for twenty bucks and free shipping I couldn't resist so I guess I'll have a spare.
Anyway You too can get a good deal on either a AC DELCO 105A CS130 (part# 3342328) or a Beck/Arnley (part# 1866183) 140A CS144 from rock auto. The CS130 is $44, no core needed and the CS144 is $78, also no core needed. If you want to look them up yourselves: $44 CS130: 1991 Pontiac Grand Am 2.5L {3 left at time of posting} $78 CS144: 1995 Buick Riviera 3.8L {11 left at time of posting} |
#53
Hmmm, looks like they ship to canada too. Shipping is abit but i will have to check them for parts more often. The CS-130 is ~$85USD with shipping but thats still cheaper than anywhere around here. I paid $100 for a used CS-144 from the wreckers.
I bought a CS-130 from them. I replaced the CS-130 in my truck a few weeks ago and it was $135 i think from NAPA.
Derek B. Current best: 11.97@110 1.65-60' !!! '74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets. 1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram. Last edited by BILTIT; 05-28-2010 at 05:35 PM. |
#54
Yes they do ship to Canada. However, I am lucky enough to only live 45 minutes from the border, so I just have things shipped to the UPS Store just on the other side of the border, and then go down and pick it up. It cost $13 for shipping to the UPS store, then I pay $5 to the UPS store for holding the package. Not a bad deal.
If you live close to the border, it is a great option to be able to ship there. |
#55
Unfortunatly i dont live anywhere near the border.
#56
rebuilt at that price
also if you can find a current rockauto discount code from someone who has recently made a purchase its 5-10% usually enough to pay postage folks on www.classicalpontiac.com Q&A forum often call for and post up those discount codes. |
#58
#59
Oh thats too bad. I didn't know about the discount codes. Oh well, I guess I'll have one to share once I pick my package up. If you google it you will find some codes also.
#60
I have been using a CS 130 for about 10 years and it has worked great!
When I got it I asked a local alternator shop about durability issues. He said that some of them do have some overheating/bearing problems, but he said that this was virtually always in cars that had the alternator mounted down low and crowded by other parts limiting airflow in/out of it. He said that when it is located up high (like a stock Pontiac V8) they tend to be very durable. I has performed great and I have had ZERO problems with it. Link to some good alternator info: http://oljeep.com/gw/alt/edge_Altern...html#Section_3 |
