67 full quarter replacement
Does anyone have any pics of the seam where the new quartepanel and the roof meet? I need to know how much to cut or not cut. Do you grind the lead out or do you melt it out? Thanks
It'll be pretty obvious once you remove all the paint and primer in the area. I melt the solder out with a torch while brushing with a brass wire brush. It doesn't take much heat, as in 'warp a panel' heat.
Greg Reid Palmetto, Georgia |
Here is a pic for you, I did both sides using the Dynacorn full quarter
https://www.facebook.com/KauffmanRac...6873234225938/ KRE 461,310 CFM 85cc, KB pistons, Eagle rods, Ohio crank KRE custom HR236,Dougs ceramic,Edelbrock Pro Flo 4. Quick Performance 9". 552HP 594 TQ |
Thanks Gassman that's what I was looking for. I used a propane torch today and carefully melted out the lead on both quarters. (Dynacorn)
I suggest using a respirator if you use a torch to melt lead joints. The gasses can be toxic.
Green Bay: A drinking town with a football problem. |
The Following User Says Thank You to LStathas For This Useful Post: | ||
Uh, yeah... It should be much more than a suggestion. Don't be doing any lead work without wearing a respirator and good ventilation. Eeps!
1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
