Old 06-13-2019, 03:28 PM
68lemans462's Avatar
68lemans462 68lemans462 is offline
Default RARE "no drill" driveshaft loop doesnt fit
I just ordered one of these and was about 50% confident it would fit. Although it did "bolt in" after barely sneaking by my X pipe, the unit is jammed up tight against the floor boards. The result is a bunch of unwanted vibratory noise from the drivetrain to the floorboards. Guess I'll be taking this off to modify it.
Anyone else have experience with this part? Wondering if my experience is unique. I'm thinking of yanking it out, heating it up, bending it down, repainting and trying again. Nothing like taking a torch to a NEW part that's supposed to fit.
1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude
Old 06-13-2019, 03:47 PM
form74's Avatar
form74 form74 is offline
I had to bend mine down a little bit , no heat needed to bend it , just put in a vise. I actually had my car on 4 x 4 pieces of wood so I could see how it fit when the car was on the ground to ensure it was centered around the driveshaft, mine is closer to the pass side as all F-body rearends are off a little, it took a few adjustments to get it right.
These are the only two pictures I have of it, looks like I bent it near the loop, i'm having a CRS moment and can't remember exactly, it's been a few years since I put it in.
ID:	514068   Click image for larger version
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.075 @ 112.70
12.092 @ 112.43
12.128 @ 111.71
Old 06-14-2019, 01:00 PM
chiphead's Avatar
chiphead chiphead is offline
I had the same experience in a '67 LeMans. Installed under the tranny mount, it jacked the tranny out of position AND hit the driveshaft tunnel. I took it back out. I still have it, my plan is to modify it to fit later.
Old 06-14-2019, 01:15 PM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is offline
Guys, Im not trying to be a jerk but there is no way I would trust that safety loop for 1 sec in a failure. In a driveshaft failure it would likely bend out of the way and allow the driveshaft to cause havoc or come apart and be part of the shrapnel flying around. I cant believe that they are NHRA legal.
Old 06-14-2019, 01:20 PM
chiphead's Avatar
That's kinda how I felt about it. Seems like it could twist the tranny off the x-member if things got ugly.
Old 06-14-2019, 01:43 PM
RocktimusPryme's Avatar
I was thinking about buying one. Just because I don't want to have to pull all my seats out and pull the carpet up. A lot of the other common ones just go through the sheet metal in the floor boards. Is that really all that much more secure? I make no argument that some of the ones that get connected to frames or are built in conjunction with sub frames are better. Obviously they are.
But I think by the fact that it is NHRA legal Im going to trust that someone did some research before it was signed off on.
I mean just visually we all look at those little Smart Cars and say "Boy I wouldn't want to be in a wreck in that" But the reality is you would probably rather be in a collision in that, than you would a 1960 Catalina.
Old 06-14-2019, 03:35 PM
Jim Moshier's Avatar
There is a whole bunch of truth this your comment! Like they say, something is better than nothing.....I still won't ride in a smart car. ....
Jim Moshier
1962 Catalina 389
Old 06-14-2019, 04:05 PM
form74's Avatar
Most Tracks by me ask you if you have one after they ask how fat your car is. I had mine on the shelf for over 5 years , until their was a bad accident (death ) at the Byron track , i was their that day and they started to check all cars after that for all safety equipment. I put on the before I went back their again.
74 Formula
3:42 gears
12.075 @ 112.70
12.092 @ 112.43
12.128 @ 111.71
Old 08-14-2019, 09:16 PM
tolerico tolerico is offline
Default Tremec fitment and RARE driveshaft loop
Well I guess I was the first...
Ordered the bolt-on driveshaft loop that Ram Air Restoration makes (and even Butler sells) for my TREMEC trans.
Upon going to mount it, realized the Tremec TKO trans have a belly 'fin' with 2 bolt bosses on the tail housing behind the transmission mount that the loop is to mount to.
The driveshaft loop will not bolt on and clear this low hanging area.
This tail belly fin, which is there for a torque arm application, has to then be shaved for the loop to fit.
Ram Air Restoration made the loop based on fitment to a Tremec TKO trans that did NOT have the fin and bolt boss on the tail since the trans they have has the fin area completely ground away (like how a stock T-5 is) for fitment to A-body GM cars. Doh!!
If you have a crappy Tremec T-5 or a customized Tremec TKO trans with the fin removed for fitment into an a-body, you will be fine.
But I'd say 80% of Tremec TKO owners have this fin/bolt boss area and will not be able to use this mount they sell without modification.
Photo shows a stock TKO trans with the fin area with bolt bosses. That is what needs to be cut off if you plan to fit this "bolt-on" loop.
Can't believe they did not have 1 person complain who has a standard TKO trans over the years. Yay me.
Old 08-14-2019, 09:22 PM
FWIW I bought one and it bolted on easily. Was also heavier duty than I expected.
I have a poly trans mount. It comes with a spacer. The spacer was about the same width as the RARE loop. So I just tossed the spacer and bolted this guy in its place.
So it seems like a one size fits a lot. But as opposed to drilling holes in your floor it’s relatively easy to try. I actually tried the basic $30 Jegs kit first, but it wouldn’t fit with my X pipe. The RARE unit was an easy bolt on in comparison.
