Old 12-25-2019, 05:59 PM
MecGen's Avatar
MecGen MecGen is offline
Default Nitrous Oxide Tripower
Hello everyone
I was wondering if anyone has put their Tripower Pontiac on spray ? I am thinking a small wet shot, maybe 75hp (or dry)
I was thinking of getting a spacer plate, between the carb and intake, like the ones on ebay and plumbing my nozzles in that instead of drilling out the intake. I hope the air cleaners still fit under the hood.
Can someone give me any advice? Pictures worth a thousand words.
Thanks in advance
Sent from my SM-T590 using Tapatalk
Old 12-25-2019, 09:33 PM
tom s tom s is offline
Old Man Taylor ran a tripower on juice in his 64 GTO YEARS ago.Tom
Old 12-25-2019, 09:57 PM
Jim Taylors NOS system was a simple plate system under the carbs.
Apparently it worked well as he had it on his street 64 GTO/Street Race car for many years and the word was he won a lot of races and a reputation with that car.
Name:	OMTs 64m GTO.jpg
Old 12-25-2019, 10:21 PM
Minor clearance issue using 1/2” nitrous plates with the front carb air cleaner requiring bending the hood bracing, Jim describes it here in this thread:
https://forums.maxperformanceinc.com....php?p=5428458
Old 12-25-2019, 10:52 PM
Thanks Bart, Merry Christmas.
Tom V
Old 12-26-2019, 01:00 AM
MecGen's Avatar
I am thinking using the 1/2 spacers, but not into bending my hood webbing. Maybe a lower profile front air filter?
Might be more trouble then I thought...
Old 04-26-2020, 10:48 PM
Old Man Taylor's Avatar
I still have nitrous on my car. It's been on continuously since 1978. Originally I just bent the brace on the hood, but when I had the car painted I had that piece cut out.
Name:	DSC_0399 small.jpg
ID:	538481   Click image for larger version
Old 04-27-2020, 05:52 AM
3X24SPD 3X24SPD is offline
Default Injected TriPower
Fogger
ID:	538489   Click image for larger version
1966 GTO (Red) WARPATH
455CI TriPower 4-Speed
1965 GTO (Black) TRIPOWR
464CI TriPower 4-Speed
1965 GTO (Blue) 3X24SPD
Old 04-27-2020, 09:36 AM
I have all of the pieces to do a Fogger set-up on one of my aluminum 1966 Tri-power
intakes and a full bottle of NOS in the Shed. Just never got around to installing it as finding a NOS supplier around the Detroit area was not easy.
Most racers had gone to "belt driven" supercharger systems and no need for bottle refills by then.
Old 04-28-2020, 08:53 AM
hill67bird hill67bird is offline
is there a part number for the nitrous plates? I have thought about putting some on my car it has a 1966 set up.
Old 04-28-2020, 11:16 AM
I don't have a part number. When mine were made (1978) they were custom made by Marvin Miller.
Old 04-28-2020, 11:17 AM
B/T/W, mine is also a '66 tri-power.
Old 04-29-2020, 08:31 AM
ok thank you I will just have to put a fogger on it.
