Old 11-28-2020, 07:38 PM
Default Anyone using SFI TH 400 cases?
So you guys in the 10s and faster are you using blankets, CSI shields, or one of the ATI type SFI TH 400 cases?
Old 11-28-2020, 07:43 PM
leeklm's Avatar
leeklm leeklm is offline
I use a basic blanket. Seems a little cheesy though. The CSI shield looks pretty slick but I have not used one.
Sent from my SM-G965U using Tapatalk
Old 11-28-2020, 07:44 PM
mysticmissle's Avatar
blanket and jw bell
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 11-29-2020, 10:53 AM
grandville455's Avatar
I use the Shield and it is nice other then getting those two damn bolts out on the sides, especially with a mid plate. The clearance u have now will be worse on yours being your firewall is closer lol
Darby
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
Old 11-29-2020, 11:21 AM
taff2's Avatar
taff2 taff2 is offline
I use a blanket on my current 8 second race car with stock HD case (and the previous 9 second car)- with an oil cooler, no problems ever.
We use after market cases on some of our customer builds - no need for a trans shield or flexplate shield but the case is a fair bit heavier. ATI SuperCase has CNC machined case passages, the Reid has as cast passages, both very sturdy pieces.
I have a shield and the two top ones are heck to get to. The cases look kind of pricey.
Old 11-29-2020, 11:29 AM
ponjohn's Avatar
ponjohn ponjohn is offline
I could not fit a shield on my previous 71 Ventura.
Any other options?
Old 11-29-2020, 06:31 PM
Old Goat Racer's Avatar
Some xtra info.
https://forums.maxperformanceinc.com...d.php?t=843615
Everybody knows somthin.
Nobody knows everything !
Old 11-30-2020, 07:24 AM
stags's Avatar
stags stags is offline
Have the CSI on my '68. Had to drill holes in the floor to access the two top bolts. Made things so easy I drilled two more for the middle ones. Of course not everyone will want to ventilate their floor but I just flap the carpet over them. Used to have rubber plugs for the holes but don't even bother with them anymore
Ain't as good as I once was, but I'm as good once as I ever was.
The Following User Says Thank You to stags For This Useful Post:
Old 11-30-2020, 08:16 PM
RA462's Avatar
RA462 RA462 is offline
CSI shield here. I drilled holes in the firewall to get to the middle bolts. The rest are decent to get to in my G-body.
Todd Sedlmeier
Who ever thought pinewood derby cars would lead to this!
October 2004 HPP Shootout participate
http://www.highperformancepontiac.co...out/index.html
86 Grand Prix
535 High Port 8.93 @ 153
65 GTO
433 High Port 12.04 @ 113
Old 11-30-2020, 08:55 PM
I think floor holes would definitely make it easier!
Old 11-30-2020, 09:26 PM
Mr Anonymous's Avatar
ultra bell and blanket, and two holes in the firewall for the top two bellhousing bolts.
Clutch Guys Matter
53 Studebaker, 400P/th400/9"
64 F-85
84 Hurst/Olds #2449
87 Cutlass Salon
54 Olds 88 sedan