Old 08-14-2019, 09:25 PM
You bolted it to a TKO? I can't see how with the 'fin' area on the tail housing hanging lower than the trans mount holes on the tranny.
Photos?
Picture is of a T5 (similar to a modified a-body fitment TKO tail) that shows there is no belly fin on the tail housing to contend with when trying to mount it.
Old 08-15-2019, 05:18 AM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
https://www.summitracing.com/parts/u...tiac/model/gto
I just got one of these. It bolts to the floor brace and tucks up so it doesn’t hang down. They make them for most popular models.
I had one of those Mike Caruso no drill loops but he quit making them. He had separate ones for T400’s and T350’s. That was a nice design that was made for the Pontiac crossmember. The RARE is on the left and the Caruso on the right. Never could get the RARE to fit right.
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
Old 08-15-2019, 06:50 AM
jamaca85 jamaca85 is offline
i bought the bolt on type this time around seems like it will do the job and fits great. i had a bolt on 20.00 one on the last time and it kept the driveline in place when the rear joint froze.
1970 firebird, 468, e heads,
Old 08-15-2019, 08:02 AM
Same same. I had to oval the hoop & bend the divingboard. Lots of buck bang to get a result.
Hoop would oscillate at mid-track. Really cut down on my race efforts. Tried thick rubber wedges, discs heldby zipties. Now hangs on garage wall.
Old 08-15-2019, 09:07 AM
phil400's Avatar
phil400 phil400 is offline
Ay what power level would these be necessary,or when does it start to be a good idea? I don't really race my car but beat it on the street and planning a drivetrain swap for more power.
78 T/A 4SPEED, Original paint, match #’s, mine since ‘99.
77 t/a sold
85 Monte Carlo SS sold
83 Mustang GT sold
Old 08-15-2019, 09:35 AM
I would say its always a good idea. You can save a lot of the rest of the car if something goes wrong. Not to mention the worse case scenarios where is pole vaults the car or flies out and hits someone.
Most of us get them to pass track tech though.
Old 08-15-2019, 09:57 AM
form74's Avatar
Mine sat on the Shelf for years , until their was a rollover a few years back at the local track, never saw the root cause posted ( they guy died and i'm sure their was a law suit), but shortly after that the Track posted the rules for each speed and anything under 14.00 needed a driveshaft loop according to some Race Rules.
I've been asked at that Track a lot if I have one , I always say it run's mid 12's if they ask.
74 Formula
3:42 gears
12.075 @ 112.70
12.092 @ 112.43
12.128 @ 111.71
Old 08-15-2019, 11:04 AM
Sirrotica's Avatar
On my oval track car I had the rear joint break, the front came out of the back of the transmission hit the ground and launched the driveshaft up into the trunk area. Since all the sheet metal is gutted, it hit the inside of the trunk lid and tore a hole in the outer trunk skin.
Another oval track incident where a driveshaft broke and stayed connected to the rear axle, flailing around until the driver got the car stopped. The shaft came inside the cockpit and literally ground his butt cheek off like hamburger.
Tony Stewart had one come off in a rollover in a sprint car (you're straddling the driveshaft) that took a portion of the meat off of his lower calf and messed up his knee, within the last 5 years or so.
Even without an injury, a driveshaft failure many times looks like there was an explosion under the car, destroying floorboards and anything it comes in contact with. Many school buses are made with driveshaft retaining devices from the factory due to the long multi pieced driveshafts necessary in that long of a vehicle, and the proximity to passengers sitting in the seats.
It's not a frequent failure, but when it does fail, it creates lots of carnage.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 08-15-2019, 11:45 AM
I'm not happy at all with the way the RARE fits. Installed with no mods the unit is tight up against my floor pan. I yanked it and placed in vice and bent it down and now it is not at an angle I'm not happy with as it is interfering with the driveshaft when the suspension is compressed.. I'm about to pull it for the THIRD time. Hopefully the third time is a charm. What a PITA! Would have been better off to just build my own.
Old 08-15-2019, 01:41 PM
Mine didn't fit either, X pipe in the way, and would have throw off driveline angles. Not sure why I didn't think of that before I bought it.
You can look up the rules that outline when a loop is needed, but pretty sure it's any time you run slicks, and/or a manual. Not sure about DOT drag radials, but would imagine so.
I say you need one if you are running anything other than 1350 joints. Same if you're running an OE shaft. I just don't get why so many are against getting a new shaft, people make do with ones that don't fit right, and are 50 years old, which is crazy, especially if you have like 15k in a driveline.
If you have a high stall converter, I say you need one.
I've seen more joint failures than shaft failures, which is generally less destructive. But many of the twisted shaft failures I've seen at the drags usually don't tear up the cars too much. Unless a piece stays on a rotating part, like output or pinion, and at high speed. Most failures occur at the launch, so it's pretty much over quick. People usually let off quick when they hear the bang.
Nothing wrong with the Lakewood ones that bolt to the floor pan cross brace. Inexpensive, effective.
A loop should be as far forward as possible, and within X inches of the front joint. Failures at the other end of the shaft might beat up the floor depending on how fast your going, but the front will pole-vault you.
X pipes, depending on how they're installed, actually work as a loop to some degree, but that will beat up the floor some still.
Carbon shafts just splinter, almost no damage to the car.
