Old 03-07-2024, 04:05 PM
indymanjoe's Avatar
Default camshaft end play question
Ok so i installed new cam with a cloyes timing chain and gears thanks to the recommendation's from the forum here. Cam is degreed and all looks good. BUT my camschaft end play is 2.5 -3.5 thousands. Is this too tight? i have searched here for the last 3 days looking for an answer. the only thing i worry about is i have read here .03-.07 is acceptable but the 2.5 is making me worried. This is a Hydraulic roller cam fwiw. Thanks as always Joe
Old 03-07-2024, 04:13 PM
steve25 steve25 is offline
Your fine!
Old 03-07-2024, 05:31 PM
Verdoro 68's Avatar
IIRC, mine was in that neighborhood.
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - 3.55 posi (build thread | walk around)
'95 Comp T/A #6 M6 - bone stock (pics)
Old 03-07-2024, 05:35 PM
indymanjoe's Avatar
Thanks for the feedback. Just dont want any issues with this refresh. spring is coming up faster than i thought it would!
Old 03-07-2024, 05:58 PM
JLMounce JLMounce is offline
If you need peace of mind, measure the thickness of your cam retaining plate and order a plate with a thickness that will get you closer to the spec you want to see.
That said, my roller cam is out of spec to the loose side by about 3 thou. It's been running like that since 2015 and I put about 5K miles a year on the car. I think you'll be fine.
-Jason
1969 Pontiac Firebird
The Following User Says Thank You to JLMounce For This Useful Post:
Old 03-07-2024, 11:29 PM
Tim Corcoran's Avatar
Your decimal point has me confused, do you mean .0025 to .0035
Tim Corcoran
Old 03-08-2024, 07:49 AM
indymanjoe's Avatar
0.002-0.003 sorry about that
Old 03-08-2024, 08:09 AM
Keep in mind that a steel cam expands more then a cast iron one would.
Old 03-08-2024, 10:43 AM
chuckies76ta's Avatar
Something else you can or could have checked it the little hole and machined slot in the cam plate for oiling. Some of the after market ones didn't have it. I think mine was around .004 end play and it has been fine. As was mentioned, the cam-plate thickness sets the end play. I seem to remember the factory ones measure in at .124 and some of the after market ones were .115
