Old 03-27-2020, 04:11 PM
64speed's Avatar
64speed 64speed is offline
Default What do you do about this?
Aluminum is turning yellow and corroding on the engine even though it is just sitting. Do I just polish it?
Old 03-27-2020, 04:26 PM
NeighborsComplaint's Avatar
Looks like oil to me unless you clear-coated or aluminum paint on the heads and the coating started to burn off. Aluminum dulls and the forms white aluminum oxide on the surface.
Spray it with aluminum wheel cleaner and lightly scuff with a green scotchbrite. Rinse with clear water in a spray bottle and wipe dry. The apply a liberal coating of WD40 on all the aluminum parts and retreat periodically.
Triple Black 1971 GTO
Old 03-27-2020, 05:35 PM
lust4speed's Avatar
Looks like oil to me also. Therefore I'd start with just a shop or terry towel soaked in brake clean, lacquer thinner, or acetone and see if it doesn't lift off. These won't change the surface texture and more aggressive attacks will.
Mick Batson
Old 03-27-2020, 05:53 PM
Unprotected aluminum corrodes quickly. Once you have clean the oil off, apply metal prep( a phosphoric acid solution) then apply Alodine to stop future corrosion.
Dr. Thomas Sowell
Old 03-27-2020, 05:55 PM
STEELCITYFIREBIRD's Avatar
Looks to me like iron laced dust rustin!
Old 03-27-2020, 07:44 PM
PAUL K's Avatar
PAUL K PAUL K is online now
Any idea what Alodine would do the the appearance of the aluminum? I'm assuming it would change the finish.
Go fast, see Elvis!
Old 03-27-2020, 08:48 PM
64speed's Avatar
It’s not oil. The engine hasn’t been run in months it’s not oil.
Old 03-27-2020, 08:55 PM
PAUL K's Avatar
It's rust. The heads are blasted with metal during the manufacturing process. Sometimes specs of metal are embedded in the aluminum and then rusts.
Go fast, see Elvis!
Old 03-27-2020, 09:44 PM
64speed's Avatar
So what do I do? My machinist said a scotchbrite pad no cleaner
Old 03-27-2020, 09:54 PM
Mike Davis's Avatar
Correct, the only way I have been able to keep it from happening was to use a scotchbrite pad with CLR on it.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 03-27-2020, 10:13 PM
PAUL K's Avatar
I've never had much of a problem but seemed to have luck with brake clean and a silver wire brush.
Go fast, see Elvis!
Old 03-27-2020, 11:50 PM
grivera's Avatar
grivera grivera is offline
Have you tried what he suggested?
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
Old 03-28-2020, 12:06 AM
64speed's Avatar
Can’t go out. Waiting on scotchbrite from amazon LOL
Old 03-28-2020, 12:28 AM
I assume you could use Iron Out.
Or Sodium Hydrosulfite powder if you have access to it.
Old 03-28-2020, 12:29 AM
Get a loaf of bread too while at Walmart!
Old 03-28-2020, 01:14 AM
64speed's Avatar
I have two loaves of bread and two gallons of milk. I just ordered some scotchbrite pads and wd40 from Amazon. I also have 48 rolls of TP not because I am a hoarder but because I am on the Amazon subscribe and save program and we weren’t here much last month so we got that month and this months LOL
Old 03-28-2020, 07:10 AM
400 Lemans's Avatar
400 Lemans 400 Lemans is offline
Paul is right, it is embedded rust. Had the same thing happen on my rpm intake and it keep getting worst as time went on. Never could find anything that would clean it up, so i just used high temp aluminum engine paint and sprayed entire intake. It turned out great, looks new again.
The Following User Says Thank You to 400 Lemans For This Useful Post:
Old 03-28-2020, 11:52 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
X2 paint it. Had this problem with my intake years ago and painted it engine color. Did the same on this engine-intake and heads. Paint stays on aluminum heads shockingly well
Chris D
69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60'
The Following User Says Thank You to OCMDGTO For This Useful Post:
Old 03-28-2020, 06:40 PM
coonhunter70 coonhunter70 is offline
Hit it with a small brass bristle brush
Old 03-31-2020, 09:46 AM
HWYSTR455's Avatar
x3. The Dupli-Color 1615 Aluminum Engine Paint is the right 'tone', not real shiny or anything, and looks great. Easy to touch up too.
I usually etch intakes, but it's tough to do the same on heads. Wipe it with acetone, let it dry, and shoot them.
