Old 01-16-2020, 08:31 PM
67gtospud's Avatar
67gtospud 67gtospud is offline
Default Best header gaskets
What header gaskets are you all using? I’ll be running Doug’s round port headers on Edelbrock aluminum heads. I’ve heard a lot of people have success with Remflex but have never personally run them myself. I also have heard of people using The Right Stuff gasket maker with good success but I’m not sure about that since it’s only rated to 450 degrees.
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/251@.050, .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears
Old 01-16-2020, 08:42 PM
tom s tom s is offline
Remflex for sure.Tom
Old 01-16-2020, 08:48 PM
Torquewar's Avatar
Torquewar Torquewar is offline
I have had different sets on mine my top picks ....Remflex /Percys....
Old 01-16-2020, 09:01 PM
TransAm 474's Avatar
TransAm 474 TransAm 474 is offline
For Sure Remflex for the street, we also had great success with Permatex Ultra Copper as well for our race engines, but for the street you cant best Remflex..
1978 Trans Am
Pump Gas 461 Stroker
Old 01-16-2020, 09:49 PM
4dblnkldude's Avatar
Same application. I use regular old Mr. Gasket, they work fine.
Old 01-16-2020, 10:05 PM
RocktimusPryme's Avatar
Remflex here as well. Before they get squeezed though they are thick, so you might need longer header bolts.
Old 01-16-2020, 10:13 PM
67gtospud's Avatar
Alright, remflex it is, I see on their website, they claim there is no need to retorque after a couple heat cycles, is it best to retorque anyways?
Old 01-16-2020, 10:14 PM
You need to at least check them. I had a couple come loose after the first time.
Old 01-16-2020, 11:30 PM
cnc's Avatar
cnc cnc is online now
Remflex here too..... never a leak
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 01-17-2020, 01:50 AM
Chris65LeMans's Avatar
+ ... what is it... 5 now?
Old 01-17-2020, 03:01 AM
6... Not on my Pontiac but on my Datsun Z with header. I will highly recommend.
Old 01-17-2020, 09:09 AM
mchell's Avatar
mchell mchell is offline
must be the odd one but I run standard Fel pro header gasket....never have leaks. Seem to last 5 years or more. They stay tight as well.
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
Old 01-17-2020, 09:49 AM
Sirrotica's Avatar
High temp RTV on a street 455 D port with Hooker headers since 1990............
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 01-17-2020, 09:55 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Felpro blue header gaskets are excellent. Never had a leak using one to date no matter how poorly made the headers were at the flanges.......Cliff
Old 01-17-2020, 10:09 AM
John Milner's Avatar
John Milner John Milner is offline
I used Mr Gasket on my round port 428 with Doug's headers. However, I had to double up on the gasket to make them seal off good.
Old 01-17-2020, 10:55 AM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
Fel-Pro. Blue gaskets here.
Old 01-17-2020, 11:11 AM
David Jones's Avatar
I ran the Doug's gaskets that came with the headers for years. When I moved the headers to my 455, I ordered new "Doug's" gaskets, I believe from Summit. A completely different gasket. Neither leaked...or, I guess in the case of the newest ones, leaks. Flat mounting surfaces, thick flanges and the right bolts will generally get you no leaks with a decent gasket and a little bit of care.
Old 01-17-2020, 12:42 PM
Formulajones's Avatar
I use copper. With a good header and mounting flange they've worked good for me for a couple decades on a few cars, and are reusable.
Old 01-17-2020, 02:43 PM
HWYSTR455's Avatar
HWYSTR455 HWYSTR455 is online now
I use the Mr. Gasket Ultra-Seal ones, the grey ones, they work really well, and easily available.
Old 01-17-2020, 03:30 PM
Hikin Mike's Avatar
Been using my copper gasket for 20+ years with no issues. Couldn't tell you what brand though.
- Mike
