Anyone using SFI TH 400 cases?
So you guys in the 10s and faster are you using blankets, CSI shields, or one of the ATI type SFI TH 400 cases?
I use a basic blanket. Seems a little cheesy though. The CSI shield looks pretty slick but I have not used one.
Sent from my SM-G965U using Tapatalk
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight |
I use the Shield and it is nice other then getting those two damn bolts out on the sides, especially with a mid plate. The clearance u have now will be worse on yours being your firewall is closer lol
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,7.33@94.55-11.502@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32 M/T 275/60 ET SS Drag Radial 2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's |
blanket and jw bell
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
I use a blanket on my current 8 second race car with stock HD case (and the previous 9 second car)- with an oil cooler, no problems ever.
We use after market cases on some of our customer builds - no need for a trans shield or flexplate shield but the case is a fair bit heavier. ATI SuperCase has CNC machined case passages, the Reid has as cast passages, both very sturdy pieces. |
I have a shield and the two top ones are heck to get to. The cases look kind of pricey.
I could not fit a shield on my previous 71 Ventura.
Any other options? |
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" |
Have the CSI on my '68. Had to drill holes in the floor to access the two top bolts. Made things so easy I drilled two more for the middle ones. Of course not everyone will want to ventilate their floor but I just flap the carpet over them. Used to have rubber plugs for the holes but don't even bother with them anymore
Ain't as good as I once was, but I'm as good once as I ever was. |
The Following User Says Thank You to stags For This Useful Post: | ||
CSI shield here. I drilled holes in the firewall to get to the middle bolts. The rest are decent to get to in my G-body.
Todd Sedlmeier Who ever thought pinewood derby cars would lead to this! October 2004 HPP Shootout participate http://www.highperformancepontiac.co...out/index.html 86 Grand Prix 535 High Port 8.93 @ 153 65 GTO 433 High Port 12.04 @ 113 |
I think floor holes would definitely make it easier!
ultra bell and blanket, and two holes in the firewall for the top two bellhousing bolts.
Clutch Guys Matter _______________________________________ 53 Studebaker, 400P/th400/9" 64 F-85 72 4-4-2 Mondello's VO Twister II 84 Hurst/Olds #2449 87 Cutlass Salon 54 Olds 88 sedan |
