Old 08-26-2019, 10:35 PM
Bill Hanlon's Avatar
Default Need an extension cord for Bosch relays
I'm trying to troubleshoot an electrical problem around a Bosch type (cube, 5 pin, 30/85/86/87/87a, etc) relay that is buried way up in the dash. If I could get a meter on the relay pins I could figure it out, but there is no way I can get to it.
I could make one, using the female end with wires that ships with the relay when you buy a new one, but no one sells a male end that I can find. I tried opening up a relay and gutting it to get a male end, but ended up destroying it.
Does anyone make an actual "extension cord" that has a Bosh male 5 pin plug on one end, at least 3 feet of 5 conductor wire and a Bosch female 5 pin plug on the other end ?
Old 08-28-2019, 05:24 AM
Can't you just put spade terminals on the end of the wires?
Old 08-28-2019, 07:00 AM
If I could see the socket that the relay plugs into, but I can't. Last night I started working on a solution using spade lugs set in potting compound (actually liquid epoxy) held in a relay cover for proper spacing. Should know tonight if it works.
Old 08-28-2019, 02:08 PM
You can cut the top off a relay, dig the guts out, and solder a relay socket with a pigtail to it.
Old 08-28-2019, 04:49 PM
That's plan B. Already have the relay torn apart, waiting to see if plan A works. Still can't believe nobody makes one.
Old 08-29-2019, 06:59 AM
RA66GTO's Avatar
RA66GTO RA66GTO is offline
The testing harness does exist via IHC / Navistar Test Equipment PN ZTSE4596, although it is not cheap.
The overall length socket to socket is about 10".
https://navistarservice.snapon.com/S...umber=ZTSE4596
1966 GTO Resto-Mod. 2nd owner California car, factory Air, Power Windows, Holley Sniper Quadrajet, MSD Dual-Sync, Gearstar 200-4R, Yank 2400 Stall Converter, HGM Compushift Mini, Heidt's Tall Spindle, UMI Control Arms, Hellwig sway bars, CPP Big Brakes, AR Torque Thrust M, Continental Extreme Contact DW
Old 08-29-2019, 07:59 AM
You're not kidding that ain't cheap!
Old 08-29-2019, 09:18 AM
Just what I need if it were about 1/10th the cost and 2 feet longer.
Epoxy is setting up on my second attempt now. The liquid epoxy was too thin. I'm trying PC-7 now.
Old 08-30-2019, 01:33 PM
I made up this 3 foot long "extension cord" for cube relays. The female end is just a standard cube relay socket. Five wires running to the male end, covered with shrink wrap. The male end is five 3/16" crimp-on spade quick disconnects sitting in PC-7 epoxy contained in an old cube relay cover. Works good.
Figured out my problem in just a few minutes once I had this tool. The main power feed for the A/C system should come to one of the relays, but wasn't making it there. Turns out there was a plug that wasn't shown on the schematic that was about 6" upstream of the relay, hiding behind the A/C unit under the dash. It had come loose.
Old 08-30-2019, 02:31 PM
Nice! And nice!
Well, that was a good effort, and will provide troubleshooting assistance down the road too!
