Old 09-08-2019, 09:25 AM
74SDformula's Avatar
74SDformula 74SDformula is offline
Default Strange Method For Oil Galley Plug Retention
First time I have seen this method for retaining the front press in oil galley plugs. Now if they had only put the piston/rod assemblies in the correct bank and lined up the timing marks on the timing gears properly they probably would have had a decent running engine.
ID:	519696   Click image for larger version
ID:	519697   Click image for larger version
ID:	519698   Click image for larger version
Old 09-08-2019, 09:37 AM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
Looks like they tried peening them in with a railroad spike then went full on Larry the cable guy on it.
I like the lettered rods, I guess they were dyslexic though
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
Old 09-08-2019, 10:45 AM
Holeshot71's Avatar
Holeshot71 Holeshot71 is offline
I bet that ran great with a couple bottles of octane boost 😎
'71 GTO, 406 CID, 60916, 1.65 HS, '69 #46 Heads 230CFM, 800CFM Q-jet, TH400, 12 Bolt 3.55
'72 Lemans, Lucerne Blue, WU2, T41, L78, M22, G80
Old 09-08-2019, 11:38 AM
tooski tooski is offline
Bwaahaahaaaa
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
Old 09-08-2019, 11:51 AM
PunchT37's Avatar
PunchT37 PunchT37 is offline
I bet that ran great with a couple bottles of octane boost ��
It was prolly running on 1/2 gal plastic bottles of Bourbon before that.
Old 09-08-2019, 11:56 AM
Sirrotica's Avatar
Limited edition RA/CC = RAM AIR/COTTON CANDY...……….
It's known to be worth at least $.50 over any other similar Stratostreak V8....
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 09-08-2019, 02:16 PM
HO Kenny's Avatar
HO Kenny HO Kenny is offline
The worst thing is that it’s pink!
Old 09-08-2019, 02:47 PM
SRR's Avatar
SRR SRR is offline
Wow.
― Calvin Coolidge
Old 09-08-2019, 03:07 PM
Dragncar Dragncar is offline
They drilled the block for a aluminum rivet ?? A little JB weld and staking the plug will do it.
Besides, this guy needs his Pontiac card pulled for the paint job.
Old 09-08-2019, 05:46 PM
OG68 OG68 is offline
What makes you think he has a card LOL.
"I don't need no stinking card"
Maybe it was a Mary Kay car in a previous life
2007 Cadillac SRX
Old 09-08-2019, 05:58 PM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
Does it have RRE stamped on it anywhere? Could be a Bruce Fulper engine. He is an expert Pontiac engine rebuilder after all.
Old 09-08-2019, 06:17 PM
Bill Hanlon's Avatar
Might have worked if he had used silver (1964 or earlier) quarters.
Old 09-08-2019, 07:33 PM
scott70's Avatar
scott70 scott70 is offline
Lol
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
Old 09-08-2019, 07:44 PM
77 TRASHCAN's Avatar
Maybe it's Richard Simmons car???
Shut it off
Shut it off
Old 09-08-2019, 08:24 PM
Big Bear's Avatar
Big Bear Big Bear is offline
Close to the pink that was on a TA at Norwalk a few years ago.
Old 09-08-2019, 10:15 PM
NeighborsComplaint's Avatar
Definitely not a nickel and dime build.
Triple Black 1971 GTO
Old 09-09-2019, 01:43 AM
gtofreek's Avatar
gtofreek gtofreek is offline
Holy crap!
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 09-09-2019, 05:57 AM
Well if your ever short for Change at a Toll both you can always pull your timing cover!
Old 09-09-2019, 07:46 AM
I'm speechless. How can one justify that?
I guess it's what's to be expected for someone who paints a Pontiac engine that color.
Old 09-09-2019, 07:49 AM
grivera's Avatar
grivera grivera is offline
Seems it would be a PITA to do it that way versus tapping the holes or driving in/staking a plug. What does it look like under the coins?
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
